/// <summary>
/// Gets the hatch loops data for the supplied region.
/// </summary>
/// <param name="region">The instance to which this method applies.</param>
/// <returns>A collection of tuples containing the loop data.</returns>
public static IEnumerable<(HatchLoopTypes, Curve2dCollection, IntegerCollection)> GetHatchLoops(this Region region)
var plane
= new Plane
(Point3d
.Origin, region
.Normal);
using (var brep
= new Brep
(region
foreach (var complex in brep.Complexes)
foreach (var loop in complex.Shells.First().Faces.First().Loops)
var edgePtrCollection
= new Curve2dCollection
(); var edgeTypeCollection
= new IntegerCollection
(); foreach (var edge in loop.Edges.Select(e => ((ExternalCurve3d)e.Curve).NativeCurve).ToOrderedArray())
switch (edge)
case LineSegment3d lineSegment3D:
edgePtrCollection.Add(
lineSegment3D.StartPoint.Convert2d(plane),
lineSegment3D.EndPoint.Convert2d(plane)));
edgeTypeCollection.Add(1);
break;
case CircularArc3d circularArc3D:
circularArc3D.Center.Convert2d(plane),
circularArc3D.Radius,
circularArc3D.StartAngle,
circularArc3D.EndAngle,
circularArc3D.ReferenceVector.Convert2d(plane),
false));
edgeTypeCollection.Add(2);
break;
case EllipticalArc3d ellipticalArc3D:
ellipticalArc3D.Center.Convert2d(plane),
ellipticalArc3D.MajorAxis.Convert2d(plane),
ellipticalArc3D.MinorAxis.Convert2d(plane),
ellipticalArc3D.MajorRadius,
ellipticalArc3D.MinorRadius,
ellipticalArc3D.StartAngle,
ellipticalArc3D.EndAngle));
edgeTypeCollection.Add(3);
break;
case NurbCurve3d nurbCurve3D:
var ctrlPts
= new Point2dCollection
(); for (int i = 0; i < nurbCurve3D.NumberOfControlPoints; i++)
ctrlPts.Add(nurbCurve3D.ControlPointAt(i).Convert2d(plane));
nurbCurve3D.Degree,
nurbCurve3D.Knots,
ctrlPts,
nurbCurve3D.IsPeriodic(out double _)));
edgeTypeCollection.Add(4);
break;
default:
break;
if (loop.LoopType == LoopType.LoopExterior)
yield return (HatchLoopTypes.External, edgePtrCollection, edgeTypeCollection);
else
yield return (HatchLoopTypes.Default, edgePtrCollection, edgeTypeCollection);
