Hi,You'll find here the last M2S-2007.lsp release.It works fine with A2007 (while updating M2S for A2007 version, I discussed with Bill Gillis and brought some suggestions about SOLIDHIST sysvar managing and international syntax).IMO, M2S is no more needed with A2007: rather than extruding meshes, it's possible to slice 3d solids with lofted surfaces, extruded surfaces, etc.
;; M2S (Mesh-to-Solid);; Creates an ACIS solid from an open 3d polygon mesh.;;;; Take 4 - Updated 5/15/2006;; - Works with AutoCAD 2007 as well as all previous releases.
Quote from: gile on February 18, 2010, 02:00:40 AMHi,You'll find here the last M2S-2007.lsp release.It works fine with A2007 (while updating M2S for A2007 version, I discussed with Bill Gillis and brought some suggestions about SOLIDHIST sysvar managing and international syntax).IMO, M2S is no more needed with A2007: rather than extruding meshes, it's possible to slice 3d solids with lofted surfaces, extruded surfaces, etc.That's the version I have too gile.Works in AC2010 ok , didn't try in AC2007 Quote;; M2S (Mesh-to-Solid);; Creates an ACIS solid from an open 3d polygon mesh.;;;; Take 4 - Updated 5/15/2006;; - Works with AutoCAD 2007 as well as all previous releases.
Yes that's exactly the one I have!
QuoteYes that's exactly the one I have!It may work...Attached a modified version: which uses vla-* functions rather than (command ...) callings (faster) and have an error handling function.
Quote from: gile on February 18, 2010, 02:22:59 AMQuoteYes that's exactly the one I have!It may work...Attached a modified version: which uses vla-* functions rather than (command ...) callings (faster) and have an error handling function.Thanks!Let me try that... but, how does this one work,do I do the same as the regular lisp procedure?
Quote from: Anarchitecture on February 18, 2010, 04:09:03 AMQuote from: gile on February 18, 2010, 02:22:59 AMQuoteYes that's exactly the one I have!It may work...Attached a modified version: which uses vla-* functions rather than (command ...) callings (faster) and have an error handling function.Thanks!Let me try that... but, how does this one work,do I do the same as the regular lisp procedure?Regular LISP procedure, type 'm2s' to invoke
