Author Topic: .NET MISCELLANEOUS/GENERAL Routines  (Read 51507 times)
Dashmonkey
  • (defun sleep nil nil)
Re: .NET MISCELLANEOUS/GENERAL Routines
« Reply #45 on: July 20, 2015, 04:41:53 PM »
Gile, I'm loving your AcadReg class! It's SUPER slick and I learned a lot from looking at it. Thanks for posting :D
I didn't break it, I swear! ...ok, I broke it.
Keith Brown
« Reply #46 on: August 12, 2015, 02:42:18 PM »
Hi Gile,
In some of your methods in the Registry Classes I had to change your OpenSubKey calls to open with ReadWrite status.  For instance in the AddPath method of the ProfileKey class I changed
Code - C#: [Select]
  1. using (var rkey= Registry.CurrentUser.OpenSubKey(key))
to
Code - C#: [Select]
  1. using (var rkey= Registry.CurrentUser.OpenSubKey(key, true))
I had to do this in several places where the value of the key was being modified.  Not sure if that was because of my permissions or something else.  I think that you are also missing the servicePack private string variable in the ProductKey class.  Other than that it worked great for me when installing a dll.
nobody
  • .net stuff
« Reply #47 on: August 12, 2015, 09:28:38 PM »
Toggles extension line for aligned dimension...doesn't account for exact middle pick but found it's never been a problem:
Code - C#: [Select]
  1.         [CommandMethod("TOGE")]
  2.         public static void RemoveAddExtensions()
  3.         {
  4.             CivilDocument CivDoc = Autodesk.Civil.ApplicationServices.CivilApplication.ActiveDocument;
  5.             Document AcadDoc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
  6.             Editor MyEditor = Application.DocumentManager.MdiActiveDocument.Editor;
  7.             Database MyDatabase = HostApplicationServices.WorkingDatabase;
  8.
  9.             using (DocumentLock acLckDoc = AcadDoc.LockDocument())
  10.             {
  11.                 using (Transaction MyTrans = MyDatabase.TransactionManager.StartTransaction())
  12.                 {
  13.                     try
  14.                     {
  15.                         ObjectId mydimoid = promptfordim("\nSelect Dimension: ");
  16.                         AlignedDimension mydim = (AlignedDimension)MyTrans.GetObject(mydimoid, OpenMode.ForRead);
  17.                         Point3d mypoint = GetMyPoint("\nSelect Point Near Extension: ");
  18.                         mydim.UpgradeOpen();
  19.
  20.                         if ((mypoint.DistanceTo(mydim.XLine1Point)) < (mypoint.DistanceTo(mydim.XLine2Point)))
  21.                         {
  22.                             if (mydim.Dimse1 == true)
  23.                             {
  24.                                 mydim.Dimse1 = false;
  25.                             }
  26.                             else
  27.                             {
  28.                                 mydim.Dimse1 = true;
  29.                             }
  30.                         }
  31.                         else
  32.                         {
  33.                             if (mydim.Dimse2 == true)
  34.                             {
  35.                                 mydim.Dimse2 = false;
  36.                             }
  37.                             else
  38.                             {
  39.                                 mydim.Dimse2 = true;
  40.                             }
  41.                         }
  42.                         mydim.DowngradeOpen();
  43.                     }
  44.                     catch (System.Exception ex)
  45.                     {
  46.                         MyEditor.WriteMessage("Error: ==>\n{0}\nTrace: ==>\n{1}", ex.Message, ex.StackTrace);
  47.                     }
  48.                     MyTrans.Commit();
  49.                 }
  50.             }
  51.         }[code]
gile
  • Marseille, France
« Reply #48 on: August 14, 2015, 04:09:21 AM »
Hi Gile,
Code - C#: [Select]
to
Code - C#: [Select]
Many thanks for reporting Keith.
I corrected the posted code.
RICVBA
« Reply #49 on: August 23, 2015, 03:19:06 AM »
Nice idea kaefer (as usual).
If I have some time, I'd add some WriteRange() method to the ExcelWriter class.
Hi Everybody
I'm a rather discontinuos learner of C# and NET, with the main purpose of Autocad Automation and its Excel connection
These days, I peeped in this thread to try and learn "true life" coding and state-of-the-art "how to"'s,
While learning a lot (and realizing there's a very lot more to - probably too much!), I assumed it could be a useful exercise to make some add-on and see what I actually grasped of it
so I'm attacching a LateBinding solution "ExcelReader" class with minor modifications to let you deal with Excel data written in and read from ranges not beginning at cell (1,1)
In detail, I modifed the following ExcelReader methods:
- ExcelReader main constructor
- SetActiveSheet()
- Peak()
- NewLine()
- Read() (the main method)
- ReadLine() (the main method)
- ReadRange() (both methods)
- RangeToDataTable() (both methods)
all modifications are clearly marked and I also mantained (commented) the corresponding original code lines
to test it I slightly modified Gile's using example as follows:
Using Example:
class Program
        static void Main(string[] args)
            using (ExcelWriter xlw = new ExcelWriter(@"C:\Users\Riccardo\Documents\Cartel2.xlsx"))
                xlw.Clear();
                xlw.WriteLine(new object[3] { "foo", "bar", "baz" }, 3, 2); //<------ modified by RICVBA to have a usedrange not beginning at cells(1,1)
                xlw.WriteLine(new object[3] { 1, 2, 3 }, 4, 3);             //<------ modified by RICVBA to have a usedrange not beginning at cells(1,1)
                xlw.Save();
            using (ExcelReader xlr = new ExcelReader(@"C:\Users\Riccardo\Documents\Cartel2.xlsx"))
                while (!xlr.StreamEnded)
                    foreach (object obj in xlr.ReadLine())
                        Console.Write("{0} ", obj);
                    Console.WriteLine();
                //added by RICVBA to test some methods after ExcelReader class modifications
                wl(xlr.ReadToEnd()); // should work as it was
                wl(xlr.ReadRange(2, 1)); // modified
            Console.ReadLine();
        //added by RICVBA
        static void wl(object[,] range)
            for (int i = 0; i < range.GetLength(0); i++)
                for (int j = 0; j < range.GetLength(1); j++)
                    Console.Write("{0} ", range[i, j]);
as per my tests, it worked.
if confirmed, same modifications for Dynamic solution's same class should be straightforward
If anybody interested in giving feedbacks, please do.
thank you
gile
  • Marseille, France
« Reply #50 on: October 01, 2015, 02:36:38 PM »
I updated the code of AutocadRegistryServices to handle the reversed values of PatchTitle and ProductName in the registry with AutoCAD 2016 SP1.
gile
  • Marseille, France
« Reply #51 on: March 10, 2017, 05:09:40 PM »
Some extension methods to perform different kinds of zoom.
Code - C#: [Select]
  1. using Autodesk.AutoCAD.ApplicationServices;
  2. using Autodesk.AutoCAD.DatabaseServices;
  3. using Autodesk.AutoCAD.Geometry;
  4. using Autodesk.AutoCAD.Runtime;
  5. using System;
  6. using System.Collections.Generic;
  7. using System.Linq;
  8.
  9. namespace Autodesk.AutoCAD.EditorInput
  10. {
  11.     public static class ExtensionMethods
  12.     {
  13.         public static Matrix3d EyeToWorld(this ViewTableRecord view)
  14.         {
  15.             if (view == null)
  16.                 throw new ArgumentNullException("view");
  17.
  18.             return
  19.                 Matrix3d.Rotation(-view.ViewTwist, view.ViewDirection, view.Target) *
  20.                 Matrix3d.Displacement(view.Target - Point3d.Origin) *
  21.                 Matrix3d.PlaneToWorld(view.ViewDirection);
  22.         }
  23.
  24.         public static Matrix3d WorldToEye(this ViewTableRecord view)
  25.         {
  26.             return view.EyeToWorld().Inverse();
  27.         }
  28.
  29.         public static void Zoom(this Editor ed, Extents3d ext)
  30.         {
  31.             if (ed == null)
  32.                 throw new ArgumentNullException("ed");
  33.
  34.             using (ViewTableRecord view = ed.GetCurrentView())
  35.             {
  36.                 ext.TransformBy(view.WorldToEye());
  37.                 view.Width = ext.MaxPoint.X - ext.MinPoint.X;
  38.                 view.Height = ext.MaxPoint.Y - ext.MinPoint.Y;
  39.                 view.CenterPoint = new Point2d(
  40.                     (ext.MaxPoint.X + ext.MinPoint.X) / 2.0,
  41.                     (ext.MaxPoint.Y + ext.MinPoint.Y) / 2.0);
  42.                 ed.SetCurrentView(view);
  43.             }
  44.         }
  45.
  46.         public static void ZoomExtents(this Editor ed)
  47.         {
  48.             if (ed == null)
  49.                 throw new ArgumentNullException("ed");
  50.
  51.             Database db = ed.Document.Database;
  52.             db.UpdateExt(false);
  53.             Extents3d ext = (short)Application.GetSystemVariable("cvport") == 1 ?
  54.                 new Extents3d(db.Pextmin, db.Pextmax) :
  55.                 new Extents3d(db.Extmin, db.Extmax);
  56.             ed.Zoom(ext);
  57.         }
  58.
  59.         public static void ZoomWindow(this Editor ed, Point3d p1, Point3d p2)
  60.         {
  61.             using (Line line = new Line(p1, p2))
  62.             {
  63.                 ed.Zoom(line.GeometricExtents);
  64.             }
  65.         }
  66.
  67.         public static void ZoomScale(this Editor ed, double scale)
  68.         {
  69.             if (ed == null)
  70.                 throw new ArgumentNullException("ed");
  71.
  72.             using (ViewTableRecord view = ed.GetCurrentView())
  73.             {
  74.                 view.Width /= scale;
  75.                 view.Height /= scale;
  76.                 ed.SetCurrentView(view);
  77.             }
  78.         }
  79.
  80.         public static void ZoomObjects(this Editor ed, IEnumerable<ObjectId> ids)
  81.         {
  82.             if (ed == null)
  83.                 throw new ArgumentNullException("ed");
  84.
  85.             using (Transaction tr = ed.Document.TransactionManager.StartTransaction())
  86.             {
  87.                 Extents3d ext = ids
  88.                     .Where(id => id.ObjectClass.IsDerivedFrom(RXObject.GetClass(typeof(Entity))))
  89.                     .Select(id => ((Entity)tr.GetObject(id, OpenMode.ForRead)).GeometricExtents)
  90.                     .Aggregate((e1, e2) => { e1.AddExtents(e2); return e1; });
  91.                 ed.Zoom(ext);
  92.                 tr.Commit();
  93.             }
  94.         }
  95.
  96.         public static void ZoomCenter(this Editor ed, Point3d center, double scale = 1.0)
  97.         {
  98.             if (ed == null)
  99.                 throw new ArgumentNullException("ed");
  100.
  101.             using (ViewTableRecord view = ed.GetCurrentView())
  102.             {
  103.                 center = center.TransformBy(view.WorldToEye());
  104.                 view.Height /= scale;
  105.                 view.Width /= scale;
  106.                 view.CenterPoint = new Point2d(center.X, center.Y);
  107.                 ed.SetCurrentView(view);
  108.             }
  109.         }
  110.     }
  111. }
  112.
« Last Edit: July 01, 2017, 02:00:10 AM by gile »
Keith Brown
« Reply #52 on: March 16, 2017, 02:00:12 PM »
Hi Gile,
Nice code but you might want to wrap your max minus min functions in an absolute value call before passing to the width and height of the view.  Autocad seems to handle it fine with out the absolute function call but Bricscad will throw an exception when both points are in negative territory.  Autocad must be automatically taking the absolute value of the width and height where Teigha (bricscad) is not.
gile
  • Marseille, France
« Reply #53 on: February 13, 2022, 11:54:00 AM »
I created a repo on GitHub with my most used general extension methods.
I have to thank all the Swampers who provided help and/or ideas to build this library (TheMaster, kaefer, kbub, Jeff H, CADbloke, Jeff_M, Keith Brown, T.Willey, Luis Esquivel, n.yuan, It's Alive!, JohnK, pkohut, Alexander Rivilis...).
« Last Edit: February 13, 2022, 02:33:11 PM by gile »
alexisgacia
  • Mosquito
« Reply #54 on: February 14, 2022, 06:48:24 AM »
I tried the purgeall of chuck gabriel but I was having problem when I apply it to multiple files. I'm still learning the autocad in C# and wanted to create a batch process of purging and cleaning of annotation scale or resetting.
Using the Chuck Code I was able to clean the drawing but some files show the layer that previously hidden. And when I try to reset the annotation scale, some objects start to appear in the layout.
Below the sample design that I tested.
        public void PurgeFiles()
            Editor ed = doc.Editor;
            List<ProcessReport> ListOfCleanFiles = new List<ProcessReport>();
            PromptResult pr = ed.GetString("\nEnter folder containing DWGs to process: ");
            if (pr.Status != PromptStatus.OK) return;
            string pathName = pr.StringResult;
            string mReportFileName = pathName + @"\ReportLog.html";
            mReportFileName = mReportFileName.Replace("\\", @"\");
            string[] fileNames = Directory.GetFiles(pathName, "*.dwg");
            // We'll use some counters to keep track
            // of how the processing is going
            int processed = 0, saved = 0, problem = 0;
            DateTime Time_ProcessStart = DateTime.Now;
            foreach (string fileName in fileNames)
                ProcessReport DwgInfo = new ProcessReport();
                if (fileName.EndsWith(".dwg", StringComparison.CurrentCultureIgnoreCase))
                    string outputName = fileName;
                    System.Diagnostics.Debug.Print(outputName + DateTime.Now.ToString());
                    Database db = new Database(false, true);
                    using (db)
                        try
                            // Purging
                            cPurge.purgeAll(db, true);
                            // Reset Annotation Scale (Not Working)
                            doc.SendStringToExecute(@"(command ""_-SCALELISTEDIT"" ""_R"" ""_Y"" ""_D"" ""*"" ""_E"") ", false, false, false);
                            db.CloseInput(true);
                            //(command ""-purge"" ""a"" ""*"" ""n"" )
                            ed.WriteMessage("\nProblem processing file: {0} - \"{1}\"", fileName, ex.Message);
                            problem++;
CADbloke
  • Crash Test Dummy
« Reply #55 on: February 14, 2022, 08:27:52 PM »
Thanks for sharing this Giles. Have you seen also https://github.com/wtertinek/Linq2Acad ?
gile
  • Marseille, France
« Reply #56 on: February 15, 2022, 01:52:02 AM »
Thanks CADbloke. this one seems really very interesting.
gile
  • Marseille, France
« Reply #57 on: February 20, 2022, 02:38:58 AM »
Two new repos on GitHub: C# and F# editable project templates for Visual Studio.
AutoCAD-Csharp-Project-Template
AutoCAD-Fsharp-Project-Template
