Hi all,
I wrote a program like this when I was learning Visual Lisp (
http://www.cadtutor.net/forum/showpost.php?p=272082&postcount=1) and I only use it every second day so I thought it'd be a good one to learn C#.NET with. Basically it's the express command GATTE with the added option to select the layout you want. Also included is a number incrementer.
Any feeback is welcome (coding, bugs, or otherwise).
Thanks Daniel for the help, and T.Willey & Oleg (Fixo) for good examples to learn from.
Hope it works for you.
Edit: Updated Code again - just minor things
