Author Topic: Reissue Challenge: Get all system variables with values  (Read 13268 times)
pkohut
« on: March 10, 2010, 06:18:55 AM »
From a long long time ago -
I don't know how one would accomplish this, and thought it might be fun.  I will look into this a little more when I get back from lunch.
Since this challenge was never completed I thought it would be cool to reissue it. http://www.theswamp.org/index.php?topic=12882.msg157207#msg157207
As an alternative to the brute force method that was originally tried, how about mining strings from the executable? You can get a program to do just that from Microsoft Technet http://technet.microsoft.com/en-us/sysinternals/bb897439.aspx.  Generate a working dataset of strings from the Windows command line by issuing the following commands -
strings -u -n1 acad.exe > StringsU.txt
strings -a -n1 acad.exe > StringsA.txt
Then process the dataset using your favorite programming language to find the strings that can be used with GETVAR.
The dataset will be huge, so the challenge then becomes how to effectivly work with the generated data, reducing runtime.
Re: Reissue Challenge: Get all system variables with values
« Reply #1 on: March 10, 2010, 06:40:34 AM »
strings -u [color=red]-n1[/color] acad.exe > StringsU.txt
strings -a [color=red]-n1[/color] acad.exe > StringsA.txt
tiny fix:
strings -u[color=red] -n 1[/color] acad.exe > StringsU.txt
strings -a [color=red]-n 1[/color] acad.exe > StringsA.txt
edit: having look at the spawned data, strings sorted and unique, the unicode file while smaller appears to have much more promise than the ascii file
could be wrong tho, i'm enjoying a sleepless night so i'm kinda crossed eyed  :doa:
« Last Edit: March 10, 2010, 06:54:36 AM by MP »
« Reply #2 on: March 10, 2010, 07:11:47 AM »
here is from acad 2006
« Reply #3 on: March 10, 2010, 07:16:52 AM »
2008 attached.
Simple test: Open the files and search for "ltscale" or "viewmode" etc. It suggests _StringsU.txt will be the one that is the most revealing.
pkohut
« Reply #4 on: March 10, 2010, 07:19:16 AM »
How long did it take to generate?
« Reply #5 on: March 10, 2010, 07:20:22 AM »
about a second
here is acad 07
« Reply #6 on: March 10, 2010, 07:21:04 AM »
static void ArxGetVar_doit(void)
    std::wstring temp;
    std::vector<std::wstring> strings;
    std::wifstream ifs( _T("c:\\StringsU.txt") );
    std::wofstream ofs( _T("c:\\StringsUOut.txt") );
    while( getline( ifs, temp ) )
      strings.push_back(temp);
    resbuf buf;
    for(size_t i=0;i<strings.size();i++)
      if(acedGetVar(strings[i].c_str(),&buf) == RTNORM)
        ofs << strings[i] << std::endl;
    ofs.close();
    ifs.close();
« Last Edit: March 10, 2010, 07:25:47 AM by Daniel »
pkohut
« Reply #7 on: March 10, 2010, 07:26:24 AM »
2008 attached.
I think your right.  Also look if someone is to parse the list then the strings starting with the * character will need to strip the * before testing.  Just saw Daniels results.  Nice.
pkohut
« Reply #8 on: March 10, 2010, 07:31:16 AM »
    std::wstring temp;
How about using std::set instead?  That should reduce the dataset quite a bit.
« Reply #9 on: March 10, 2010, 07:45:48 AM »
    std::wstring temp;
like this?
  typedef std::set<std::wstring> stringset;
    std::wstring temp;
    stringset strings;
    stringset::iterator iter;
      strings.insert(temp);
    resbuf buf;
    for(iter = strings.begin();iter!=strings.end();++iter)
      if(iter->size() > 0 )
        if(iter->at(0) != '*')
          if(acedGetVar(iter->c_str(),&buf) == RTNORM)
            ofs << *iter << std::endl;
            if(buf.restype == RTSTR)
              free(buf.resval.rstring);
    ofs.close();
    ifs.close();
« Last Edit: March 10, 2010, 07:55:04 AM by Daniel »
pkohut
« Reply #10 on: March 10, 2010, 07:56:49 AM »
    std::wstring temp;
    [color=brown]std::vector<std::wstring> strings;[/color]
std::set<std::wstring> strings;
and this to get rid of duplicates (untested) -
      strings.insert(std::transform(temp.begin(), temp.end(), temp.begin(), std::toupper);
« Reply #11 on: March 10, 2010, 08:08:40 AM »
edit: updated with Paul's mods  :kewl:
    std::wstring temp;
    stringset strings;
      if(temp[0] == '*')
        strings.insert(temp.substr(1));
      else
    resbuf buf;
    for(stringset::iterator iter = strings.begin();iter!=strings.end();++iter)
    ofs.close();
    ifs.close();
07 output
« Last Edit: March 10, 2010, 09:08:22 AM by Daniel »
« Reply #12 on: March 10, 2010, 08:23:02 AM »
here is 2010s list
« Last Edit: March 10, 2010, 09:07:07 AM by Daniel »
« Reply #13 on: March 10, 2010, 08:26:46 AM »
Anyway, pretty cool find Paul
pkohut
« Reply #14 on: March 10, 2010, 08:32:42 AM »
Here's a couple tweeks to your code.  Gets rid of duplicates by promoting all strings to upper case, then adding them to a std::set.  Also, ignores the first character of a string if it is *
#include <set>
#include <fstream>
#include <string>
#include <cctype>
        std::wstring temp;
        while( getline( ifs, temp ) ) {
            if(temp[0] == L'*')
            else
        resbuf buf;
        for(std::set<std::wstring>::iterator it = strings.begin(); it != strings.end(); it++)
            if(acedGetVar(it->c_str(),&buf) == RTNORM)
                ofs << it->c_str() << std::endl;
        ofs.close();
        ifs.close();
