Author Topic: Debug - getting layer from selected object  (Read 4027 times)
Krushert
  • FREE BEER Tomorrow!!
« on: January 20, 2010, 09:13:39 PM »
I am cobbling this together from a handful of routines but I crashing at this point.
  (setq objectlayer (cdr [color=red](assoc 8 PlineID)[/color]))Well that is what the debugger is telling me
Anyway I coming up with nothing on what to replace it with so I am asking for a little help.
Thanks a million.
;;;; User Selection of PolyLine and test thereof
  (IF
    (setq
      ss (ssget
   '((0 . "LWPOLYLINE"))
     (setq
       PlineID
(vla-get-objectid (vlax-ename->vla-object (ssname ss 0)))
;;;; Generating of FeildString Variable for the plines length
;;;; Use the FIELD-command to compose the next line:  (itoa PlineID)
  (setq fieldstring
(strcat "%<\\AcObjProp Object(%<\\_ObjId "
(itoa PlineID)
">%).Length \\f \"%lu6\">%"
  ;;;; Gathering Layer Info from User Selected object changes current layer to that of selected object
  (setq curlay (getvar "clayer"))
  (setvar "clayer" objectlayer)
Re: Debug - getting layer from selected object
« Reply #1 on: January 20, 2010, 09:32:46 PM »
You're getting Entity, Object and Objectid mixed up.
See if this helps
(IF (setq ss (ssget '((0 . "LWPOLYLINE"))))
    (setq PlineID (vla-get-objectid
                      (vlax-ename->vla-object (setq ent (ssname ss 0)))
(setq layerName (cdr (assoc 8 (entget ent))))
    (setq PlineID (vla-get-objectid (vlax-ename->vla-object (ssname ss 0))))
(setq *AcadDocument (vla-get-activedocument (vlax-get-acad-object))
      layerObject   (vla-ObjectIDToObject *AcadDocument PlineID)
      layerName     (vla-get-layer layerObject)
    (setq
                    (setq ObjectPline (vlax-ename->vla-object (ssname ss 0)))
(setq layerName (vla-get-layer ObjectPline))
Krushert
« Reply #2 on: January 20, 2010, 10:18:40 PM »
Thought as much from taking a breather and then studying past examples.  Looks like I got some reading to do with the above.
I was trying to figure out how to use (setq layerName (cdr (assoc 8 (entget ent)))) in the first option that you show and I actually tried the vla-get-layer halfheartedly.   I see that I need that extra Setq in there somewhere.  Anyway I choose the 3rd option and the the routine works.
Krushert
« Reply #3 on: January 20, 2010, 10:27:00 PM »
Just thought of something to kick this routine up a notch.  Where can I find some examples of combining the ssget function with the getpoint function all with one user pick?
I need to cull the above info from a multi-segmented pline along with angle immediate segment that the user picked on and the point on where the user picked.  The latter two would be to insert a block on a pline at that point and rotate the block to align with pline.
« Reply #4 on: January 20, 2010, 10:31:41 PM »
Do you want multiple entitys
(ssget ....
or a single entity
(entsel ....
Krushert
« Reply #5 on: January 20, 2010, 10:40:43 PM »
(ssget ....
or a single entity
(entsel ....
I am selecting a single entity.    :?
« Reply #6 on: January 20, 2010, 11:29:53 PM »
To break the process up, see how this goes for a start ..
Note: Code reads best in the Mercury forum theme.
[add:] Profile->LookAndLayoutPreferences->CurrentTheme(change)->Mercury
LIBRARY FUNCTIONS
;; (KDUB:ENTSel_3 <Promptmsg> <typelist > <nentselflag > )
(defun kdub:entsel_3 (promptmsg              ;
                      typelist               ; List of entity types allowed to be selected
                      nentselflag            ; If true nentsel permitted , otherwise use entsel.
                      /            pickok       returnvalue
                      tmp
  (setq promptmsg (strcat "\n"
                          (cond (promptmsg)
                                ("Select object")
  (while (not pickok)
    (setvar "ERRNO" 0)
    (setq returnvalue (if nentselflag
                        (nentsel promptmsg)
                        (entsel promptmsg)
      ((= (getvar "ERRNO") 52)               ; enter
       ;; skip out
       (setq pickok t)
      ((= (getvar "ERRNO") 7)
       (princ "Nothing found at selectedpoint. ")
      ((and
         (setq tmp (entget (car returnvalue))) ; object type
         typelist
         (not (member (cdr (assoc 0 tmp)) (mapcar 'strcase typelist)))
       )                                     ; wrong type
       (alert
         (strcat "Selected object is not"
                 "\na "
                 (apply 'strcat
                        (cons (car typelist)
                              (mapcar '(lambda (x) (strcat "\nor " x))
                                      (cdr typelist)
      ;; skip out
      ((setq pickok t))
  ;; return EntityENAME/PickPoint List
  returnvalue
(defun kdub:getsegment (obj pt / cpt eparam stparam)
  ;; Stig Madsen
    ((setq cpt (vlax-curve-getclosestpointto obj pt t))
     (setq eparam (fix (vlax-curve-getendparam obj)))
     (if (= eparam
            (setq stparam (fix (vlax-curve-getparamatpoint obj cpt)))
       (setq stparam (1- stparam))
       (setq eparam (1+ stparam))
     (list eparam
           (vlax-curve-getpointatparam obj stparam)
           (vlax-curve-getpointatparam obj eparam)
TEST CODE
Should return the start end endpoint of the Selected LINE or LWPOLYLINE Segment
(if (setq plineent (kdub:entsel_3 "Select Work line"
                                  '("LINE" "LWPOLYLINE")
                                  t
  (progn (setq plineobj (vlax-ename->vla-object (car plineent))
               ;; PickPoint (osnap (cadr plineent) "_nea")
               PickPointWorld  (trans (osnap (cadr plineent) "_nea") acUCS acWorld)
         (kdub:getsegment plineobj PickPointWorld)
Once you understand that, deal with inserting the block.
« Last Edit: January 20, 2010, 11:45:47 PM by Kerry Brown »
Krushert
« Reply #7 on: January 21, 2010, 12:37:34 PM »
Thanks Kerry.  I see it is not an easy nut to crack.  I will pick away at it and will be back with questions.
« Reply #8 on: January 21, 2010, 02:11:57 PM »
Here is an old routine that may be modified for your use.
;;  03.17.08 CAB modified the block insert to use the Scale of the first
;;    block inserted. Also changed the entget to getpoint for the object
;;    selection so that osnaps will be visible
;;  http://forums.cadalyst.com/showthread.php?p=20949#post20949
;| This routine is further modified by Alan Butler aka CAB aka CAB2k
   The routine will work with a block without attributes so I modified
   it to work with most blocks in that the break points are determined
   by the intersect points of LINES that are farthest apart.
   I renamed it BlockInsert for my use. I did minimal testing with a
   valve symbol inserted into a pline. No UCS testing.
   This routine works by exploding the block, then determining the intersect
   points. After the exploded block is removed.
   Note that this will not work with all blocks.
;|Routine to label contours drawn by Line/Arc/Polyline. Originally penned by
  CiphDRMRS, aka T.Willey, on the AUGI Forums. Modified by Jeff Mishler.
  An assumption is made that a valid block with 1 attribute is selected.
(defun c:BlockInsert (/        atts      ent      entobj   inspt
                  intpts   lastent  oldecho  oldreq   oldosnap p1
                  p2       pt       sel      tmplist  tmplist2 tmpobj
                  inpt     re       elst  *error*
  ; (setq *bname nil) ; force new block each time, or
  ;;  paste at the command line to reset the block name
  (defun *error* (msg)
    (if msg
      (princ msg)
    (setvar "attreq" oldreq)
    (setvar "osmode" oldosnap)
    (command "undo" "end")
    (setvar "cmdecho" oldecho)
;; CAB 05/07/06
;;  group on the first three elements  A B C of a flat list A B C D E F
;;  list must be divisable by 3, no error checking
;;  InpLst is the flat list ((A B C) (D E F) (G H I)...)
(defun group_on3 (inplst / outlst tmp grp idx sub)
  (while inplst
    (setq outlst (cons (list (car inplst) (cadr inplst) (caddr inplst)) outlst))
    (setq inplst (cdddr inplst))
  outlst
  (setq OldReq   (getvar "attreq")
        oldecho  (getvar "cmdecho")
        oldOsnap (getvar "osmode")
  (setvar "cmdecho" 0)
  (command "undo" "be")
  (setvar "attreq" 0)
  (setvar "osmode" 512)
  ;;  CAB made *bname var global so that I could reuse the var in a session
  ;;  If you want the block name to be changed at each start uncomment the next line
  ;;  (setq *bname nil)
  (while
      ;;  use getpoint for osnaps to work
      (setq inspt (getpoint "\n Select object where you wish the block to be inserted: "))
      (setq inspt (osnap inspt "_near"))
      (setq Sel (nentselp inspt))
     (setq Ent    (car Sel)
           entObj (vlax-ename->vla-object Ent)
     (if (not *bname)
         (setvar "cmdecho" 1)
         (initdia)
         (command "_.insert")
         (command InsPt)
         (while (> (getvar "cmdactive") 0)
           (command pause)
         (setq LastEnt (entlast)
       elst    (entget LastEnt)
               *bname  (cdr (assoc 2 elst))
       *ScaleX  (cdr (assoc 41 elst))
       *ScaleY  (cdr (assoc 42 elst))
         (command "_.-insert" *bname)
         (command InsPt *ScaleX *ScaleY pause)
         (setq LastEnt (entlast))
     (setq tmpObj (vlax-ename->vla-object LastEnt)
           z      (last inspt)
     (setq tmpList (vlax-invoke tmpObj 'Explode))
    ;;  CAB modified this section & removed some code
     (setq Intpts nil        ; CAB
           re     nil)
     (foreach i tmpList
                  (vlax-invoke x 'move (list 0.0 0.0 0.0) '(0.0 0.0 1e99))
                  (vlax-invoke x 'move (list 0.0 0.0 0.0) '(0.0 0.0 -1e99))
               (list entobj i)
       ;;  collect all points of intersect
       ;;  CAB revised 11.08.07 to accommodate objects that have more than one
       ;;  intersect point
       (if (setq inpt (vlax-invoke entobj 'intersectwith i acextendnone)) ; CAB
           (setq inpt   (group_on3 inpt)   ;  CAB revised 11.08.07
                 intpts (append inpt intpts))  ;  CAB revised 11.08.07
       (vlax-invoke entobj 'move (list 0.0 0.0 0.0) (list 0.0 0.0 z))
       (vlax-invoke i 'move (list 0.0 0.0 0.0) (list 0.0 0.0 z))
       (vla-delete i)
    ;;  CAB added this section of code
    ;;  Find the two points farthest apart
    (mapcar
      '(lambda(x)
         (mapcar
           '(lambda(y)
                ((null re)(setq re (list x y)))
                ((> (distance x y) (distance (car re) (cadr re)))
           IntPts
      IntPts
    ;;  restore the Z
    (setq p1 (list (caar re) (cadar re) z)
          p2 (list (caadr re) (cadadr re) z))
     (if (and p1 p2)
       (command  "_.break"  Ent
         (trans p1 0 1) ; had to add trans to both points
         (trans p2 0 1) ; here is the second point
         (alert (strcat "Can not break object."
                        "\n  Error in getting the two points needed."
                        "\nSelect OK then select the 2 points to break at."
         (setvar "osmode" 32)
         (if (and (setq p1 (getpoint "\nFirst break point: "))
                  (setq p2 (getpoint p1 "....second break point: "))
           (command ".break" Ent p1 p2)
     (if (setq atts (vlax-invoke tmpObj 'getattributes))
       (vla-put-textstring (car atts) (rtos z 2 0))
  (*error* nil)
Krushert
« Reply #9 on: January 21, 2010, 03:00:08 PM »
Thanks CAB.  I will take a look at this also.
This is all making my head start that spinning thing. :grazy:
« Reply #10 on: January 21, 2010, 03:11:04 PM »
This is the way that I would normally approach it, sometimes excluding the last condition, so that the user may exit if he/she doesn't select something:
(while
    (setq ent (car (entsel "\nSelect Entity: ")))
    (cond (  (eq 'ENAME (type ent))
             (if (not (member (cdr (assoc 0 (entget ent))) '("LINE" "ARC")))
               (princ "\n** Invalid Object Selected **")))
          (t (princ "\n** Nothing Selected **")))))
Krushert
« Reply #11 on: January 22, 2010, 01:02:56 PM »
Guys I have been teleported to a project that needs to get out the door.  I will be back.  Thanks for the help.
nivuahc
« Reply #12 on: January 22, 2010, 05:02:16 PM »
I was thinking about something along these lines the other day and this is as far as I got (though I'm sure there are more better ways to go about it... I was sorta thinking out loud):
(setq Item (entsel)
      Pick (cadr Item)
      VLAItem (vlax-ename->vla-object (car Item))
      ItemAngle
       (* 180.0
            (angle
              (vlax-safearray->list
                (vlax-variant-value
                  (vlax-get-property VLAItem 'StartPoint)
                (vlax-variant-value
                  (vlax-get-property VLAItem 'EndPoint)
            pi
(princ "\nThe user picked the item at point ")(princ Pick)
(princ (strcat "\nThe angle of the item is " (rtos ItemAngle 2 2)))
I'm purty darned positive that there's a better way to do it but I got about this far before I got pulled off and put on something else
« Reply #13 on: January 22, 2010, 06:32:07 PM »
How about with vlax-curve?
;;  GetAngle  CAB 01.22.2010
(defun c:GetAngle(/ ent pt ang)
  ;;  CAB test to see if vlax-curve can be used on an object
  (defun curveOK (ent) ; returns nil if not allowed
    (not (vl-catch-all-error-p
           (vl-catch-all-apply 'vlax-curve-getendparam (list ent))
  ;;  Loop until something is picked
  (while (or (and (not (setq ent (entsel "\nSelect an object:")))
                  (princ "\nMissed, Try Again."))
     (and (not (curveOK (car ent)))
  (princ "\nNo Angle, Try Again.")))
  (setq pt (vlax-curve-getclosestpointto (car ent) (cadr ent))
ent (car ent))
  (setq ang (angle '(0 0) (vlax-curve-getFirstDeriv ent (vlax-curve-getParamAtPoint ent pt))))
  (print ang)
