Have a couple commands that bring up dialog boxes here is what is happening...
Start command 'A'...brings up dialog box 'A'
Start command 'B'...brings up dialog box 'B'
Here is where it gets wonky.
Start command 'A' a second time....brings up dialog box 'B'
and everytime there after
both routines follow the same scheme...
(defun run_dialog ( / dcl_id return)
(setq dcl_id (load_dialog "H:\\Master\\LISP\\Blocking"))
(new_dialog "Blocking_dlg" dcl_id)
(action_tile "2x2" "(setq return 1.5)(done_dialog)")
(action_tile "2x4" "(setq return 3.5)(done_dialog)")
(action_tile "2x6" "(setq return 5.5)(done_dialog)")
(action_tile "2x8" "(setq return 7.5)(done_dialog)")
(action_tile "2x10" "(setq return 9.25)(done_dialog)")
(action_tile "2x12" "(setq return 11.25)(done_dialog)")
(start_dialog)
(unload_dialog dcl_id)
return
);end_defun
The other just has different values but the same general format.
Ideas anybody?
![Huh ???](http://www.theswamp.org/Smileys/black/huh.gif)
Thanks ( <---- yes se7en I said it )
