Author Topic: the Swamp Block Library Manager?  (Read 61480 times)
Gilles
Re: the Swamp Block Library Manager?
« Reply #105 on: July 05, 2010, 12:38:39 PM »
Hello everyone.
This Blockmanager looks very interesting.
I would like to test it.
But I do not manage to launch it.
It would be appropriate to give a little instruction manual so that the largest number of non-technical users can test or use.
Thank's in advance. :grazy:
jbuzbee
« Reply #106 on: July 06, 2010, 12:27:35 PM »
Sorry guys - I don't frequent theSwamp much anymore.  The easiest way to load the file is create an acaddoc.lsp file (AutoCAD will automatically load it everytime a drawing is opened.)  Make sure that acadDoc.lsp AND the BlackManager.fas file are in AutoCAD's search path.
I've attached a simple acadDoc.lsp to get you started.
James Buzbee
Windows 8
fisherridge
« Reply #107 on: August 09, 2010, 10:18:02 PM »
jbuzbee,
I installed and ran BlockManagerv3.0 and it worked fine for a few insertions, then it stopped inserting. When I click the insert button it starts the scale command.
Command: _.insert Enter block name or [?]:
Command: _scale
Select objects: 1 0 found
Select objects:
Any ideas why?
Mike
jbuzbee
« Reply #108 on: August 10, 2010, 01:07:39 PM »
Sounds like a stray variable.  I'll take a look when I have time.
jb
James Buzbee
Windows 8
jbuzbee
« Reply #109 on: August 11, 2010, 02:34:38 PM »
I revised the insert command - should work now.
Download v4.0 on first page.
jb
James Buzbee
Windows 8
CADwiesel
  • Wir machen das Mögliche unmöglich
« Reply #110 on: March 02, 2011, 11:55:17 AM »
I got an Error while trying:
The OpenDCL arx module did not load!
I tried Acad 2006 and 2010
is it possible to fix it?
Gruß
CADwiesel
Besucht uns im CHAT
jbuzbee
« Reply #111 on: March 02, 2011, 03:26:01 PM »
CADwiesel, welcome to theSwamp.
You'll need to download the OpenDCL runtime here:
http://www.opendcl.com/download/
This project was not meant to be a finished productivity tool , but rather, a learning exercise to illustrate the GUI possibilities with OpenDCL.
Have fun!
James Buzbee
Windows 8
CADwiesel
« Reply #112 on: March 04, 2011, 04:52:29 AM »
 :oops: Yes, sorry for my stupid Question. I'd figgert this out bevore
Gruß
CADwiesel
Besucht uns im CHAT
jbuzbee
« Reply #113 on: March 04, 2011, 10:27:21 AM »
I hope I didn't come off harsh - that was not my intent.
And there are No stupid questions!!
Thinking that way won't get you very far on this site.
I can't imagine how much of an idiot CAB, Lee Mac, MP, et al think I am!!  :wink:
James Buzbee
Windows 8
« Reply #114 on: March 04, 2011, 11:21:38 AM »
Oh, not at all  :roll:
joking of course
« Reply #115 on: March 04, 2011, 11:40:52 AM »
As we mix languages, ACAD versions, programing levels and personalities it is easy to miss interpret
messages and intent.
As James said there are no Stupid Question here just misunderstanding's.   :-)
77077
« Reply #116 on: September 28, 2014, 08:33:12 PM »
Good topics! but some rontine need install Odcl.
« Reply #117 on: September 28, 2014, 08:41:00 PM »
Yes, that is mentioned in the original post.
http://opendcl.com/wordpress/
