Author Topic: Newbie looking for simple C# examples  (Read 8271 times)
SteveK
« on: January 19, 2010, 11:51:14 PM »
I've just been through the C# Hello World example here http://www.cadalyst.com/cad/autocad/autocad-commands-c-cad-clinic-civil-3d-tutorial-3069.
Does anyone have any small C# examples I can learn from? An example would be searching a drawing for text that is green and changing it to blue.
And as an aside: is there an ssget equivalent in C#?
Thanks,
steve
« Last Edit: January 20, 2010, 12:21:38 AM by steve.k »
« Last Edit: January 22, 2010, 02:51:29 AM by Kerry Brown »
fixo
Re: Newbie looking for simple C# examples
« Reply #2 on: January 20, 2010, 04:11:59 AM »
Thanks,
steve
Here is what you asked about
Feel free to change to your suit
~'J'~
Glenn R
« Reply #3 on: January 20, 2010, 11:10:51 AM »
Start off by learning the language first - forget the autocad side of it for now, as it sounds like you're at the very beginning. You'll be glad you did in the long run.
SteveK
« Reply #4 on: January 20, 2010, 04:20:44 PM »
http://through-the-interface.typepad.com/
Cheers Kerry, that site (above) is quite good. Here's a couple I found I can read through.
Using pickfirst selection
http://through-the-interface.typepad.com/through_the_interface/2006/09/using_the_pickf.html
Creating an AutoCAD layer
http://through-the-interface.typepad.com/through_the_interface/2010/01/creating-an-autocad-layer-using-net.html
~'J'~
Thanks very much Fixo! I'll get back to you with questions   :-)
I got plenty of holes in my knowledge, but I know the basics of C++ so I'm gonna see how far I can get with that.  :?
SteveK
« Reply #5 on: January 20, 2010, 06:17:35 PM »
Fixo, I just went through your code. It actually made sense! The only thing that looks a bit foreign is the bit bracketed: "using (Transaction..."
Can I ask a few questions?...
1. Where does the object Regex come from? As in the line:
newtext = Regex.Replace(dbt.TextString, sFind, sReplace);
2. Is the
catch (Autodesk.AutoCAD.Runtime.Exception ex) the common error catcher? Ie, what if I use:
catch (...)?
3. What does
[assembly: CommandClass(typeof(SelText.TextMod))] at the top of the cs file do?
4. How does autoCAD know to run the Initialize function in InitCommand.cs? Don't we need to call it because it's in a function?
5. Out of interest, do we ever use classes apart from a single class to house our commands?
6. Lastly, I just want to make sure there's no apropos button in SharpDevelop, like there is in the Visual Lisp Editor. And the best thing to use as a quick reference is http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%20.NET%20Developer%27s%20Guide/index.html?
Thanks!!  :-)
steve
« Last Edit: January 20, 2010, 06:49:41 PM by steve.k »
« Reply #6 on: January 20, 2010, 06:59:35 PM »
1) System.Text.RegularExpressions.Regex
2) what do you mean by ; catch (...)
You catch exceptions thrown (Please Read The Documentation )
3) not mandatory, but improves loading performances. (Please Read The Documentation )
4) public class InitCommand : Autodesk.AutoCAD.Runtime.IExtensionApplication
5) yes (Please Read The Documentation )
6) You mean Intellisence ?
   re the quick reference : did you see my first link ?
regards
[edit]
RTFM changed to Please Read The Documentation
« Last Edit: January 22, 2010, 07:47:22 PM by Kerry Brown »
SteveK
« Reply #7 on: January 20, 2010, 07:42:06 PM »
Kerry, I know you know a great deal, but if you don't want to genuinely help then please don't post! Let someone else.
« Reply #8 on: January 20, 2010, 07:50:05 PM »
Steve
ALL of my answers are correct and relevant to your question.
The (Please Read The Documentation ) is for additional information.
If you expect me ( or anyone) to write a thesis to cover information already included in documentation you will be disappointed I think.
... oh, and you're welcome :)
« Last Edit: January 22, 2010, 07:48:19 PM by Kerry Brown »
SteveK
« Reply #9 on: January 20, 2010, 08:13:27 PM »
Kerry, You expect a thanks when you were being rude? There's a difference between correct and helpful.
You know yourself you posted what you did because you've either seen these questions a hundred times or you've read them countless times in the .NET manual and you think I could have found the answer if I'd searched it or the web.
In answer I have made a search for these questions. And I just like finding out details in a forum. It's how myself and countless others have learnt lisp. Yes I've read a hundred questions that boil down to the same one asked last year, but so long as someone show's an effort to learn I quite enjoy helping them along.
Anyways, that's enough of that. Thanks Kerry, question 1 was beneficial to me.
« Reply #11 on: January 20, 2010, 08:44:53 PM »
Regarding 2)
what do you mean by :
catch (...) ?
« Reply #12 on: January 20, 2010, 08:51:22 PM »
Regarding 3)
What does
[assembly: CommandClass(typeof(SelText.TextMod))]at the top of the cs file do?
do
I answered
http://www.autodesk.com/autocad-net-developers-guide
http://through-the-interface.typepad.com/through_the_interface/2006/09/optimizing_the_.html
« Reply #13 on: January 20, 2010, 08:52:47 PM »
Regarding 5)
yes.
I have no further comment other than :
If you don't know this I suggest you read Glenn's post
SteveK
« Reply #14 on: January 20, 2010, 09:33:38 PM »
Thanks Kerry.
2. Ignore this. catch (...) was an afterthought from C++. It doesn't work. My bad.
3. That link is helpful.
4. No I don't understand that, but once again those links put me on the right track I think.
5. It was more a general question I just thought an experienced C#'er could comment on. I'm sure I'll notice when I come across it, was just curious if classes are used in code that run simple autocad commands. I can't think how, and it doesn't matter.
Thanks again Kerry, and sorry I didn't mean to be a blight on your day.
