Author Topic: dimension color question  (Read 1786 times)
ELOQUINTET
« on: November 22, 2004, 10:39:25 AM »
hey guys i was wondering do any of you use different colors for your text and dimension lines in your dim styles. i always did them as one color but some people here want to text to be another color so it's easier to read. the problem i'm having is when i do match properties sometime it makes the text bylayer and other times the color specified in text color. why does it do this any suggestions of a better way?
« Reply #1 on: November 22, 2004, 11:13:47 AM »
Have you tried filtering all dimensions and changing the text color in the properties box?
ELOQUINTET
« Reply #2 on: November 22, 2004, 11:46:39 AM »
no but my question really is is there a better way of doing this. i am considering just using a bolder font for dimension text insted of another color. my goal is to not have to fix it just lookin for ideas
CADaver
« Reply #3 on: November 22, 2004, 02:03:26 PM »
Text colot is defined in the dimstyle.  Edit the dimstyle and all dims using that style should update.
It can be over-ridden using DIMTCLR.
