Author Topic: -+{ Challenge }+- Serialize Xdata  (Read 13624 times)
Re: -+{ Challenge }+- Serialize Xdata
« Reply #30 on: January 23, 2010, 10:32:56 PM »
Thanks Dan, I'll work through it eventually :)
The time difference astounds me  !!  .... 8 seconds vs 0.7 seconds.
--> Donate to theSwamp<--
pkohut
« Reply #31 on: February 07, 2010, 08:20:28 PM »
Test results of supplied drawing (500,000 points), 'doit' middle 5 test results from  10 samples.
Only changes was to move the switch statement logic in CTypedValue::CTypedValue( const resbuf *buf )
to a class that holds a jump table of functions.  The class is called like
   short type = acdbGroupCodeToType(buf->restype);
   blaze1::op(buf, _value, _valueType, vString);
Because the compiler generated indirect calls through the jump table the speed boost I was looking for didn't
really happen.  Would need to restructor more of the code and try to keep parameters in functions to
3 or less, and have a jmp instead of a call.
                 Paul            Dan
              0.677111       0.690452
              0.678350       0.691959
              0.679616       0.695678
              0.680110       0.698469
              0.680415       0.699986
Average       0.679120       0.695309
Finally, Dan's runtime he posted of 0.53? for his i7 machine is what I get when I don't archive the data.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #32 on: February 07, 2010, 09:12:14 PM »
I played with  acdbGroupCodeToType too, I created a switch with all the codes including  ones > 5000, but it made little difference.
I'm still amazed at how fast CArchive is compared to serializing with .NET    :-o
Retired
It's Alive!
  • Retired
  • AKA Daniel
« Reply #33 on: February 07, 2010, 09:16:35 PM »
I'm still pondering what kind of serialization I want to use, it seems most like some sort of XML format....  :|
Retired
pkohut
« Reply #34 on: February 07, 2010, 09:36:14 PM »
Funny, I was just looking at Boost Fusion earlier as a possible XML solution.
Got as far as reading the preface and quick start pages.
http://www.boost.org/doc/libs/1_42_0/libs/fusion/doc/html/fusion/quick_start.html
