Author Topic: List_Box Text Alignment  (Read 2734 times)
« on: January 23, 2010, 08:12:54 PM »
Hi Guys,
I am trying to align text within a List_Box so that I may have two columns, for use in this thread.
Things I have already tried:
  • Using "fixed_width_font = true;"  ~  This works, but the font is quite large and doesn't look right
  • Using Tabs in the text string  ~  Doesn't work
  • 'Padding' the string with spaces to get a desired length  ~  Doesn't work with non-fixed width fonts
I believe this is possible somehow, as MP uses this same idea in his AxProps program  (along with other neat tricks), but, of course, the source code for his routine is not available... so his secret is safe with him...
Any help or pointers are greatly appreciated :-)
Lee
« Last Edit: January 23, 2010, 08:27:26 PM by Lee Mac »
Re: List_Box Text Alignment
« Reply #1 on: January 23, 2010, 08:48:07 PM »
It's a while since I've played with DCL, but ;
Have you tried the tabs attribute in the dcl definition file ?
Something like :
    : list_box {
        key = "list_box";
        tabs = "20 60 70";
        width = 75;
        height = 25;
« Last Edit: January 23, 2010, 09:03:34 PM by Kerry Brown »
« Reply #2 on: January 23, 2010, 08:52:35 PM »
Aha!  Many thanks Kerry, I shall give that a go!
My incomplete knowledge of DCL showing...  :oops:
« Reply #3 on: January 23, 2010, 09:00:52 PM »
Perfect Kerry - exactly what was needed  :-)
Many thanks,
Lee
« Reply #4 on: January 23, 2010, 09:02:13 PM »
Most welcome !
Have a look at the Tab_Truncate attribute as well.
« Reply #5 on: January 23, 2010, 09:10:24 PM »
Excellent! That's two new things discovered today  :wink:
Thanks Kerry  :-)
« Reply #6 on: January 23, 2010, 09:18:25 PM »
 [off topic] :wink:
I just noticed how closely that .DCL code resembles C# code
« Reply #7 on: January 23, 2010, 09:23:21 PM »
 [off topic] :wink:
Never dabbled in C#... is format the same then?  :|
« Reply #8 on: January 23, 2010, 10:45:18 PM »
just similar ...
There's something comforting about seeing statement terminators < ; > and code block identifiers < { .. }  >
« Last Edit: January 24, 2010, 04:30:35 AM by Kerry Brown »
