Author Topic: Limitation with Array Action?  (Read 3558 times)
Serge J. Gianolla
« on: January 24, 2010, 05:26:06 PM »
Hi all,
I am starting with a single circle and use the array parameter. The end results I am after are e.g. 3 circles horizontally, 6 vertically or 5 Hor and 2 Ver…
AutoCAD does not allow user to select same object twice for the Array action!! Has anyone found a solution/work-around?
Serge J. Gianolla
Re: Limitation with Array Action?
« Reply #1 on: January 24, 2010, 06:51:22 PM »
Got it thanx to Array box sets, not as flexible/intuitive but does the job!
