Author Topic: Plotstamp  (Read 9911 times)
ML
Plotstamp
« Reply #15 on: November 30, 2004, 10:18:34 AM »
Hendie
Here is the solution,
Thanks to Keith, I discovered the send command in VBA, then I created this little bit of code and put it in the begin plot event. It works like a charm
Private Sub AcadDocument_BeginPlot(ByVal DrawingName As String)
ThisDrawing.SendCommand ("-plotstamp" & vbCr & "on" & vbCr & vbCr)
hendie
Plotstamp
« Reply #16 on: November 30, 2004, 11:23:24 AM »
that's cheating !  :P
I thought you wanted to create your own Plotstamp routine, not use the bog-stndard one.
still, if it works.......
ML
Plotstamp
« Reply #17 on: November 30, 2004, 11:50:24 AM »
Cheating!
Hell, why create a whole module for something so simple?
Remember KISS :)
ML
Plotstamp
« Reply #18 on: November 30, 2004, 11:50:55 AM »
Keep it simple _______
