Author Topic: .NET Getting Started  (Read 111012 times)
« on: March 03, 2010, 12:03:03 AM »
.NET Getting Started.
IDE
MS VS2008 MSVS2010
http://www.microsoft.com/express/Downloads/
http://msdn.microsoft.com/en-au/evalcenter/default.aspx
MS EXPRESS Editions 2008 2010
SharpDEVelop
http://www.icsharpcode.net/OpenSource/SD/
Learning
http://msdn.microsoft.com/en-us/vstudio/cc136611.aspx
Visual C# Developer Centre
http://msdn.microsoft.com/en-au/vcsharp/default.aspx
Visual Basic Developer Centre
http://msdn.microsoft.com/en-au/vbasic/default.aspx
AutoDesk Developer Center
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1911627
AutoCAD .NET Developer's Guide
http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%20.NET%20Developer's%20Guide/index.html
ObjectARX Reference
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=785550
AutoCAD .NET Labs
   AutoCAD 2010 .Net Training.zip (zip - 706Kb)
http://images.autodesk.com/adsk/files/autocad_2010_dotnet_training.zip
AutoCAD .NET Wizards NEW!
   AutoCAD 2010 .Net Wizards.zip (zip - 477Kb)
http://images.autodesk.com/adsk/files/autocad_2010_dotnet_wizards.zip
Introduction to AutoCAD .NET Programming DevTV session
http://through-the-interface.typepad.com/through_the_interface/2007/11/devtv-introduct.html
ADN DevCast Episode 1
http://through-the-interface.typepad.com/through_the_interface/2010/02/the-stephen-and-fenton-show-adn-devcast-episode-1.html
DevTV: Introduction to AutoCAD .NET Programming
http://download.autodesk.com/media/adn/DevTV_Introduction_to_AutoCAD._NET_Programming/
AutoDesk Discussion Group
http://discussion.autodesk.com/forums/forum.jspa?forumID=152
Augi forums
http://forums.augi.com/forumdisplay.php?f=215
index: http://www.theswamp.org/index.php?topic=31866.0
Viewing Code :
For a better code viewing option,
In your UserProfile in Look and Layout Preferences set the theme to Mercury.
Copy and Paste code :
With code posts that use the new colored formatting ;
ie
Code - C#: [Select]
  1.                 foreach (MText mtxt in mtextToFix)
  2.                 {
  3.                     mtxt.Contents = mtxt.Text;
  4.                 }
  5.
If you use IE9, the best way to copy the code to the clipboard is to select 'Quote' at the top Right of the post
and then clip the code from the post editor.
( Cancel or hit the Page-Back button when done )
FireFox and Chrome will copy the code without the line numbers and retaining the whitespace formatting
Note :
Some of these references are getting a little old. If you find any that are more current please add them to this thread :)
Regards
« Last Edit: April 21, 2012, 05:33:56 AM by Kerry »
kdub in one timeline.
--> Donate to theSwamp<-
Re: .NET Getting Started
« Reply #1 on: March 03, 2010, 12:17:54 AM »
Some Books ...
Microsoft Visual C# 2008 Step by Step ~ John Sharp
http://www.amazon.com/gp/product/0735624305?ie=UTF8&tag=msdn-vs-20&linkCode=as2&camp=1789&creative=390957&creativeASIN=0735624305
Programming C#: Building .NET Applications with C# ~ Jesse Liberty
http://www.amazon.com/Programming-Building-Applications-Jesse-Liberty/dp/0596006993/ref=sr_1_2?ie=UTF8&s=books&qid=1267593144&sr=1-2
Pro C# 2008 and the .NET 3.5 Platform, Fourth Edition (Windows.Net) ~ Andrew Troelsen
http://www.amazon.com/2008-NET-Platform-Fourth-Windows-Net/dp/1590598849/ref=pd_sim_b_10
OR wait for
Pro C# 2010 and the .NET 4.0 Platform, Fifth Edition ~ Andrew Troelsen
http://www.amazon.com/Pro-2010-NET-Platform-Fifth/dp/1430225491/ref=pd_sim_b_70
Code Complete: A Practical Handbook of Software Construction ~ Steve McConnell
http://www.amazon.com/Code-Complete-Practical-Handbook-Construction/dp/0735619670
Chuck Gabriel
« Reply #2 on: March 03, 2010, 07:28:53 AM »
This should probably be a sticky.
« Reply #3 on: March 05, 2010, 11:48:04 PM »
Done !
Anyone else have any links to tutorials of books ??
« Reply #4 on: March 08, 2010, 06:09:20 PM »
I used this to get my programs to just run.
Editing the registry to have the dll  be demand loaded, and the commands defined ~ Glenn R.
[ http://www.theswamp.org/index.php?topic=16184.msg196725#msg196725 ]
« Reply #6 on: April 09, 2010, 09:25:00 PM »
for VS2010 IDE
http://www.theswamp.org/index.php?topic=32974.msg384418#msg384418
Regarding LearnVisualStudio.net   Video Library
« Reply #7 on: August 16, 2010, 03:14:48 PM »
A new version of the  AutoCAD .NET Wizard has been posted– compatible with AutoCAD 2011 and with Visual Studio 2010
http://through-the-interface.typepad.com/through_the_interface/2010/08/new-version-of-the-autocad-net-wizard-posted.html
jgr
« Reply #8 on: September 02, 2010, 09:58:24 PM »
Free utilities and components for dotNet
Utilities:
Free obfuscator for .NET
http://www.foss.kharkov.ua/g1/projects/eazfuscator/dotnet/Default.aspx
Utility that can be used to merge multiple .NET assemblies into a single assembly
http://www.microsoft.com/downloads/details.aspx?FamilyID=22914587-b4ad-4eae-87cf-b14ae6a939b0&displaylang=en
C# Exception Logger
http://www.doogal.co.uk/exception.php
PInvoke Interop Assistant
helps developers to efficiently convert from C to managed P/Invoke signatures or verse visa.
http://clrinterop.codeplex.com/releases/view/14120
Components and controls:
Object database engin (open source)
http://db4o.com/
45 free WinForms Controls
http://www.componentfactory.com/product?id=3
30 free WinForms Controls
http://www.qiosdevsuite.com
Zip and Unzip (open source)
dotnetzip.codeplex.com
CADbloke
  • Crash Test Dummy
StackOverflow - programming Q & A
« Reply #9 on: September 03, 2010, 04:12:44 AM »
Just in case you missed it - http://stackoverflow.com/ has over 900,000 programming questions and answers ... so far. Lots of .NET, not so much AutoCAD.
« Reply #10 on: September 03, 2010, 04:24:22 AM »
CADbloke
I've been using stackoverflow a bit myself recently.
Can't quite make up my mind about the member evaluation system there, but they sure do handle a lot of questions each day ... and with pretty good manners
Thanks for the post, and welcome to theSwamp
ps:
good to see a another fellow countryman  8-)
Glenn R
  • What idiot child of married cousins wrote this?!
« Reply #11 on: September 03, 2010, 04:43:41 AM »
hehe....even if he is a 'mexican' :D
Me
« Reply #12 on: November 22, 2011, 08:53:37 PM »
C# Fundamentals: Development for Absolute Beginners
A newly collated 24 episode series on Channel 9 at MSDN.
http://channel9.msdn.com/Series/C-Sharp-Fundamentals-Development-for-Absolute-Beginners#tab_sortBy_sequential
I haven't seen the videos but they seem to be presented by Bob Tabor who's work I am familiar with at www.LearnVisualStudio.net  .
Should be great for a refresher course as well as for Beginners.
Regards
« Reply #13 on: November 22, 2011, 11:39:11 PM »
Addendum to previous post.
DO NOT view the lesson by clicking the piccy ( the default resolution is a little crappy)
Select either
High Quality WMV (PC, Xbox, MCE)
or
High Quality MP4
or better yet, download  the WMV
enjoy
« Reply #14 on: November 23, 2011, 12:15:28 AM »
Just noticed that there is also a Series for VB.net if you want to go that way.
http://channel9.msdn.com/Series/Visual-Basic-Development-for-Absolute-Beginners/Series-Introduction-01
