Author Topic: Block Manager [Option 2]  (Read 22904 times)
TimSpangler
  • CAD Naked!!
Re: Block Manager [Option 2]
« Reply #45 on: January 19, 2011, 12:43:38 PM »
Have you run this before with out any errors?
ACA 2015 - Windows 7 Pro
linuxsun
« Reply #46 on: January 21, 2011, 03:21:11 AM »
Let me check to be sure that dcl_Control_SetToolTipTitle was available then.  The last version that I have been using is 6.0.1.3.
BRB
And before the time that I use OpenDCL v. 5.1.2.3 I have not tried the 6.0.1.3 version. Error could be caused from the language of autocad ITA and not ENG.
« Reply #47 on: January 21, 2011, 04:45:47 AM »
I'd recommend everyone use
Current Build [6.0.2.1]
http://www.opendcl.com/download/
2011/01/13 : Release Candidate 1 is now available. I still want to do some detailed testing
and tweaking of control bar and palette forms in Bricscad, but otherwise RC1
is what I expect to be released as the finished OpenDCL 6.0.
