Author Topic: Copyblock2 question...  (Read 2245 times)
hudster
« on: November 22, 2004, 09:17:47 AM »
I'm using the copyblock2 lisp routing to rename some anonymous blocks with * as the first character.
I've set up the following macro for quick use.
^C^Ccopyblock2;\\;ins;\
How do I change this macro so that the name of the block could be the existing name, minus the first character?
Or is there a lisp routine that would allow me to do this?
« Reply #1 on: November 22, 2004, 11:19:47 AM »
This code wikk skip the 'New name' prompt if the name starts with *
;make a copy of a block with a new name
;select block to copy
;enter new name unless anonymous block, then new name = ols name less *
;pick insertion point
(defun C:CopyBlock3 (/ *error* OldBlockName NewBlockName
    rewind BlockName Info BlockInfo ent_name ent_info)
(defun *error* (Msg)
  ((or (not Msg)
       (member Msg '("console break"
                     "Function cancelled"
                     "quit / exit abort"))))
  ((princ (strcat "\nError: " Msg)))
 ) ;cond
) ;end error
  (sssetfirst)
  (setq OldBlockName (entsel "\nSelect Block to copy: "))
  (while
    (or
      (null OldBlockName)
      (/= "INSERT" (cdr (assoc 0 (entget (car OldBlockName)))))
     (princ "\nSelection was not a block - try again...")
;block name
  (setq OldBlockName (strcase (cdr (assoc 2 (entget (car OldBlockName))))))
  (princ (strcat "\nSelected block name: " OldBlockName))
  (if (= "*" (substr OldBlockName 1 1))
     (setq NewBlockName (substr OldBlockName 2))
     (setq NewBlockName (getstring T "\nEnter new block name: "))
  (setq rewind T)
  (while (setq Info (tblnext "BLOCK" rewind))
    (setq BlockName (strcase (cdr (assoc 2 Info))))
    (if (= OldBlockName BlockName)
      (setq BlockInfo Info)
    (setq rewind nil)
  (if BlockInfo
      (setq ent_name (cdr (assoc -2 BlockInfo)))
;header definition:
      (entmake (list '(0 . "BLOCK")
      (cons 2 NewBlockName)
     '(70 . 2)
      (cons 10 '(0 0 0))
;body definition:
      (entmake (cdr (entget ent_name)))
      (while (setq ent_name (entnext ent_name))
 (setq ent_info (cdr (entget ent_name)))
 (entmake ent_info)
;footer definition:
      (entmake '((0 . "ENDBLK")))
     (command "-INSERT" NewBlockName pause "1" "1" "0")
 (*Error* nil)
) ;end
