Author Topic: Block Manager [Option 2]  (Read 22933 times)
TimSpangler
  • CAD Naked!!
« on: March 03, 2010, 01:04:00 PM »
****NEW CODE ADDED****
-Check the lisp header for changes
So in response to this thread >Here<.
I have finally gotten off of my arse and finished the first OpenDCL project that I started.  I want to thank JB for some of the ObjectDBX code.
A quick run down:
-It is a palette form that utilizes OpenDCL.
-It was created in [5.1.2.3]
-It writes all of its setting to the registry (theswamp\block manager\)
-It can use either a Folder library or a Drawing container Library
-It has the ability to save libraries as favorites for quicker access
-It has the ability to select the insert layer as long as it is in the drawing
-It has the ability to open the current block for editing
-It has a quick link to theswamp.....
Here are some pics:
The Palette:
The Favorites:
The File info:
The palette starts with a dialog asking for the library type.  Once selected it will then ask for the library location:
-For Folder type this will be the top level of the library and will show all the sub folders as libraries in the drop down.  Select the library and it will show all of the drawings in that
sub folder as blocks in the list.
-For Drawing type this will be the folder that contains all of the container drawings.  The drawing will be listed as libraries.  Select the library and the blocks in that drawing will be listed as block in the list.
You can change library type by selecting either the large text or the button.
To add the current library as a favorite select the favorite button (the little piece of paper) and it will bring up the dialog.  Just hit add. Delete should be obvious.  Load is as it says, you can also load by dbl clicking the favorite in the list.
To reset the directory, just click the open file button and reselect the directory.  This will change the current directory.
Double clicking the block in the block list will show the file properties of the selected block (if it is a drawing) or the properties of the container drawing.
Double clicking the the block preview will insert the block on the layer listed (if it is not changed it should be the current layer).  Using the insert button will do the same.
Close button will close the palette (duh)
The ? will not do anything  (YET).
I hope that this explains most everything, if not, you know where to find me (hiding in the corner)
Comments / Feedback welcome
ENJOY!
« Last Edit: August 05, 2010, 01:01:08 PM by TimSpangler »
ACA 2015 - Windows 7 Pro
jbuzbee
Re: Block Manager [Option 2]
« Reply #1 on: March 03, 2010, 01:18:46 PM »
Tim,
Excellent work!  I like the graphic at the bottom!  Thanks for doing this - I was getting bored with mine (very short attention span  :lol: )
I'm eager to download it and give it a try.  Looks like a lot of nice features . . ..
jb
PS: good work.
James Buzbee
Windows 8
nivuahc
« Reply #2 on: March 03, 2010, 01:26:10 PM »
Tim,
Looks fantastic!
One minor problem:
Specify scale factor: <1>
.-insert Enter block name or [?]: S:\ACAD\Blocks\\J-Box.dwg
Invalid block name.
; error: Function cancelled
nivuahc
« Reply #3 on: March 03, 2010, 01:30:50 PM »
This fixed it. Not sure how it affects DWG Library type blocks...
(defun c:BLOCK_PREVIEW_OnDblClicked (/ TmpEnt tmpScale)
;; Get the insertion scale
(if (null (setq tmpScale (getreal "\n Specify scale factor: <1>")))
(setq tmpScale 1)
;; Insert the selected block
(if (= SBM_LibType "Folder")
;; Insert the block
[color=red];(command ".-insert" (strcat SBM_Directory "\\" SBM_Library "\\" SBM_Block) "scale" tmpScale PAUSE PAUSE)[/color]
[color=blue](command ".-insert" (strcat SBM_Directory "\\" SBM_Library SBM_Block) "scale" tmpScale PAUSE PAUSE)[/color]
;; Import the block from the container
(BLOCK_ImportDbx (strcat SBM_Directory "\\" SBM_Library) SBM_Block)
;; Insert the block
(command ".-insert" SBM_Block "scale" tmpScale PAUSE PAUSE)
;; Get the block
(setq TmpEnt (entget(entlast)))
;; Change the layer
(setq TmpEnt (subst (cons 8 SBM_Layer)(assoc 8 TmpEnt) TmpEnt))
(entmod TmpEnt)
;; Send status
(princ (strcat "\n " SBM_Block " was inserted...."))
;; Silent Exit
TimSpangler
  • CAD Naked!!
« Reply #4 on: March 03, 2010, 01:33:59 PM »
(setq tmpScale 1)
;; Insert the block
;; Insert the block
;; Get the block
;; Change the layer
(entmod TmpEnt)
;; Send status
;; Silent Exit
Weird?  It has been working great since I started testing it a week ago.  Let me have another look at that.  As far as drawing blocks that code is right below the code that you modified.
TimSpangler
  • CAD Naked!!
« Reply #5 on: March 03, 2010, 01:35:54 PM »
James,
I do have one small issue with the dbx code.  It seems to leave the selected container drawing locked until autocad closes?  have you seen this?
jbuzbee
« Reply #6 on: March 03, 2010, 01:39:24 PM »
I'm out of the office and my laptop doesn't have ACAD so I can't look / test, but you are releasing the DBXDOC object?  This should be done as soon as possible in the code.  I'll have a look tonight at home - that is until Ghost Hunters comes on!
James Buzbee
Windows 8
alanjt
  • Standby for witty remark...
« Reply #7 on: March 03, 2010, 02:28:48 PM »
Very nice Tim! Will have to test tomorrow.
Dropbox
Krushert
  • FREE BEER Tomorrow!!
« Reply #8 on: March 03, 2010, 03:16:50 PM »
As for the Scale, I would suggest of adding a check box(s) the set to the scale to dimscale and/or cannoscale.
My 1/2 cent opinion.
TimSpangler
  • CAD Naked!!
« Reply #9 on: March 03, 2010, 03:28:33 PM »
(setq tmpScale 1)
;; Insert the block
;; Insert the block
;; Get the block
;; Change the layer
(entmod TmpEnt)
;; Send status
;; Silent Exit
Chuck,
What is the actual block name that you are inserting?  Are you using folder or drawing library?
Crank
« Reply #10 on: March 03, 2010, 03:29:09 PM »
If you want to use cannoscale, you have to make the block annotative and let Autocad handle the scaling.
I think the scale options should be the same as with normal toolpalettes.
nivuahc
« Reply #11 on: March 03, 2010, 03:37:22 PM »
Folder, and that happened no matter which block I chose. For the record, the one I posted above was named J-Box.dwg
Krushert
« Reply #12 on: March 03, 2010, 03:51:45 PM »
(setq CANN0SCALE (getvar "cannoscalevalue"))
(setq ARCHVALUE (/ 1 CANN0SCALE)) ;start of Calculations
Returns
ARCHVALUE = 96.0
CANN0SCALE = 0.0104167
I have it inserting Dumb Blocks all day long?
Am i using it wrong?
jbuzbee
« Reply #13 on: March 03, 2010, 04:04:26 PM »
No.  That's how I use it for like tags and stuff.  The new way is to let AutoCAD manage annotative blocks, scaling them when the annoscale changes.  I find this functionality limited for a number of reasons.  Besides, we use the Project Navigator in Architecture so all annotation goes into a View drawing which never changes scale.
James Buzbee
Windows 8
TimSpangler
  • CAD Naked!!
« Reply #14 on: March 03, 2010, 04:08:50 PM »
From you example above, it seems to be adding extra \  between the library and the block?  I am not seeing that.  I will check through the code again.
