Author Topic: I need your opinions  (Read 13441 times)
M-dub
« on: November 21, 2003, 11:02:51 AM »
Although you all may not understand some of what I'm talking about, does the following message make sense to you?  I'm ready to submit these drawings and want to make sure future CADdies don't F them up.
(BTW - Sorry about the CAPS...I ain't re-typing that sh!te...)
NOTE TO CAD
1.  PAY STRICT ATTENTION TO LAYERS BEING USED.
2.  ONLY MAIN TRUNK CABLES ARE PLACED ON SPECIFIC 'COM-___' LAYERS.  ALL DROP LINES ARE TO BE PLACED ON THE SAME LAYER AS THE DEVICE BEING CONNECTED.  THE DROP LINES ARE THEN GIVEN THE SAME PROPERTIES AS THE TRUNK CABLE.  FOR EXAMPLE, THE ETHERNET TRUNK CABLE IS ON THE COM-ETHERNET LAYER WITH THE COLOUR AND LINETYPE SET TO BYLAYER.  THE DROP LINES CONNECTING TO A PLC-5/40E WILL GO ON THE DEVICE-PLC LAYER WITH THE COLOUR SET TO BLUE AND THE LINETYPE SET TO DASHED2 (COM-ETHERNET LAYER PROPERTIES).  THIS IS DONE NOT ONLY TO KEEP THE DRAWING UNIFORM, BUT IS ALSO TO KEEP IT 'TIDY' WHEN CERTAIN LAYERS ARE FROZEN.  (WHEN THE DEVICE-PLC LAYER IS FROZEN, THERE WILL NOT BE ETHERNET AND DH+ LINES STICKING OUT, NOT CONNECTED TO ANYTHING.)
(THIS NOTE IS TO REMAIN ON THE "NO-PLOT" LAYER AND IS NOT TO BE DELETED, FROZEN OR TURNED OFF)
Thanks a lot!  :wink:
Mike
daron
« Reply #1 on: November 21, 2003, 11:12:39 AM »
Sounds good.
Craig
« Reply #2 on: November 21, 2003, 11:16:21 AM »
Sounds fine to me. Apparently you've had problems in the past?
M-dub
« Reply #3 on: November 21, 2003, 11:27:20 AM »
Well, I suppose you could say that....
It's just that this group of drawings goes against the grain as far as "normal" cadding.  Normally, we try to always put stuff on a certain layer and leave the other properties as BYLAYER.  As you read above, it's quite a change from that and I just want to make sure that everyone who works on these drawings in the future knows what to do...
Thanks guys
Craig
« Reply #4 on: November 21, 2003, 11:31:26 AM »
I understand.
Dent Cermak
« Reply #5 on: November 21, 2003, 11:48:17 AM »
Makes sense to me. Ain't that scary!  :shock:
M-dub
« Reply #6 on: November 21, 2003, 11:51:49 AM »
Actually, it's good news!  If Dent can understand it, I don't think I need any more replies!
JK ;)
ELOQUINTET
« Reply #7 on: November 21, 2003, 12:50:40 PM »
makes sense to me too but do other draftsmen there read or follow instructions. they very rarely do here to my dismay. good luck...
dan
M-dub
« Reply #8 on: November 21, 2003, 12:54:21 PM »
I'm not banking on that, but at least I've proven my due diligence.
You can lead a horse to water...
But you can't make him follow simple f'ing instructions!
ELOQUINTET
« Reply #9 on: November 21, 2003, 12:58:14 PM »
then lead the horse into the water  :o
M-dub
« Reply #10 on: November 21, 2003, 01:13:13 PM »
With a new pair of cement horseshoes?
ELOQUINTET
« Reply #11 on: November 21, 2003, 01:57:54 PM »
indeed mdub
M-dub
« Reply #12 on: November 21, 2003, 02:03:26 PM »
actually, last time I checked, a horse would require TWO pairs! :)
« Reply #13 on: November 21, 2003, 04:37:53 PM »
Why don't you create a couple simple routines to set this layering for them? Or you could make a custom pulldown menu to do this. These two items would be easily distributable to whomever you are trying to get to adhere to standards.  :D
-ron
Here is one I use daily for lateral lines.
(defun c:ss () ;Shrub lateral
  (setvar 'plinegen 1)
  (setvar 'cmdecho 0)
  (setvar 'plinewid (* (getvar "dimscale") 0.0125))
  (command ".-layer" "make"     "0280-shrub-lateral"
  "color" "6"     ""  ""
  "pline"
(c:ss)
M-dub
« Reply #14 on: November 21, 2003, 04:51:32 PM »
Thanks a lot Ron,
However, once I'm done with these drawings, there's a good chance that they will never be updated again.  Plus, they'll be distributed to each brewery across Canada, so I would find that to be difficult to manage...
Great idea though!
Cheers!
