Author Topic: .NET GEOMETRY Routines  (Read 67556 times)
gile
  • Marseille, France
Re: .NET GEOMETRY Routines
« Reply #15 on: April 19, 2011, 01:16:01 PM »
Thanks, Oleg. You're very welcome.
gile
  • Marseille, France
« Reply #16 on: April 25, 2011, 01:55:10 PM »
A new C# implementation of the ConvexHull using Linq (.NET Framework 3 or upper)
Code - C#: [Select]
  1. using System;
  2. using System.Collections.Generic;
  3. using System.Linq;
  4. using Autodesk.AutoCAD.ApplicationServices;
  5. using Autodesk.AutoCAD.DatabaseServices;
  6. using Autodesk.AutoCAD.EditorInput;
  7. using Autodesk.AutoCAD.Geometry;
  8. using Autodesk.AutoCAD.Runtime;
  9. using AcAp = Autodesk.AutoCAD.ApplicationServices.Application;
  10.
  11. namespace LinqConvexHull
  12. {
  13.     public class Commands
  14.     {
  15.         private Point2d _p0;
  16.
  17.         private bool Clockwise(Point2d p1, Point2d p2, Point2d p3)
  18.         {
  19.             return ((p2.X - p1.X) * (p3.Y - p1.Y) - (p2.Y - p1.Y) * (p3.X - p1.X)) < 1e-9;
  20.         }
  21.
  22.         private double Cosine(Point2d pt)
  23.         {
  24.             double d = _p0.GetDistanceTo(pt);
  25.             return d == 0.0 ? 1.0 : Math.Round((pt.X - _p0.X) / d, 9);
  26.         }
  27.
  28.         private List<Point2d> ConvexHull(List<Point2d> pts)
  29.         {
  30.             _p0 = pts.OrderBy(p => p.Y).ThenBy(p => p.X).First();
  31.             pts = pts.OrderByDescending(p => Cosine(p)).ThenBy(p => _p0.GetDistanceTo(p)).ToList();
  32.             for (int i = 1; i < pts.Count - 1; i++)
  33.             {
  34.                 while (i > 0 && Clockwise(pts[i - 1], pts[i], pts[i + 1]))
  35.                 {
  36.                     pts.RemoveAt(i);
  37.                     i--;
  38.                 }
  39.             }
  40.             return pts;
  41.         }
  42.
  43.         [CommandMethod("Test")]
  44.         public void Test()
  45.         {
  46.             Document doc = AcAp.DocumentManager.MdiActiveDocument;
  47.             Database db = doc.Database;
  48.             Editor ed = doc.Editor;
  49.             TypedValue[] filter = new TypedValue[1] { new TypedValue(0, "POINT") };
  50.             PromptSelectionResult psr = ed.GetSelection(new SelectionFilter(filter));
  51.             if (psr.Status != PromptStatus.OK) return;
  52.             using (Transaction tr = db.TransactionManager.StartTransaction())
  53.             using (Polyline pline = new Polyline())
  54.             {
  55.                 List<Point2d> pts = new List<Point2d>();
  56.                 foreach (SelectedObject so in psr.Value)
  57.                 {
  58.                     DBPoint dbPt = (DBPoint)tr.GetObject(so.ObjectId, OpenMode.ForRead);
  59.                     pts.Add(new Point2d(dbPt.Position.X, dbPt.Position.Y));
  60.                 }
  61.                 pts = ConvexHull(pts);
  62.                 for (int i = 0; i < pts.Count; i++)
  63.                 {
  64.                     pline.AddVertexAt(i, pts[i], 0.0, 0.0, 0.0);
  65.                 }
  66.                 pline.Closed = true;
  67.                 pline.SetDatabaseDefaults();
  68.                 BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
  69.                 btr.AppendEntity(pline);
  70.                 tr.AddNewlyCreatedDBObject(pline, true);
  71.                 tr.Commit();
  72.             }
  73.         }
  74.     }
  75. }
  76.
« Last Edit: October 20, 2020, 01:13:28 AM by gile »
gile
  • Marseille, France
« Reply #17 on: July 10, 2011, 10:41:46 AM »
I made a minor update in GeometryExtensions and I added comments to create a documentation file using Sandcastle Help File Builder.
The GeomExtDoc.chm is downloadable from the reply #2.
qjchen
  • Best wishes to all
« Reply #18 on: July 13, 2011, 09:41:50 AM »
Gile, Thank you your great library, I will learn a lot from it~
And this code about convex hull which using Linq is so concise, very cool~
« Last Edit: July 13, 2011, 10:11:29 AM by qjchen »
http://qjchen.mjtd.com
kaefer
« Reply #19 on: July 13, 2011, 10:39:07 AM »
I can only second that. Merci beaucoup!
Alas, there was a minor snag in appropriating your intellectual property: The paper space transformations are extension methods to Editor, whereas I needed them for Viewport to replicate the CHSPACE command. Any chance to make them more generic?
type Viewport with
    member vp.DCS2PSDCS =
        Matrix3d.Scaling(vp.CustomScale, vp.CenterPoint) *
        Matrix3d.Displacement(vp.CenterPoint - Point3d.Origin) *
        Matrix3d.Displacement(Point3d.Origin - vp.ViewCenter.To3d)
    member vp.PSDCS2DCS = vp.DCS2PSDCS.Inverse()
    member vp.DCS2WCS =
        Matrix3d.Rotation(-vp.TwistAngle, vp.ViewDirection, vp.ViewTarget) *
        Matrix3d.Displacement(vp.ViewTarget - Point3d.Origin) *
        Matrix3d.PlaneToWorld vp.ViewDirection
    member vp.WCS2DCS = vp.DCS2WCS.Inverse()
gile
  • Marseille, France
« Reply #20 on: July 13, 2011, 01:39:14 PM »
Thank you both.
I do not really care about "intellectual property" with the code I post on TheSwamp or elsewhere. I learn a lot from you and others and most of the code I write is "hacked" from what I read.
If I can bring my "two cents" sometimes, it makes me happy when other find it usefull.
Anyway, you're right, the Viewport extensions methods may be useful as the actual methods only work with the current (or last activated) one (I wanted to mimic the AutoLISP trans function with the Point3d.Trans() method).
If you don't mind it's an "appropriation of your intellectual proprety" ;-) , I'd add them to the library.
jgr
« Reply #21 on: July 15, 2011, 07:49:05 PM »
gile
  • Marseille, France
« Reply #22 on: August 29, 2011, 04:16:38 AM »
Here's a method to write the Brep (Boundary Representation) geométric informations of Solid3d, Region, Surface to an Xml file.
Requires A2009 or upper.
Method parameters:
- id: A Solid3d, Region or Surface ObjectId
- filename: The Xml file complete path
- append: If the file exists and this parameter is True, the new data is append to the file, else, the file is overwritten
Code - C#: [Select]
  1.         public void WriteBrepToXml(ObjectId id, string filename, bool append)
  2.         {
  3.             XmlDocument xmlDoc = new XmlDocument();
  4.             if (System.IO.File.Exists(filename) && append)
  5.             {
  6.                 xmlDoc.Load(filename);
  7.             }
  8.             else
  9.             {
  10.                 string s = @"<?xml version='1.0' ?>
  11.                <Brep>
  12.                </Brep>";
  13.                 xmlDoc.LoadXml(s);
  14.             }
  15.             Database db = HostApplicationServices.WorkingDatabase;
  16.             using (Transaction tr = db.TransactionManager.StartTransaction())
  17.             {
  18.                 Entity ent = (Entity)tr.GetObject(id, OpenMode.ForRead);
  19.                 string solidType;
  20.                 if (ent is Solid3d) solidType = "Solide";
  21.                 else if (ent is Region) solidType = "Region";
  22.                 else if (ent is AcDb.Surface) solidType = "Surface";
  23.                 else return;
  24.                 using (Brep brp = new Brep(ent))
  25.                 {
  26.                     XmlElement entNode = xmlDoc.CreateElement(solidType);
  27.                     entNode.SetAttribute("Handle", ent.Handle.ToString());
  28.                     xmlDoc.DocumentElement.AppendChild(entNode);
  29.                     foreach (Complex cplx in brp.Complexes)
  30.                     {
  31.                         XmlElement cplxNode = xmlDoc.CreateElement("Complex");
  32.                         entNode.AppendChild(cplxNode);
  33.                         foreach (Shell shl in cplx.Shells)
  34.                         {
  35.                             XmlElement shlNode = xmlDoc.CreateElement("Shell");
  36.                             shlNode.SetAttribute("Type", shl.ShellType.ToString());
  37.                             cplxNode.AppendChild(shlNode);
  38.                             foreach (AcBr.Face face in shl.Faces)
  39.                             {
  40.                                 XmlElement faceNode = xmlDoc.CreateElement("Face");
  41.                                 shlNode.AppendChild(faceNode);
  42.                                 try
  43.                                 {
  44.                                     foreach (BoundaryLoop loop in face.Loops)
  45.                                     {
  46.                                         XmlElement loopNode = xmlDoc.CreateElement("Loop");
  47.                                         loopNode.SetAttribute("Type", loop.LoopType.ToString());
  48.                                         faceNode.AppendChild(loopNode);
  49.                                         foreach (Edge edge in loop.Edges)
  50.                                         {
  51.                                             ExternalCurve3d curve = (ExternalCurve3d)edge.Curve;
  52.                                             switch (curve.NativeCurve.GetType().Name)
  53.                                             {
  54.                                                 case "LineSegment3d":
  55.                                                     LineSegment3d ls = (LineSegment3d)curve.NativeCurve;
  56.                                                     XmlElement lsNode = xmlDoc.CreateElement("LineSegment3d");
  57.                                                     lsNode.SetAttribute("StartPoint", ls.StartPoint.ToString());
  58.                                                     lsNode.SetAttribute("EndPoint", ls.EndPoint.ToString());
  59.                                                     lsNode.SetAttribute("Direction", ls.Direction.ToString());
  60.                                                     loopNode.AppendChild(lsNode);
  61.                                                     break;
  62.                                                 case "CircularArc3d":
  63.                                                     CircularArc3d ca = (CircularArc3d)curve.NativeCurve;
  64.                                                     double angle = Vector3d.XAxis
  65.                                                          .TransformBy(Matrix3d.PlaneToWorld(ca.Normal))
  66.                                                          .GetAngleTo(ca.ReferenceVector, ca.Normal);
  67.                                                     XmlElement caNode = xmlDoc.CreateElement("CircularArc3d");
  68.                                                     caNode.SetAttribute("StartPoint", ca.StartPoint.ToString());
  69.                                                     caNode.SetAttribute("EndPoint", ca.EndPoint.ToString());
  70.                                                     caNode.SetAttribute("Center", ca.Center.ToString());
  71.                                                     caNode.SetAttribute("Radius", ca.Radius.ToString());
  72.                                                     caNode.SetAttribute("StartAngle", (ca.StartAngle + angle).ToString());
  73.                                                     caNode.SetAttribute("EndAngle", (ca.EndAngle + angle).ToString());
  74.                                                     caNode.SetAttribute("Normal", ca.Normal.ToString());
  75.                                                     loopNode.AppendChild(caNode);
  76.                                                     break;
  77.                                                 case "EllipticalArc3d":
  78.                                                     EllipticalArc3d ea = (EllipticalArc3d)curve.NativeCurve;
  79.                                                     XmlElement eaNode = xmlDoc.CreateElement("EllipticalArc3d");
  80.                                                     eaNode.SetAttribute("StartPoint", ea.StartPoint.ToString());
  81.                                                     eaNode.SetAttribute("EndPoint", ea.EndPoint.ToString());
  82.                                                     eaNode.SetAttribute("Center", ea.Center.ToString());
  83.                                                     eaNode.SetAttribute("StartAngle", ea.StartAngle.ToString());
  84.                                                     eaNode.SetAttribute("EndAngle", ea.EndAngle.ToString());
  85.                                                     eaNode.SetAttribute("MajorAxis", ea.MajorAxis.ToString());
  86.                                                     eaNode.SetAttribute("MinorAxis", ea.MinorAxis.ToString());
  87.                                                     eaNode.SetAttribute("MajorRadius", ea.MajorRadius.ToString());
  88.                                                     eaNode.SetAttribute("MinorRadius", ea.MinorRadius.ToString());
  89.                                                     eaNode.SetAttribute("Normal", ea.Normal.ToString());
  90.                                                     loopNode.AppendChild(eaNode);
  91.                                                     break;
  92.                                                 case "NurbCurve3d":
  93.                                                     XmlElement ncNode = xmlDoc.CreateElement("NurbCurve3d");
  94.                                                     NurbCurve3d nc = (NurbCurve3d)curve.NativeCurve;
  95.                                                     NurbCurve3dData data = nc.DefinitionData;
  96.                                                     ncNode.SetAttribute("StartPoint", nc.StartPoint.ToString());
  97.                                                     ncNode.SetAttribute("EndPoint", nc.EndPoint.ToString());
  98.                                                     ncNode.SetAttribute("Degree", data.Degree.ToString());
  99.                                                     ncNode.SetAttribute("Periodic", data.Periodic.ToString());
  100.                                                     ncNode.SetAttribute("Rational", data.Rational.ToString());
  101.                                                     for (int i = 0; i < data.Knots.Count; i++)
  102.                                                     {
  103.                                                         ncNode.SetAttribute(string.Format("Knot_{0}", i + 1), data.Knots[i].ToString());
  104.                                                     }
  105.                                                     for (int i = 0; i < data.Weights.Count; i++)
  106.                                                     {
  107.                                                         ncNode.SetAttribute(string.Format("Weight_{0}", i + 1), data.Weights[i].ToString());
  108.                                                     }
  109.                                                     for (int i = 0; i < data.ControlPoints.Count; i++)
  110.                                                     {
  111.                                                         ncNode.SetAttribute(string.Format("ControlPoint_{0}", i + 1), data.ControlPoints[i].ToString());
  112.                                                     }
  113.                                                     loopNode.AppendChild(ncNode);
  114.                                                     break;
  115.                                             }
  116.                                         }
  117.                                     }
  118.                                 }
  119.                                 catch
  120.                                 {
  121.                                     XmlElement loopNode = xmlDoc.CreateElement("LoopUnbounded");
  122.                                     faceNode.AppendChild(loopNode);
  123.                                 }
  124.                             }
  125.                         }
  126.                     }
  127.                     xmlDoc.Save(filename);
  128.                 }
  129.                 tr.Commit();
  130.             }
  131.         }
Heres a little example of the returned file content for a region made of a rectangle from 0,0 to 80,50 with a circular hole which center is at 20,30 and a 10 radius:
Code - XML: [Select]
  1. <?xml version="1.0"?>
  2. <Brep>
  3.   <Region Handle="2747">
  4.     <Complex>
  5.       <Shell Type="ShellExterior">
  6.         <Face>
  7.           <Loop Type="LoopInterior">
  8.             <CircularArc3d StartPoint="(30,30,0)" EndPoint="(30,30,0)" Center="(20,30,0)" Radius="10" StartAngle="3.14159265358979" EndAngle="9.42477796076938" Normal="(0,0,-1)" />
  9.           </Loop>
  10.           <Loop Type="LoopExterior">
  11.             <LineSegment3d StartPoint="(0,0,0)" EndPoint="(80,0,0)" Direction="(1,0,0)" />
  12.             <LineSegment3d StartPoint="(80,0,0)" EndPoint="(80,50,0)" Direction="(0,1,0)" />
  13.             <LineSegment3d StartPoint="(80,50,0)" EndPoint="(0,50,0)" Direction="(-1,0,0)" />
  14.             <LineSegment3d StartPoint="(0,50,0)" EndPoint="(0,0,0)" Direction="(0,-1,0)" />
  15.           </Loop>
  16.         </Face>
  17.       </Shell>
  18.     </Complex>
  19.   </Region>
  20. </Brep>
« Last Edit: July 12, 2016, 06:31:08 AM by gile »
gile
  • Marseille, France
« Reply #23 on: September 11, 2011, 08:36:50 AM »
I expanded a little the GeometryExtensions library.
There're two more classes: PolylineSegment and PolylineSegmentCollection (which inherits from List<PolylineSegment>) and a new extension method: Ellipse.ToPolyline().
I hope these classes make easier some work with polylines or to create polylines from other entities.
Here's a quick and dirty example (will give unexpected result with entities which don't lies on the WCS XY plane).
The MJOIN command joins the selected entities: line, arc, polyline, ellipse and spline (A2010 or later for spline) into one or more polyline(s).
using GeometryExtensions;
namespace GeometryExtensionsTestCommands
    public class MjoinCommand
        [CommandMethod("mjoin")]
        public void PolyJoin()
            TypedValue[] filter = {
                new TypedValue(-4,"<OR"),
                new TypedValue(0, "ARC,ELLIPSE,LINE,LWPOLYLINE"),
                new TypedValue(-4, "<AND"),
                new TypedValue(0, "SPLINE"),
                new TypedValue(-4, "&"),
                new TypedValue(70, 8),
                new TypedValue(-4, "AND>"),
                new TypedValue(-4, "OR>")};
                PolylineSegmentCollection psc = new PolylineSegmentCollection();
                Plane plane = new Plane(Point3d.Origin, Vector3d.ZAxis);
                foreach (ObjectId id in psr.Value.GetObjectIds())
                    switch (ent.GetType().Name)
                        case "Arc":
                            Arc arc = (Arc)ent;
                            psc.Add(new PolylineSegment(
                                new CircularArc2d(
                                    arc.Center.Convert2d(plane),
                                    arc.Radius,
                                    arc.StartAngle,
                                    arc.EndAngle,
                                    Vector2d.XAxis,
                                    false)));
                            break;
                        case "Ellipse":
                            Ellipse el = (Ellipse)ent;
                            psc.AddRange(new PolylineSegmentCollection(el));
                            break;
                        case "Line":
                            Line l = (Line)ent;
                                new LineSegment2d(
                                    l.StartPoint.Convert2d(plane),
                                    l.EndPoint.Convert2d(plane))));
                            break;
                        case "Polyline":
                            Polyline pl = (Polyline)ent;
                            psc.AddRange(new PolylineSegmentCollection(pl));
                            break;
                        case "Spline":
                            try
                                Spline spl = (Spline)ent;
                                psc.AddRange(new PolylineSegmentCollection((Polyline)spl.ToPolyline()));
                            catch { }
                            break;
                        default:
                            break;
                foreach (PolylineSegmentCollection segs in psc.Join())
                    Polyline pline = segs.ToPolyline();
                tr.Commit();
gile
  • Marseille, France
« Reply #24 on: October 16, 2011, 11:02:36 AM »
The GeometryExtension librairy keeps on growing.
The main new things are Polyline, Polyline2d and Polyline3d extensions methods : GetProjectedPolyline and GetOrthoProjectedPolyline.
These methods create a new Polyline object and may replace the GetProjectedCurve and GetOrthoProjectedCurve methods which do not give expected results with Polyline and Polyline2d entities.
The elliptical arcs resulting of the polyline arcs projection are approximated using the PolylineSegmentCollection(Ellipse ellipse) constructor. This constructor uses the same geometric method as the 'old' AutoCAD native approximation of ellipses (i.e. PELLIPSE = 1).
« Last Edit: October 16, 2011, 11:16:30 AM by gile »
gile
  • Marseille, France
« Reply #25 on: November 14, 2011, 03:13:32 PM »
New version of GeometryExtensions (1.3).
Download updated in the first message.
Corrected some bugs with the GetProjectedPolyline and GetOrthoProjectedPolyline methods.
fixo
« Reply #26 on: May 05, 2012, 04:56:14 AM »
Draw bisector berween 2 lines
        [CommandMethod("bisect", CommandFlags.Modal | CommandFlags.Redraw)]
        public static void TestForBiLine()
            // Get the current document and database
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            // Select lines
            PromptEntityOptions opt = new PromptEntityOptions("\nSelect a first line:");
            opt.SetRejectMessage("\nMust be selected the line only!");
            opt.AddAllowedClass(typeof(Line),false);
            PromptEntityResult res1 = ed.GetEntity(opt);
            // Set 'black hole' to exit if something wrong
            if (res1.Status != PromptStatus.OK)return;
         opt=   new PromptEntityOptions("\nSelect a second line:");
            PromptEntityResult res2 = ed.GetEntity(opt);
            if (res2.Status != PromptStatus.OK) return;
            // Open transaction
             Transaction tr = db.TransactionManager.StartTransaction();
             using (tr)
                 DBObject obj1 = tr.GetObject(res1.ObjectId, OpenMode.ForWrite);
                 Line ln1 = obj1 as Line;
                 if (ln1 == null) return;
                 DBObject obj2 = tr.GetObject(res2.ObjectId, OpenMode.ForWrite);
                 Line ln2 = obj2 as Line;
                 if (ln2 == null) return;
                 Point3d ps1 = ln1.StartPoint;
                 Point3d pe1 = ln1.EndPoint;
                 Point3d ps2 = ln2.StartPoint;
                 Point3d pe2 = ln2.EndPoint;
                 Point3dCollection pts = new Point3dCollection();
                 ln1.IntersectWith(ln2, Intersect.ExtendBoth, pts, 0, 0);
                 // Set 'black hole' to exit if no intersection
                 if (pts.Count != 1)
                     acadApp.ShowAlertDialog("Lines are colinear or does not intersects each another");
                     return;
                 // Calculate nearest point to the first line
                 Point3d pk1 = res1.PickedPoint;
                 pk1 = ln1.GetClosestPointTo(pk1, true);
                 Point3d pk2 = res2.PickedPoint;
                 pk2 = ln2.GetClosestPointTo(pk2, true);
                 // Swap start and end points if lines has different direction
                 if (ps1.DistanceTo(ps2) + pe1.DistanceTo(pe2) > (ps1.DistanceTo(pe2) + pe1.DistanceTo(ps2)))
                     Point3d tp = new Point3d(ps1.X, ps1.Y, ps1.Z);
                     ps1 = pe1;
                     pe1 = tp;
                 // create the first temporary Line3d object
                 Line3d tl1 = new Line3d(ps1, ps2);
                 // Calculate midpoint of this line
                 Point3d tp1 = tl1.EvaluatePoint(0.5);
                 // create the second temporary Line3d object
                 Line3d tl2 = new Line3d(pe1, pe2);
                 Point3d tp2 = tl2.EvaluatePoint(0.5);
                 // Create bisector line
                 Line ln = new Line(tp1, tp2);
                 ln.SetDatabaseDefaults();
                 BlockTableRecord btr = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
                 // Append line to the current space and transaction
                 btr.AppendEntity(ln);
                 tr.AddNewlyCreatedDBObject(ln, true);
                 // Commit transaction
                 tr.Commit();
Regards,
~'J'~
« Last Edit: May 05, 2012, 03:21:03 PM by fixo »
gile
  • Marseille, France
« Reply #27 on: May 05, 2012, 03:13:26 PM »
Hi Oleg,
Here's another way using vectors
Code - C#: [Select]
  1.         [CommandMethod("Bisect")]
  2.         public void Bisector()
  3.         {
  4.             Document doc = AcAp.DocumentManager.MdiActiveDocument;
  5.             Database db = doc.Database;
  6.             Editor ed = doc.Editor;
  7.             PromptEntityOptions peo = new PromptEntityOptions("\nSelect the first line: ");
  8.             peo.SetRejectMessage("Selected object is not a line !");
  9.             peo.AddAllowedClass(typeof(Line), true);
  10.             PromptEntityResult per = ed.GetEntity(peo);
  11.             if (per.Status != PromptStatus.OK) return;
  12.             Point3d p1 = per.PickedPoint.TransformBy(ed.CurrentUserCoordinateSystem);
  13.             ObjectId id1 = per.ObjectId;
  14.             peo.Message = "\nSelect the second line: ";
  15.             per = ed.GetEntity(peo);
  16.             if (per.Status != PromptStatus.OK) return;
  17.             Point3d p2 = per.PickedPoint.TransformBy(ed.CurrentUserCoordinateSystem);
  18.             ObjectId id2 = per.ObjectId;
  19.             using (Transaction tr = db.TransactionManager.StartTransaction())
  20.             {
  21.                 Line l1 = (Line)tr.GetObject(id1, OpenMode.ForRead);
  22.                 Line l2 = (Line)tr.GetObject(id2, OpenMode.ForRead);
  23.
  24.                 // Checks if lines intersect
  25.                 Plane plane;
  26.                 Line3d line1 = new Line3d(l1.StartPoint, l1.EndPoint);
  27.                 Line3d line2 = new Line3d(l2.StartPoint, l2.EndPoint);
  28.                 if (!line1.IsCoplanarWith(line2, out plane) || line1.IsParallelTo(line2))
  29.                     return;
  30.
  31.                 // Calculates the bisector
  32.                 Point3d inters = line1.IntersectWith(line2)[0];
  33.                 Vector3d vec1 = line1.Direction;
  34.                 Vector3d vec2 = line2.Direction;
  35.                 // Corrects the vectors direction according to picked points
  36.                 if (vec1.DotProduct(inters.GetVectorTo(p1)) < 0)
  37.                     vec1 = vec1.Negate();
  38.                 if (vec2.DotProduct(inters.GetVectorTo(p2)) < 0)
  39.                     vec2 = vec2.Negate();
  40.                 Vector3d bisectDir = (vec1 + vec2) / 2.0;
  41.
  42.                 // Draws the bisector (XLine)
  43.                 Xline xline = new Xline();
  44.                 xline.UnitDir = bisectDir.GetNormal();
  45.                 xline.BasePoint = inters;
  46.                 BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
  47.                 btr.AppendEntity(xline);
  48.                 tr.AddNewlyCreatedDBObject(xline, true);
  49.                 tr.Commit();
  50.             }
  51.         }
Note: AFAIK, there's no need to call Dispose() on Line3d objects (as for Vector3d, Point3d, ...).
fixo
« Reply #28 on: May 05, 2012, 03:22:47 PM »
Thanks, Gilles, I removed these lines from code
Regards,
Oleg
fixo
« Reply #29 on: May 06, 2012, 02:27:34 AM »
Circle by 3 points
        [CommandMethod("circ3p")]// This method can have any name
        public static void TestFor3PointCircle()
            // Get the document and database
            // If we have a valid point selection, get all 3 points
           PromptPointOptions ppo =   new PromptPointOptions("\nPick a point : ");
            ppo.AllowNone = true;
            PromptPointResult ppr;
                ppr = ed.GetPoint(ppo);
                if (ppr.Status != PromptStatus.OK) return;
            Point3d p1= ppr.Value;
            ppo =   new PromptPointOptions("\nPick a second point : ");
            Point3d p2= ppr.Value;
                        ppo =   new PromptPointOptions("\nPick a third point : ");
            Point3d p3= ppr.Value;
            // To pass center point by reference
            Point3d pc = new Point3d();
            // Get result
            bool result = CircleCenter(p1, p2, p3, out pc);
            if (result)
                ed.WriteMessage("\nCenter point calculated:\t{0:f3},{1:f3},{2:f3}", pc.X, pc.Y, pc.Z);
            else return;
            // Calculate radius
            double rad = pc.DistanceTo(p1);
            // Open transaction and add circle to the current space
                Circle circ = new Circle(pc, Vector3d.ZAxis, rad);
                btr.AppendEntity(circ);
                tr.AddNewlyCreatedDBObject(circ, true);
                tr.Commit();
        public static bool CircleCenter(Point3d p0, Point3d pm, Point3d p1, out Point3d pc)
            Vector3d v1 = p0 - pm;
            Vector3d v2 = p1 - pm;
            if (v1.IsParallelTo(v2))
                pc = new Point3d();
                return false;
            CircularArc3d crc = new CircularArc3d(p0, pm, p1);
            pc = crc.Center;
            return true;
Regards,
~'J'~
