Author Topic: Reissue Challenge: Get all system variables with values  (Read 13045 times)
It's Alive!
  • Retired
  • AKA Daniel
Re: Reissue Challenge: Get all system variables with values
« Reply #15 on: March 10, 2010, 08:36:44 AM »
nice!
don't forget this
if(buf.restype == RTSTR)
  free(buf.resval.rstring);
« Reply #16 on: March 10, 2010, 11:17:47 AM »
Thanks for finding a way to do this Paul!  It really bothered me that I couldn't find a way to make it work.
pkohut
« Reply #17 on: March 10, 2010, 01:42:11 PM »
You guys were on the right path, just need to narrow the workload a bit.  8-)
« Reply #18 on: March 10, 2010, 02:25:40 PM »
'09 Electrical versions
With Lisp.
Ascii : 3.953 seconds
Unicode : 0.328 seconds
« Reply #19 on: March 10, 2010, 02:29:52 PM »
Tim,
I'm a bit lost in with all the 'higher knowledge' of this thread, but just curious, how can this:
strings -u -n1 acad.exe > StringsU.txt
strings -a -n1 acad.exe > StringsA.txt
be applied with LISP? [ Assuming you went down that route ]
« Reply #20 on: March 10, 2010, 02:44:19 PM »
What are the results you guys are getting after a parse of these strings?  ...the reason i ask is because i could have sworn that ive done this; let me look.
I had a list of `known' vars and i compared that to my `string' list i read from the mep 05 acad.exe whereupon i came up with the DATA file in this post: http://www.theswamp.org/index.php?topic=14632.0
With a var on its own line, i had about 700.
When i get some time i want to try and find some of the code i used to generate (compare files and such) that dat file and study this post more because im still a bit confused.
EDIT: Just saw Tim's post....
« Reply #21 on: March 10, 2010, 03:17:44 PM »
Tim,
I didn't Lee.  I use Lisp to evaluate what was returned by that.  I didn't want to take the time to figure out how to call the command through lisp, I just processed what it returned.
« Reply #22 on: March 10, 2010, 05:09:44 PM »
Tim,
Ah, I see thanks buddy  :-)
It's Alive!
  • Retired
  • AKA Daniel
« Reply #23 on: March 11, 2010, 12:04:28 AM »
So did anyone catch any strange undocumented sysvars?  :-)
« Reply #24 on: March 11, 2010, 12:52:31 AM »
Does anyone have a list of the documented ones ?  :lol:
It's Alive!
  • Retired
  • AKA Daniel
« Reply #25 on: March 11, 2010, 01:05:42 AM »
good point  :-o
« Reply #27 on: March 11, 2010, 10:06:34 AM »
I believe Kerry was just making a facetious remark.
« Reply #28 on: March 11, 2010, 10:10:00 AM »
No flies on you John  :wink:
« Reply #29 on: March 11, 2010, 10:17:42 AM »
* Se7en confused.
I'm taking advantage of a situation?
I'm not trying to be difficult here i truly dont understand.
EDIT:
*shock!* we can use the " / me " tag?!?!?!
