Author Topic: Help with vla-get-startpoint  (Read 3505 times)
ozimad
« on: February 08, 2010, 07:07:56 AM »
Hi can somebody helpme with getting startpoint:
Command: ; error: bad argument type: VLA-OBJECT 2127010984 - this is the error
    (setq temp (ssget "l")) ;;;iselect blocj
    (command "_.explode" temp) ;;;i explode it
    (setq temp1 (entlast)) ;;get the line out of block
    (setq objid1 (vla-get-objectid (vlax-ename->vla-object temp1)))
    (setq stpt (vlax-SafeArray->List (vlax-Variant-Value (vla-Get-StartPoint objid1))))
    (print stpt)
    (command "_.erase" temp1 "")
many thanks!
gile
  • Marseille, France
Re: Help with vla-get-startpoint
« Reply #1 on: February 08, 2010, 07:23:21 AM »
The argument requiered by vla-get-StartPoint have to be a vla-object type, not an ObjectId
« Reply #2 on: February 08, 2010, 02:43:19 PM »
Also, you can avoid dealing with variants by using:
(vlax-get obj 'StartPoint)
 :wink:
« Reply #3 on: February 08, 2010, 03:08:05 PM »
One more:
(vlax-curve-getstartpoint curve-obj)
« Reply #4 on: February 08, 2010, 03:20:25 PM »
More cat skinning ( just 'cuz I was in the mood )  :-D :ugly:
    (lambda ( x )
        (vlax-curve-getPointAtParam
            x
            (vlax-curve-getStartParam x)
    (car (entsel))
« Reply #5 on: February 08, 2010, 03:26:18 PM »
Curve functions are the way to go - much quicker with Enames and no need to convert to vla-object...  8-)
