Author Topic: Hotkeys for Bricscad?  (Read 21207 times)
hmspe
Re: Hotkeys for Bricscad?
« Reply #15 on: May 17, 2010, 05:29:37 PM »
Thank you.
"Science is the belief in the ignorance of experts." - Richard Feynman
It's Alive!
  • BricsCAD
  • AKA Daniel
« Reply #16 on: May 18, 2010, 03:53:25 AM »
Chuck, did you write all that?
Chuck Gabriel
« Reply #17 on: May 18, 2010, 07:59:12 AM »
Yep.  Are you adding points or taking them away? :-)
It's Alive!
  • BricsCAD
  • AKA Daniel
« Reply #18 on: May 18, 2010, 08:25:41 AM »
Adding! As always, your coding is exceptional   8-)
Chuck Gabriel
« Reply #19 on: May 18, 2010, 09:12:44 AM »
Thanks.  Right back atcha.
It's Alive!
  • BricsCAD
  • AKA Daniel
« Reply #20 on: May 18, 2010, 09:43:15 AM »
Would you mind if I port this to BRX / Bricscad? I think I would need to setup a new project and I may need to ask you a question or two.
Chuck Gabriel
« Reply #21 on: May 18, 2010, 10:13:02 AM »
I think that would be great.  Ask away.  I'll do my best.
LE3
« Reply #22 on: May 18, 2010, 12:24:13 PM »
Do not know why Chuck is not working for any of the big software companies... he writes excellent code! - cheers.
Chuck Gabriel
« Reply #23 on: May 18, 2010, 12:36:14 PM »
Thanks Luis, but Chuck doesn't have the right pieces of paper, for starters.  It certainly isn't for lack of trying.
I start work on my BS in Computer Science next Monday, though.
LE3
« Reply #24 on: May 18, 2010, 12:49:25 PM »
Excellent move, go for it!
« Last Edit: May 18, 2010, 02:38:58 PM by LE3 »
It's Alive!
  • BricsCAD
  • AKA Daniel
« Reply #25 on: May 19, 2010, 12:55:57 PM »
Beta 1 for Bricscad V10
@ Chuck, All I really needed to do was convert the project to Unicode and add a line for demand loading.
Chuck Gabriel
« Reply #26 on: May 19, 2010, 01:49:23 PM »
Awesome.
Daniel Eiszele
« Reply #27 on: May 19, 2010, 07:31:43 PM »
Just in case anyone else was looking and couldn't find them.  I pulled these out of the source code.  Does anyone know if there is a command to list the functions available in an arx file?
Commands are:
Keyson - Turns hotkeys on.
Keysoff - Turns hotkeys off.
KeysToggle - Off to On; On to Off
Keys Config - Shows Configuration Dialog
GetKeys - Lists current key mappings and commands they are bound to.
EditKeys - Loads the Hotkeys editor (Currently doesn't exist?????)
By the way, great program Chuck.  This is one of those didn't know I needed it till I had it programs.  And thanks Daniel for doing the compilation for Bricscad.
« Reply #28 on: May 19, 2010, 10:22:56 PM »
From memory, the EditKeys was a COM program, not ARX.
Daniel, with the version I compiled I added an initialise function that printed the command names to the screen ... was going to write a KeysHelp routine but never got around to it.
--> Donate to theSwamp<--
Chuck Gabriel
« Reply #29 on: May 19, 2010, 10:23:24 PM »
Thanks for the kind words.
The HotKeys editor is a stand-alone VB6 program.  I can post a copy here if you like.
