huh? that make little to no sense. Here is what i got:
Command: ( (lambda (/ entry xname xpath saved-xref-name)
((_> (while
(((_> ;; itterate thru all xrefs in dwg
(((_> (setq entry (tblnext "block" (not entry)))
(((_> ;; get the first block
(((_> (if (cdr (assoc 1 entry))
((((_> ;; check to see if it has a path (is an xref)
((((_> ;;
((((_> ;; if it does..
((((_> (if (zerop (logand (cdr (assoc 70 entry)) 32))
(((((_> (princ
((((((_> (strcat
(((((((_> "\nExternal Reference is unloaded, but its saved path
is: "
(((((((_> "\""
(((((((_> (cdr (assoc 1 entry))
(((((((_> "\""
(((((((_> ))
(((((_> (princ
((((((_> (strcat "\nExternal Reference is loaded and its saved
path is: "
(((((((_> "\""
(((((((_> "\""
(((((((_> ))
(((((_> )
((((_> ) ; if
(((_> ); while
((_> (princ)
((_> )
(_> )
External Reference is loaded and its saved path is:
"C:\tmp\Xref-paths\XREFS\Drawing1.dwg"
