Author Topic: 2004 ADT balloons  (Read 1904 times)
TJAM51
2004 ADT balloons
« on: November 28, 2004, 11:14:33 AM »
When using the 2004 balloon callouts it seems that they will only come in ata certain size. If I was drawing at 1/8" scale all would be fine, but when I change the required settings for 1/4" scale the balloon still comes in at 1/8" scale. How can I get these built in routines for 2004 ADT to adapt to the scale I am drawing at?
danny
2004 ADT balloons
« Reply #1 on: November 30, 2004, 05:13:15 AM »
seems funny, I would have thought that ADT would have their built in balloon callouts adjust to the drawing scale.  Well, their is a couple things you could try,  The ADT balloon is a block, you can try and recreate the block to the appropriate scale and as it is inserted, will default to the drawing block.  It all comes down to how the Content block was created, if it bothers you a lot, you can recreate the block using the AECCREATECONTENT command.  On the second page in this command dialog, their is a section for additional scaling.  You may want to look into that.
