Here is an old routine that may be modified for your use.
;; 03.17.08 CAB modified the block insert to use the Scale of the first
;; block inserted. Also changed the entget to getpoint for the object
;; selection so that osnaps will be visible
;; http://forums.cadalyst.com/showthread.php?p=20949#post20949
;| This routine is further modified by Alan Butler aka CAB aka CAB2k
The routine will work with a block without attributes so I modified
it to work with most blocks in that the break points are determined
by the intersect points of LINES that are farthest apart.
I renamed it BlockInsert for my use. I did minimal testing with a
valve symbol inserted into a pline. No UCS testing.
This routine works by exploding the block, then determining the intersect
points. After the exploded block is removed.
Note that this will not work with all blocks.
;|Routine to label contours drawn by Line/Arc/Polyline. Originally penned by
CiphDRMRS, aka T.Willey, on the AUGI Forums. Modified by Jeff Mishler.
An assumption is made that a valid block with 1 attribute is selected.
(defun c:BlockInsert (/ atts ent entobj inspt
intpts lastent oldecho oldreq oldosnap p1
p2 pt sel tmplist tmplist2 tmpobj
inpt re elst *error*
; (setq *bname nil) ; force new block each time, or
;; paste at the command line to reset the block name
(defun *error* (msg)
(if msg
(princ msg)
(setvar "attreq" oldreq)
(setvar "osmode" oldosnap)
(command "undo" "end")
(setvar "cmdecho" oldecho)
;; CAB 05/07/06
;; group on the first three elements A B C of a flat list A B C D E F
;; list must be divisable by 3, no error checking
;; InpLst is the flat list ((A B C) (D E F) (G H I)...)
(defun group_on3 (inplst / outlst tmp grp idx sub)
(while inplst
(setq outlst (cons (list (car inplst) (cadr inplst) (caddr inplst)) outlst))
(setq inplst (cdddr inplst))
outlst
(setq OldReq (getvar "attreq")
oldecho (getvar "cmdecho")
oldOsnap (getvar "osmode")
(setvar "cmdecho" 0)
(command "undo" "be")
(setvar "attreq" 0)
(setvar "osmode" 512)
;; CAB made *bname var global so that I could reuse the var in a session
;; If you want the block name to be changed at each start uncomment the next line
;; (setq *bname nil)
(while
(and
;; use getpoint for osnaps to work
(setq inspt (getpoint "\n Select object where you wish the block to be inserted: "))
(setq inspt (osnap inspt "_near"))
(setq Sel (nentselp inspt))
(setq Ent (car Sel)
entObj (vlax-ename->vla-object Ent)
(if (not *bname)
(setvar "cmdecho" 1)
(initdia)
(command "_.insert")
(command InsPt)
(while (> (getvar "cmdactive") 0)
(command pause)
(setq LastEnt (entlast)
elst (entget LastEnt)
*bname (cdr (assoc 2 elst))
*ScaleX (cdr (assoc 41 elst))
*ScaleY (cdr (assoc 42 elst))
(command "_.-insert" *bname)
(command InsPt *ScaleX *ScaleY pause)
(setq LastEnt (entlast))
(setq tmpObj (vlax-ename->vla-object LastEnt)
z (last inspt)
(setq tmpList (vlax-invoke tmpObj 'Explode))
;; CAB modified this section & removed some code
(setq Intpts nil ; CAB
re nil)
(foreach i tmpList
(mapcar '(lambda (x)
(vlax-invoke x 'move (list 0.0 0.0 0.0) '(0.0 0.0 1e99))
(vlax-invoke x 'move (list 0.0 0.0 0.0) '(0.0 0.0 -1e99))
(list entobj i)
;; collect all points of intersect
;; CAB revised 11.08.07 to accommodate objects that have more than one
;; intersect point
(if (setq inpt (vlax-invoke entobj 'intersectwith i acextendnone)) ; CAB
(setq inpt (group_on3 inpt) ; CAB revised 11.08.07
intpts (append inpt intpts)) ; CAB revised 11.08.07
(vlax-invoke entobj 'move (list 0.0 0.0 0.0) (list 0.0 0.0 z))
(vlax-invoke i 'move (list 0.0 0.0 0.0) (list 0.0 0.0 z))
(vla-delete i)
;; CAB added this section of code
;; Find the two points farthest apart
(mapcar
'(lambda(x)
(mapcar
'(lambda(y)
((null re)(setq re (list x y)))
((> (distance x y) (distance (car re) (cadr re)))
IntPts
IntPts
;; restore the Z
(setq p1 (list (caar re) (cadar re) z)
p2 (list (caadr re) (cadadr re) z))
(if (and p1 p2)
(command "_.break" Ent
(trans p1 0 1) ; had to add trans to both points
(trans p2 0 1) ; here is the second point
(alert (strcat "Can not break object."
"\n Error in getting the two points needed."
"\nSelect OK then select the 2 points to break at."
(setvar "osmode" 32)
(if (and (setq p1 (getpoint "\nFirst break point: "))
(setq p2 (getpoint p1 "....second break point: "))
(command ".break" Ent p1 p2)
(if (setq atts (vlax-invoke tmpObj 'getattributes))
(vla-put-textstring (car atts) (rtos z 2 0))
(*error* nil)
