Author Topic: GetObject (AutoCAD2010-64 bit) from VB6 on Windows7 (64-bit)  (Read 5074 times)
NYacad
« on: February 24, 2010, 09:57:15 PM »
Hello:
How to Get AutoCAD on Windows7 (or Vista) 64-bit from standing alone VB6 application?
The following code (or similar simple procedures, like ACADDOC.SendCommand...) is producing “Type mismatch” error on above-shown environment.
Public ACADAPP As AcadApplication
Public ACADDOC As AcadDocument
    Private Sub GetLength()
Set ACADAPP = GetObject(, "Autocad.Application")
Set ACADDOC = ACADAPP.ActiveDocument
AppActivate ACADAPP.Caption
  MsgBox (ACADDOC.Utility.GetDistance(, vbCrLf & "Get Length:"))
  End Sub
Changing to ... GetObject(, "Autocad.Application.18") doesn't help
What is the name of reference and location of AutoCAD VBA library on 64-bit OS?
For AutoCAD2010 on Windows XP those are:
AutoCAD 2010 Type Library (IS IT DIFFERENT IN 64-BIT?)
Location
C:\Program Files\Common Files\Autodesk Shared\acadx18enu.tlb (IS IT DIFFERENT IN 64-BIT?)
Any help will be appreciated.
One more question: is it possible to install additional and have two OS (Windows XP and Windows 7) on one PC?
Alex
sinc
Re: GetObject (AutoCAD2010-64 bit) from VB6 on Windows7 (64-bit)
« Reply #1 on: February 25, 2010, 11:49:52 PM »
Maybe one of these?
C:\Program Files\Common Files\Autodesk Shared\acax18enu.tlb
C:\Program Files (x86)\Common Files\Autodesk Shared\acax18enu.tlb
