Author Topic: LMS Tech  (Read 9326 times)
Lerner
LMS Tech
« on: January 29, 2010, 09:28:27 AM »
Does anyone know what the "(LMS Tech)" means in the AutoCAD version number?
Re: LMS Tech
« Reply #1 on: January 29, 2010, 09:52:47 AM »
Could not find an answer yet. Wild guess unregistered version
Rob...
Re: LMS Tech
« Reply #2 on: January 29, 2010, 10:02:48 AM »
CAB may be correct. This might help: http://www.cadforums.net/ftopic375.html
CAD Tech
David Hall
  • Automatic Duh Generator
Re: LMS Tech
« Reply #3 on: January 29, 2010, 10:28:07 AM »
I think it is for License Manged System, as mine kicks back 18.0s (LMS Tech) and I have a registered version.
David Hall
Re: LMS Tech
« Reply #4 on: January 29, 2010, 10:29:20 AM »
I forgot to say, registered Network License version.
Lerner
Re: LMS Tech
« Reply #5 on: January 29, 2010, 10:47:51 AM »
Well if that's not it CmdrDuh it's a good guess. Not sure why they say 'tech' though.
Re: LMS Tech
« Reply #6 on: January 29, 2010, 10:58:25 AM »
My non registered version of 2006 returns "16.2s (LMS Tech)"
Lerner
Re: LMS Tech
« Reply #7 on: January 29, 2010, 11:11:18 AM »
I managed to find this list so it looks like it started appearing with version 2004:
18.0 (LMS Tech) = AutoCAD 2010
17.2 (LMS Tech) = AutoCAD 2009
17.1 (LMS Tech) = AutoCAD 2008
17.0 (LMS Tech) = AutoCAD 2007
16.2 (LMS Tech) = AutoCAD 2006
16.1 (LMS Tech) = AutoCAD 2005
16.0 (LMS Tech) = AutoCAD 2004
15.2 = AutoCAD 2002
15.1 = AutoCAD 2000i
15.0 = AutoCAD 2000
14.0 = AutoCAD R14
Which leads to another question. What is the 's' after the number in some versions?
Re: LMS Tech
« Reply #8 on: January 29, 2010, 11:29:57 AM »
You ask too many questions!  :-D
My 2006 is a "Not for resale" version.
My 2004 returns this "16.0"  it is registered & a standard version.
HTH 8-)
Lerner
Re: LMS Tech
« Reply #9 on: January 29, 2010, 11:38:59 AM »
Here's another list I found in the file sysvdlg.dat in the Express directory:
18.0s (LMS Tech) = AutoCAD 2010
17.2s (LMS Tech) = AutoCAD 2009
17.1s (LMS Tech) = AutoCAD 2008
17.0s (LMS Tech) = AutoCAD 2007
16.2s (LMS Tech) = AutoCAD 2006
16.1s (LMS Tech) = AutoCAD 2005
16.0 = AutoCAD 2004
15.06 = AutoCAD 2002
15.05 = AutoCAD 2000i
Which differs slightly in the earlier versions from the list above that I found on the web. This one seems to be more accurate. And it looks like the 's' started appearing at the same time as the (LMS Tech).
« Last Edit: January 29, 2010, 11:51:19 AM by Lerner »
Lerner
Re: LMS Tech
« Reply #10 on: January 29, 2010, 12:12:22 PM »
Ok well that's just the data file for the Express Tool SYSVDLG which is a system variable dialog viewer. You can see that list by running the program and looking under ACADVER.
JCTER
Re: LMS Tech
« Reply #11 on: January 29, 2010, 12:14:09 PM »
Command: acadver
ACADVER = "18.0s (LMS Tech)" (read only)
but all this discussion begs the question... why would you?
Lerner
Re: LMS Tech
« Reply #12 on: January 29, 2010, 12:51:21 PM »
I was just hoping that would shed some light on LMS Tech. If someone can think of some other change that occurred around the 2004/2005 version that might indicate what it means.
