Author Topic: Adding and subtracting dimensions with lisp.  (Read 11593 times)
KOWBOI
« on: February 22, 2010, 03:28:14 PM »
I have a lisp routine that is supposed to add or subtract dimensions. It works fine with horizontal or aligned dimensions but not with vertical dimensions. Any Ideas on this?
Re: Adding and subtracting dimensions with lisp.
« Reply #1 on: February 22, 2010, 03:58:43 PM »
Could you post what you have, and perhaps we can help a bit better  ;-)
« Reply #2 on: February 22, 2010, 04:00:51 PM »
KOWBOI
« Reply #3 on: February 22, 2010, 05:02:25 PM »
Wow, thanks, this is almost exactly what I wanted. I would also like to be able to place the total on the drawing. My lisp skills are meager and I'm almost afraid to hack at this one to do that. Any suggestions? TIA.
KOWBOI
« Reply #4 on: February 22, 2010, 05:04:21 PM »
I forgot to add. Thanks to SMadsen for the lisp, great job!
« Reply #5 on: February 22, 2010, 05:51:25 PM »
This may work for you:
;;; TXTSUM.LSP by Stig
;;; Routine that allows for pick of text, dimensions and attributes
;;; in order to do calculation with numbers in the text. Valid are
;;; strings that entirely represents a number or that has a number
;;; at the leftmost position, which is separated from alpha characters
;;; with a space, tabulation, quote or double quote (newline character
;;; in MTEXT is not a valid separator!).
;;; Units allowed by LUNITS are valid. If a number of any format
;;; is not separated by the above characters from alpha characters,
;;; it will not be regarded as a number (normal behavior of READ).
;;; No angle units are handled, - only linear units.
;;; NOTE: For dimensions, only the actual measurement will be read.
(defun getNent_kWords (msg lst kwords / ent)
  (setvar "ERRNO" 0)
  (and (not msg) (setq msg "\nSelect object: "))
  (while (and (not ent) (/= (getvar "ERRNO") 52))
    (and kwords (initget kwords))
    (setq ent (nentsel msg))
      ((= (type ent) 'STR))
      ((vl-consp ent)
       (cond ((> (length ent) 2)
                ((member (cdr (assoc 0 (entget (last (last ent))))) lst)
                 (setq ent (last (last ent))))
                ((member (cdr (assoc 0 (entget (car ent)))) lst)
                 (setq ent (car ent)))
                ((princ "\nNot a valid object") (setq ent nil))
  ent
(defun C:TXTSUM (/ ent entl func cont txtsum lastsum undosum used useUsed)
  (defun printCurrent (sum) (and sum (princ (strcat "\nCurrent result: " (rtos sum)))))
  (setq func '+)
  (while (setq ent (getNent_kWords
                    (strcat "\nSelect text or [+/-/*/Div/Undo] (current: "
                            (vl-princ-to-string func) "): ")
                    '("TEXT" "MTEXT" "DIMENSION" "ATTRIB")
                    "+ - * Div / Undo"
      ;; if entity of type TEXT, MTEXT or DIMENSION go get supposed number ...
      ((= (type ent) 'ENAME)
       (setq entl (entget ent))
       (cond ((member (cdr (assoc 0 entl)) '("TEXT" "MTEXT" "ATTRIB"))
              (setq cont (cdr (assoc 1 entl)))
              ;; figure out the format with various DISTOF units.
              ;; if no DISTOF format is recognized, simply READ it
              ;; and see if something can be obtained from the string
              (setq cont
                       ((distof cont 1))
                       ((distof cont 2))
                       ((distof cont 3))
                       ((distof cont 4))
                       ((distof cont 5))
                       ((read cont)) ; get number if followed by a space "10 a" = 10
                       ;; (read "10a") = "10a" so you must test result with
                       ;;   (numberp "10a") results in 'not a number'
             ;; got a dimension .. just read the measurement
             ((= (cdr (assoc 0 entl)) "DIMENSION")
              (setq cont (cdr (assoc 42 entl)))
         ((and (not txtsum)(numberp cont))
          (setq txtsum cont lastsum txtsum used (cons ent used))
          (printCurrent txtsum))
         ;; see if it really holds a number
         ((numberp cont)
          ;; add last result to undo list
          (setq undosum (cons lastsum undosum))
          ;; ... and see if it has already been used
          (if (cond ((member ent used)
                     (initget "Yes No")
                     (cond ((/= "No"
                              (getkword "\nAdd object already used? [Yes/No] <Yes>: "))
                            T)))
                    (T)
              (if (and (= func '/)(zerop cont))
                (princ "\nDivide by zero error")
                (setq txtsum (apply func (list txtsum cont))))
              (princ (strcat "\n" (rtos lastsum) " " (vl-princ-to-string func)
                             " " (rtos cont) " = " (rtos txtsum)))
            );_ progn
          ) ; if
          (setq used (cons ent used) lastsum txtsum)
         ) ;_ numberp
         ((princ "\nNo numeric value found")(printCurrent txtsum))
       ) ;_ cond
      ) ;_ type ENAME
      ;; if string then it must have been returned by getEnt_kWords and
      ;; is either "+", "-", "*" or "Div" (or "/"). Go set up function to use
       (cond ((= ent "Div") (setq func '/))
             ((= ent "Undo")
              ;; if undo can be done, go get the previous result and
              ;; chop off the undo list
              (if undosum
                (setq txtsum  (car undosum) lastsum txtsum undosum (cdr undosum))
                (princ "\nNothing to undo")
             ((setq func (read ent)))
    ) ;_ cond
  ) ;_ while
  (and txtsum (princ (strcat "\nTotal: " (rtos txtsum))))
  ;;  Added by CAB 02.22.2010
  (initget "Yes No")
  (if (/= (getkword "\nAdd total to drawing? [Yes/No] <Yes>: ") "No")
(setq pt (trans (getvar 'viewctr) 1 0))
  (command "._undo" "_mark")
        (setq ent
       (entmakex
(list (cons 0 "TEXT") ;***
                 (cons 1 (rtos txtsum)) ;* (the string itself)
                 (cons 6 "BYLAYER") ; Linetype name
                 ;;(cons 8 "0")   ; layer
                 (cons 10 pt) ;* First alignment point (in OCS)
                 (cons 11 pt) ;* Second alignment point (in OCS)
                 (cons 40 (getvar "TextSize")) ;* Text height
(princ "\nPick location.")
(command "._Move" ent "" "_non" Pt pause)
;;  Test for ENTER pressed ILO point picked
(if (equal 0.0 (distance Pt (getvar "lastpoint")) 0.0001)
  (command "._undo" "_back") ; & exit
KOWBOI
« Reply #6 on: February 23, 2010, 10:48:30 AM »
This is great, thank you so much CAB. Your skills are greatly appreciated!
« Reply #7 on: February 23, 2010, 11:10:12 AM »
You're quite welcome.
KOWBOI
« Reply #8 on: February 26, 2010, 12:39:42 PM »
What I want to use this routine for is to select two dimensions and multiply them so as to get the area and place that on the drawing.  I made some very minor, simple changes. It now defaults to multiply your selection and places the area to 2 decimal places on a specific layer that does not plot then switches back to the previous layer. However, our drawings are in millimeters and I need square feet and I have not been able to figure out what to change in the code to make this happen. CAB has been a huge help and I was hoping he might be able to take a shot a this since my lisp skills suck so bad. Thanks again.
KOWBOI
« Reply #9 on: February 26, 2010, 01:12:56 PM »
I work for a company that does granite counter tops and some of the are quite odd but when I get the area of a piece it needs to be squared off. I thought this might give you an idea of what I am talking about. Thanks again for all the help.
« Reply #10 on: February 26, 2010, 01:28:27 PM »
Instead of messing with dimensions, you could get the BoundingBox for the object, and use its area  :-)
Or you could use a field that links the two dimensions...  :-)
« Reply #11 on: February 26, 2010, 01:42:30 PM »
Hows this for example?
Just knocked it up quickly:
(defun c:dimFld (/ e1 e2 pt)
  (vl-load-com) ;; Lee Mac  ~  26.02.10
  (setq *doc (cond (*doc) ((vla-get-ActiveDocument
                             (vlax-get-acad-object)))))
  (if (and (setq e1 (car (entsel "\nSelect Dimension 1: ")))
           (eq "DIMENSION" (cdr (assoc 0 (entget e1))))
           (setq e2 (car (entsel "\nSelect Dimension 2: ")))
           (eq "DIMENSION" (cdr (assoc 0 (entget e2))))
           (setq pt (getpoint "\nSelect Point for Field: ")))
    (vla-AddMText
      (if (zerop (vla-get-ActiveSpace *doc))
        (if (eq :vlax-true (vla-get-Mspace *doc))
          (vla-get-ModelSpace *doc)
          (vla-get-PaperSpace *doc))
        (vla-get-ModelSpace *doc)) (vlax-3D-point pt) 0.
      (strcat "%<\\AcExpr "
              "%<\\AcObjProp Object(%<\\_ObjId "
              (itoa (vla-get-Objectid (vlax-ename->vla-object e1)))">%).Measurement >% * "
              (itoa (vla-get-Objectid (vlax-ename->vla-object e2)))">%).Measurement >% \\f \"%lu6\" >%")))
  (princ))
« Last Edit: February 26, 2010, 01:59:01 PM by Lee Mac »
KOWBOI
« Reply #12 on: February 26, 2010, 02:06:31 PM »
WOW! I didn't know that was even possible. Thanks so much for the help but I have to draw in millimeters and show the area in square feet. I also need it to be on a specific layer called NO_PLOT_LAYER. I know absolutely nothing about vl, vla, vlx or any of that or I would try and edit the code myself.
« Reply #13 on: February 26, 2010, 02:08:50 PM »
This may be the conversion. Untested
(setq SqFt (* Dim1 Dim2 0.000010764))
(princ (rtos SqFt 2 2))
« Reply #14 on: February 26, 2010, 02:13:51 PM »
No worries, try this:
(defun c:dimFld (/ e1 e2 pt suff)
  (setq suff "sq.ft") ;; Suffix
  (or (tblsearch "LAYER" "NO_PLOT_LAYER")
      (vla-add (vla-get-layers *doc) "NO_PLOT_LAYER"))
    (vla-put-layer
      (vla-AddMText
                (itoa (vla-get-Objectid (vlax-ename->vla-object e2)))">%).Measurement >%"
                " \\f \"%lu6%ps[, " suff "]%ct8[1.07639104e-005]\" >%"))
    "NO_PLOT_LAYER"))
  (princ))
