Author Topic: Underlined Mtext  (Read 8983 times)
MeasureUp
Re: Underlined Mtext
« Reply #15 on: February 04, 2010, 11:27:34 PM »
Origenally, I want to write underlined MTEXT by using AutoLisp.
Thanks again.
(defun c:test (/ M-Text pt str)
  (defun M-Text (pt val)
    (entmakex (list (cons 0 "MTEXT")
                    (cons 100 "AcDbEntity")
                    (cons 100 "AcDbMText")
                    (cons 10 pt)
                    [color=red](cons 7 "ROMANS")[/color]
                    (cons 1 val))))
  (if (setq pt (getpoint "\nSpecify Point: "))
      (setq str (getstring t "\nSpecify Text: "))
      (M-Text pt (strcat "{\\L" str "}"))))
  (princ))
Thank you very much.
By learning your code, I read DXF section in the HELP & add a line the your code allowing to change the text style.  :-)
« Reply #16 on: February 04, 2010, 11:45:21 PM »
good job.
You can also set the layer and if needed the color override.
Do you see which DXF codes do that?
« Reply #17 on: February 05, 2010, 11:49:47 AM »
MeasureUp
« Reply #18 on: February 05, 2010, 10:27:25 PM »
good job.
Not sure if the following correct:
                    (cons 10 pt)
                    (cons 7 "ROMANS")
                    (cons 1 val))
    ); end of entmakex
    [color=red](entmakex (list (cons 0 "LAYER")
  (cons 2 "Layer_Mtext")) ; set mtext's layer to "Layer_Mtext" if it exists.
    ); end of entmakex[/color]
Thanks.
MeasureUp
« Reply #19 on: February 05, 2010, 10:29:48 PM »
Nice one  :-)
This may help you  :-)
http://autodesk.com/techpubs/autocad/acad2000/dxf/
Thanks for the link.
PS. Is there a 2010 version available in autodesk's web?
I can find it there.
« Reply #20 on: February 05, 2010, 11:18:08 PM »
Not quite. The benefit of using entmake is that if the layer does not exist it will create it without your help.
Try this:
                    (cons 10 pt)
                    (cons 7 "ROMANS")
                    (cons 8 "Layer_Mtext")
                    (cons 1 val))
    ); end of entmakex
« Reply #21 on: February 05, 2010, 11:30:32 PM »
Try this :-
http://images.autodesk.com/adsk/files/acad_dxf1.pdf
MeasureUp
« Reply #22 on: February 06, 2010, 01:21:25 AM »
Try this:
                    (cons 10 pt)
                    (cons 7 "ROMANS")
                    (cons 1 val))
    ); end of entmakex
Sorry, I confuse with the DXF group codes.
I use the (cons 2 "Layer_Mtext") because I found "2" under the layer section.
MeasureUp
« Reply #23 on: February 06, 2010, 01:28:56 AM »
Try this :-
Thanks for your help. I opened the file.
I am trying to get more resources from Autodesk web.
I did a search again but can't find a page in the Autodesk web showing the entry to the DXF Reference file.
Can you show me the page?
Thanks again.
« Reply #24 on: February 06, 2010, 02:09:49 AM »
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2882295&linkID=9240617
Have you tried your local Help files ?  :-
C:\Program Files\Autodesk\ACAD 2010\Help\acad_dxf.chm
« Reply #25 on: February 06, 2010, 07:12:49 AM »
« Reply #26 on: February 06, 2010, 08:39:27 AM »
Try this:
                    (cons 10 pt)
                    (cons 7 "ROMANS")
                    (cons 1 val))
    ); end of entmakex
When aiming to modify/set the properties for an entity, just look at the entity dxf group codes - these are all that you need. The layer dxf codes would be used to create/modify a layer.
MeasureUp
« Reply #27 on: February 08, 2010, 06:23:31 PM »
Thanks.
Yes, I know the local built in one but was thinking it would be helpful if there is one in pdf form.
MeasureUp
« Reply #28 on: February 08, 2010, 06:26:17 PM »
Don't forget to visit this thread:
http://www.theswamp.org/index.php?topic=24700.msg359343#msg359343
You are the biggggggg man.
Thanks for the useful/helpful resources.
MeasureUp
« Reply #29 on: February 08, 2010, 06:29:02 PM »
Thanks. you are right.
