Author Topic: Question of the day #3  (Read 3493 times)
« on: November 24, 2004, 10:21:53 AM »
Re-write the following function using a different procedure but produce the same results.
(defun c:cyrds ( / cubic_yards)
    (setq cubic_yards
   (apply '*
  (list
    (getreal "\nEnter length: ")
    (getreal "\nEnter width: ")
    (getreal "\nEnter height: ")
   27.00
    (prompt
      (strcat
"\nCubic yards of concrete = "
(rtos cubic_yards 2 2)
« Reply #1 on: November 24, 2004, 10:34:22 AM »
I'd prefer to leave the return value numerical so it could be used to feed another function or the command line. Dressing up the return value could be performed by a calling function.
(defun CubicYards ( )
    (apply '*
        (cons
            (/ 1 27.0)
            (mapcar
               '(lambda (what)
                    (initget 7)
                    (getdist (strcat "\nEnter " what))
               '("length: " "width: " "height: ")
« Reply #2 on: November 24, 2004, 10:47:00 AM »
MP, very slick..
That one would be hard to beat.
« Reply #3 on: November 24, 2004, 11:11:45 AM »
Here is my offering.
Rather straight forward.
(defun cyrds (bu / x y z)
  (initget 7)
  (setq x (getdist "\nEnter length: "))
  (initget 7)
  (setq y (getdist "\nEnter width: "))
  (initget 7)
  (setq z (getdist "\nEnter height: "))
  (/ (/ (* x y z) 27.0) (if (= bu "Feet") 1 1728))
(defun c:cyards(/ units)
  (initget "Feet Inches")
  (setq units (getkword "\nYou base unit is in [Feet or Inches] <Inches>."))
  (prompt (strcat  "\nCubic yards of concrete = " (rtos (cyrds units) 2 2)))
« Reply #4 on: November 24, 2004, 11:42:31 AM »
While we're on the subject of nested functions..............
(defun c:cyrds ( / get-real cubic-yards val lst)
  (defun get-real (what)
    (getreal (strcat "\n"what": "))
  (defun cubic-yards (lst)
    (/ (apply '* lst) 27.00)
    (= (length
         (foreach item '("Length" "Width" "Height")
                  (if (setq val (get-real item))
                    (setq lst (cons val lst))
       3
    (princ
      (strcat "\nCubic yards = "(rtos (cubic-yards lst) 2 2))
    ; else
    (princ
      (strcat
        "\nI need more than "
        (itoa (length lst))
        " numbers to complete my task"
SMadsen
« Reply #5 on: November 24, 2004, 01:21:13 PM »
... and the recursive variant:
(defun cubicYards (lst)
  (cond ((= (length lst) 3)
         (mapcar 'princ (list (/ (apply '* lst) 27.0) " cubic yards")))
        ((cubicYards (cons (getdist (strcat "\nEnter "
                           (nth (length lst) '("length" "width" "height"))
                           ": ")) lst)))
hendie
« Reply #6 on: November 24, 2004, 01:29:40 PM »
Stig, what are you doing talking in old money ????
SMadsen
« Reply #7 on: November 24, 2004, 01:56:49 PM »
Old money?
As for what I'm doing, I generally have no idea :D
hendie
« Reply #8 on: November 24, 2004, 01:59:46 PM »
Quote from: SMadsen
Old money?
in the UK, when we refer to anything pre-decimal/pre-metric (i.e. feet and inches) it's referred to as "old money" like when we had £/s/d
SMadsen
« Reply #9 on: November 24, 2004, 03:12:18 PM »
Ah ok. Thanks Hendie.
... they started it!
