I'm having trouble here.
I want to slice all four edges off the rectangles I am making, however, to use the vla-slidesolid method, you need a solid object. Thats fine at first, but once you slice a solid, it becomes two objects. It seems like the original solid, instead of just updating, creates and entirely new object. Is there a way to keep the main solid as your "object"?
thanks,
ArgV
