Author Topic: Block library  (Read 7981 times)
Atwist
Block library
« on: February 06, 2010, 11:10:57 AM »
Hello,
Am need a simple block library, I have looking here on this site can somebody my gif a tip
Aerdvark
Re: Block library
« Reply #1 on: February 06, 2010, 11:51:16 AM »
I believe what you need is a toolpalette for your blocks.
Atwist
Re: Block library
« Reply #2 on: February 06, 2010, 12:06:43 PM »
Hello Aerdvark,
Toolpalette is no option I have too Mani blocks
GDF
Re: Block library
« Reply #3 on: February 06, 2010, 01:51:27 PM »
Here is one way...
Atwist
Re: Block library
« Reply #4 on: February 07, 2010, 02:34:41 AM »
Hello GDF,
That looks ferry nice  :lol: where can I download a demo.
Atwist
wwhittle
Re: Block library
« Reply #5 on: February 07, 2010, 08:25:23 AM »
AutoCAD's design centre works quite well?
rhino
Re: Block library
« Reply #6 on: February 07, 2010, 11:51:49 AM »
Welcome to the Swamp...
have u tried the code posted here:
http://web2.airmail.net/terrycad/AutoLISP-Code.htm
look for  blk_lib
Atwist
Re: Block library
« Reply #7 on: February 07, 2010, 12:45:52 PM »
Hello Rhino,
Thanks for the Tipp, Il knew this wan.
But that is noting for me.
Atwist
rhino
Re: Block library
« Reply #8 on: February 07, 2010, 01:09:45 PM »
Hello Rhino,
Atwist
umm so what are you looking for?
standard blocks?
GDF
Re: Block library
« Reply #9 on: February 07, 2010, 01:41:01 PM »
Hello GDF,
Atwist
I use a modified version of:
;;; Original concept by Lintang Darudjati
;;; HotBlocks
;;; A block manager with INI style customization file and a dialog box performing collection-grouping,
;;; file path display, and slide previews as 'hot thumbnails'. Build your own dwg block library with it.
;;; And make them ready to be inserted easily anytime.
;;; http://www.geocities.com/RainForest/1073/download.html
t-bear
Re: Block library
« Reply #10 on: February 08, 2010, 09:30:52 AM »
We use the Symbol Manager in Dotsoft's ToolPac  http://www.dotsoft.com/.  Have been using it for 4 years now with no problems. It's simple to set up and use, fully expandable, works as a stand-alone or network app.  I recommend it highly.  No affiliation or kick-backs here, just a happy customer.
Atwist
Re: Block library
« Reply #11 on: February 08, 2010, 01:14:18 PM »
Hello GDF,
Your make this program?? :lol:
Its looks so professional.
I am engineer an not a programmer.
For me is this not a option to make it by me self. :cry:
Atwist
GDF
Re: Block library
« Reply #12 on: February 08, 2010, 02:07:13 PM »
Hello GDF,
Atwist
Yes, and I am an architect not a programmer. I mainly snip here and edit there. I roll my own dcl and can do simple lsp code. I get a lot of help from other swampers here.
