Author Topic: Seeing info of selection sets  (Read 6212 times)
Re: Seeing info of selection sets
« Reply #15 on: February 19, 2010, 07:28:06 PM »
QAFLAGS is undocumented. It's been in AutoCAD since R11.
« Reply #16 on: February 19, 2010, 07:45:32 PM »
QAFLAGS normally affects whether selection sets can be exploded.  :-)
« Reply #17 on: February 19, 2010, 08:53:11 PM »
Maybe:
(defun c:test (/ usrexplmode ent ss)
  (if (setq ss (ssget "_X" (list (cons 0 "INSERT") (cons 410 (getvar 'CTAB)))))
      (setq usrexplmode (getvar "explmode"))
      (setvar "explmode" 1)
      (mapcar '(lambda(x)(command "._explode" x)) (mapcar 'cadr (ssnamex ss)))
      (setvar "explmode" usrexplmode)
« Reply #18 on: February 19, 2010, 08:59:33 PM »
Another one to try.
(defun c:test (/ ss)
      (initcommandversion 2)
      (command "._explode" "P" "")
« Reply #19 on: February 19, 2010, 09:08:06 PM »
Last one:
(defun C:test (/ ss flag)
      (setq flag (getvar "qaflags"))
      (setvar "qaflags" 5)
      (command "explode" ss "")
      (setvar "qaflags" flag)
myloveflyer
« Reply #20 on: February 19, 2010, 09:17:58 PM »
CAB,NICE
HAPPY NEW YEAR!
Never give up !
« Reply #21 on: February 19, 2010, 09:28:22 PM »
yep, that last one should do nicely Alan
Should ignore locked layers too, yes ?
« Reply #22 on: February 19, 2010, 10:04:36 PM »
Wow.  Learned something new.  I could have sworn that I used a selection set with the explode command before.  Guess I remembered wrong.  Good to know.
« Reply #23 on: February 19, 2010, 11:13:39 PM »
Thanks all,
It honered locked layers in ACAD2000.
I could not test the middle one because initcommandversion is not recognized in ACAD 2000.
No more time tonight..
ZZZZZZZZZZZZZZZzzzzzz........
Hangman
« Reply #24 on: February 21, 2010, 11:12:25 AM »
Thanks all,
I think the correct phrase would be something to the effect of:
LiZZZZPPLiZZZZPPLiZZZZZZZzzzzzzppp........
Nicely done.
Hangman  8)
