Author Topic: Set default for getpoint  (Read 2587 times)
« on: November 17, 2004, 11:50:30 AM »
I am inserting our title blocks with lisp and was wondering how to make the insertion point default to 0,0 if the user hits enter. Does it have something to do with initgat?
 (initget 1)
  (setq pt (getpoint "\nPick Titleblock Location: "))
  (command ".-layer"
  "m"
  "m-sheet"
  ".-INSERT"
  "Aei8.5x11=Aei8.5x11.dwg"
  pt
  "1"
  "1"
  "0"
Thanks,
Ron
« Reply #1 on: November 17, 2004, 12:08:27 PM »
Remove the (initget 1)
and use
(if (null pt) (setq pt '(0 0 0)))
Does not trap bad numeric entry from user.
« Reply #2 on: November 17, 2004, 12:08:56 PM »
(setq pt (getpoint "\nInsertion Point:<0,0,0> "))
;; if you hit <enter> at this prompt 'getpoint' returns 'nil'
(not (setq pt (getpoint "\nInsertion Point:<0,0,0> ")))
;; this returns 'T' if the user hits <enter>
;; so our test is to see of the user hit <enter> or picked a point
(if (not (setq pt (getpoint "\nInsertion Point:<0,0,0> ")))
  (prompt "\nUser hit <enter>")
  ;else
  (prompt "\nUser picked a point")
« Reply #3 on: November 17, 2004, 12:23:21 PM »
Thanks guys....I'll learn this lisp stuff someday :)
daron
« Reply #4 on: November 17, 2004, 02:00:08 PM »
Do you need to use getpoint if you already know where you want your blocks placed?
(command ".-insert" "blockname" '(0.0 0.0) "1" """")
Something like that.
« Reply #5 on: November 17, 2004, 04:27:53 PM »
I wanted to let the user be able to select a point......but most of the time the insertion will be 0,0.
Ron
taner
Re: Set default for getpoint
« Reply #6 on: September 26, 2008, 11:16:03 PM »
Ron
http://paracadd.com/lisp.htm#external
upoint.lsp
