Poll
s
0 (0%)
s
1 (100%)
Total Members Voted: 1
Author Topic: how to get the intersectpoint  (Read 2200 times)
frtfff
« on: January 09, 2010, 10:05:31 AM »
I hope tp get a intersect point of a line and a pline .
but I don't have any idea.
Do you have any good idea?
Thank you
« Last Edit: January 11, 2010, 12:57:54 AM by Daniel »
XXL66
Re: how to get the intersectpoint
« Reply #1 on: January 09, 2010, 12:00:47 PM »
based on begin, endpoint and bulge of pline compute circle. Compute intersection circle and infinite line. Result is 0 points, 1 (tangent) point or 2 points. In case of 2 points compute which is on the bulged segment.
frtfff
« Reply #2 on: January 10, 2010, 02:35:10 AM »
 :oops:
It's Alive!
  • BricsCAD
  • AKA Daniel
« Reply #3 on: January 10, 2010, 09:16:02 AM »
  static void doit(void)
    CPromptEntityResult per1;
    CEditor::GetEntity(per1,_T("Select Line"));
    if(per1.Status != Acad::eNormal)
      acutPrintf(_T("\nCEditor::GetEntity Line %ld: "),__LINE__ );
      return;
    CPromptEntityResult per2;
    CEditor::GetEntity(per2,_T("Select PLine"));
    if(per2.Status != Acad::eNormal)
      return;
    AcDbEntityPointer pEnt1(per1.ObjectId, AcDb::kForRead);
    if(pEnt1.openStatus() != Acad::eOk)
      acutPrintf(_T("\npEnt1.openStatus() Line %ld: "),__LINE__ );
      return;
    AcDbEntityPointer pEnt2(per2.ObjectId, AcDb::kForRead);
    if(pEnt2.openStatus() != Acad::eOk)
      acutPrintf(_T("\npEnt2.openStatus() Line %ld: "),__LINE__ );
      return;
    AcDbCurve *pLine = AcDbCurve::cast(pEnt1);
    if(!pLine)
      acutPrintf(_T("\npLine is Null Line %ld: "),__LINE__ );
      return;
    AcDbCurve *pPline = AcDbCurve::cast(pEnt2);
    if(!pPline)
      acutPrintf(_T("\npPline is Null Line %ld: "),__LINE__ );
      return;
    AcGePoint3dArray pts;
    if(pLine->intersectWith(pPline,AcDb::kExtendThis,pts) != eOk)
      acutPrintf(_T("\npLine->intersectWith Line %ld: "),__LINE__ );
      return;
    for(size_t i=0;i<pts.length();i++)
      acutPrintf(_T("\n@ %g,%g,%g"),pts[i].x,pts[i].y,pts[i].z);
frtfff
« Reply #4 on: January 10, 2010, 10:43:00 PM »
// This is the revised code from Mr.Daneal
//CPromptEntityResult per1;
//CEditor::GetEntity(per1,_T("Select Line"));
ads_name line_sel;
ads_point pt_line;
//acedEntSel(_T("\nSelect First line:"),line_sel,pt_line);
if(acedEntSel(_T("\nSelect line:"),line_sel,pt_line) != Acad::eNormal)
return;
//CPromptEntityResult per2;
//CEditor::GetEntity(per2,_T("Select PLine"));
ads_name pilne_sel;
ads_point Pt_pline;
if(acedEntSel(_T("\nSelect Pline:"),pilne_sel,Pt_pline) != Acad::eNormal)
return;
AcDbObjectId lineId,plineId;
acdbGetObjectId(lineId,line_sel);
acdbGetObjectId(plineId,pilne_sel);
//AcDbEntityPointer pEnt1(lineId, AcDb::kForRead);
//AcDbEntityPointer pEnt2(plineId, AcDb::kForRead);
AcDbEntity *pEnt1,*pEnt2;
acdbOpenObject(pEnt1,lineId,AcDb::kForRead);
acdbOpenObject(pEnt2,plineId,AcDb::kForRead);
if(!pLine)
return;
if(!pPline)
return;
return;
pEnt1->close();
pEnt2->close();
//The question is the first point and the final point doesn't work here.What happened?
« Last Edit: January 10, 2010, 11:08:22 PM by Daniel »
frtfff
« Reply #5 on: January 10, 2010, 10:47:42 PM »
 :kewl:
frtfff
« Reply #6 on: January 10, 2010, 10:50:35 PM »
We should get four datas for every condition.But it doesn't work.
It's Alive!
  • BricsCAD
  • AKA Daniel
« Reply #7 on: January 11, 2010, 12:57:02 AM »
I guess it does not like Collinear segments
BTY AcDbEntityPointer is in Acad/Briciscad :),
I will post my promtresult classes one of these days
« Last Edit: January 11, 2010, 01:01:17 AM by Daniel »
frtfff
« Reply #8 on: January 11, 2010, 03:35:24 AM »
 :pissed:
