if not Global Mapper will convert them to a usable format...
Quote from: mjfarrell on January 07, 2010, 12:35:10 pmif not Global Mapper will convert them to a usable format...'usable' as in keeping the georeference bits in tact?
Quote from: Mark on January 07, 2010, 02:26:33 pmQuote from: mjfarrell on January 07, 2010, 12:35:10 pmif not Global Mapper will convert them to a usable format...'usable' as in keeping the georeference bits in tact?as in to another file format...the geo portion will most likely be of no use to LT...however I think the answer is yes...
Quote from: mjfarrell on January 07, 2010, 04:01:20 pmQuote from: Mark on January 07, 2010, 02:26:33 pmQuote from: mjfarrell on January 07, 2010, 12:35:10 pmif not Global Mapper will convert them to a usable format...'usable' as in keeping the georeference bits in tact?as in to another file format...the geo portion will most likely be of no use to LT...however I think the answer is yes...So what happened with the release of 2010. We installed the object enabler, http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13170708&linkID=9240818 , for 2010LT but we are not able to see any images! So what else could be wrong?Did they go and break a good thing!?!?
your link points to this:AutoCAD Architecture & AutoCAD MEP 2010 Object Enabler (32-bit and 64-bit)
somehow I do NOT see the MEP enabler doing anything of any good for you
Quote from: mjfarrell on March 08, 2010, 11:30:13 amsomehow I do NOT see the MEP enabler doing anything of any good for you I know that MEP will not work for us but this was how we were able to view images last year. It would be a shame that they would strip that funcionality out of the object enabler.
Being able to see images in LT is not related to object enablers. Instead of pursuing that path, tell us exactly what's happening and what you expect to happen, with as many details related to setup & process as possible.
