Author Topic: [Help] Converting a string with special characters into a series of lists  (Read 10133 times)
nivuahc
Re: [Help] Converting a string with special characters into a series of lists
« Reply #15 on: January 06, 2010, 01:29:36 PM »
The only issue I have, now, is trying to get that damned Title row to not show up... I mean, I tried setting vla-put-titlesuppressed to every value I can think of and it doesn't seem to make a bit of difference.  :ugly:
Any ideas?  :?
(vlax-invoke table 'DeleteRows 0 1)   :oops:
nivuahc
« Reply #16 on: January 06, 2010, 02:30:28 PM »
So that begs the question: What the heck is TitleSuppressed good for?
« Reply #17 on: January 06, 2010, 02:43:29 PM »
Do you suppress the header row also?  Or do you want to keep that?  When I have done tables in code, I coded it like (vla-put-TitleSuppressed Tbl :vlax-false) and that worked for me.
nivuahc
« Reply #18 on: January 06, 2010, 02:58:02 PM »
I've tried
(vlax-put Tbl 'TitleSuppressed :vlax-true)
(vlax-put Tbl 'TitleSuppressed -1)
but never
(vla-put-TitleSuppressed Tbl :vlax-true)
I'll have to give that a whirl (though it shouldn't make a difference, should it?).
« Reply #19 on: January 06, 2010, 02:59:26 PM »
You'd be surprised, I remember Tim helping me figure out something with a bunch of Viewports, and it all came down to something like that...
nivuahc
« Reply #20 on: January 06, 2010, 03:05:30 PM »
Yeah, Tim can be pretty amazing. But that method didn't do it either.  :|
« Reply #21 on: January 06, 2010, 03:48:40 PM »
Here is how I create mine
(setq Tbl (vlax-invoke CurSpace 'AddTable StPt (length StrList) MaxCol TxtHt 1.0))
(if (= ShowTitle "Yes")
(if (= ShowHeader "Yes")
    (vla-put-HeaderSuppressed Tbl :vlax-false)
    (vla-put-HeaderSuppressed Tbl :vlax-true)
(vla-SetAlignment Tbl acTitleRow 5)
(vla-SetAlignment Tbl acHeaderRow 5)
(vla-SetAlignment Tbl acDataRow TxtAli)
(vla-put-RegenerateTableSuppressed Tbl :vlax-true)
After is when I start filling in all the information.  This has worked before without error.  It's been tested on '04 and '06 for sure.  What version are you using?
sidenote:  You guys trying to make me blush? ... Thanks for the kind words...
