Author Topic: How to statistics the total number of parts?  (Read 19474 times)
xianaihua
« on: January 05, 2010, 07:23:28 AM »
Hello all,
I want to assemble a body of statistics for each sub-assembly and parts of the total numbers,
Their assembly relation is shown below.
The number behind each piece, but the pieces in the last one in a number of sub-assembly.
According to bom of each dwg,I constructed the following list:
("sub-assembly1-1" "assembly" 2)
("sub-assembly1-2" "assembly" 3)
("sub-assembly1-3" "assembly" 2)
("pat1-1" "assembly" 3)
("pat1-2" "assembly" 2)
("pat1-3" "assembly" 1)
("sub-assembly2-1" "sub-assembly1-1" 3)
("sub-assembly2-2" "sub-assembly1-1" 3)
("sub-assembly2-3" "sub-assembly1-1" 2)
("pat2-1" "sub-assembly1-1" 3)
("pat2-2" "sub-assembly1-1" 2)
("pat1-3" "sub-assembly1-1" 1)
("pat3-1" "sub-assembly2-1" 3)
("pat3-2" "sub-assembly2-1" 2)
("pat2-1" "sub-assembly2-1" 1)
Example:total numbers of "pat3-1"=3X3X2X1
That,numbers of "pat3-1" in the "sub-assembly2-1" *  numbers of "sub-assembly2-1" in the "sub-assembly1-1" * numbers of "sub-assembly1-1" in the "assembly" *  numbers of "assembly"(By default, the top-level assembly's number is one)
I want to have a recursive algorithm, was the total number of new list
("sub-assembly1-1" "assembly" 2 2);2X1
("sub-assembly1-2" "assembly" 3 3);3X1
("sub-assembly1-3" "assembly" 2 2);2X1
("pat1-1" "assembly" 3 3);3X1
("pat1-2" "assembly" 2 2);2X1
("pat1-3" "assembly" 1 1);1X1
("sub-assembly2-1" "sub-assembly1-1" 3 6);3X2X1
("sub-assembly2-2" "sub-assembly1-1" 3 6);3X2X1
("sub-assembly2-3" "sub-assembly1-1" 2 4);2X2X1
("pat2-1" "sub-assembly1-1" 3 6);3X2X1
("pat2-2" "sub-assembly1-1" 2 4);2X2X1
("pat1-3" "sub-assembly1-1" 1 2);1X2X1
("pat3-1" "sub-assembly2-1" 3 18);3X3X2X1
("pat3-2" "sub-assembly2-1" 2 12);2X3X2X1
("pat2-1" "sub-assembly2-1" 1 6);1X3X2X1
All friends, how to do this recursively?
First of all, thanks !
« Last Edit: January 05, 2010, 06:28:24 PM by xianaihua »
xianaihua
Re: How to statistics the total number of parts?
« Reply #1 on: January 05, 2010, 09:56:54 PM »
Hi all..
Anyone have an idea on how to get tol numbers of parts?
thanks.
« Reply #2 on: January 05, 2010, 10:25:00 PM »
Maybe tomorrow, I'm done for the day. :-)
xianaihua
« Reply #3 on: January 06, 2010, 06:56:47 PM »
I look forward to the guidance of CAB, and other masters! :-D
« Reply #4 on: January 06, 2010, 07:28:56 PM »
Here is a start.  You can do the recursion changes to make it do what you want exactly.
(defun ShowBlockNesting ( blkName blkCol / tempList tempName NestingList)
    (if (not (vl-catch-all-error-p (setq BlkObj (vl-catch-all-apply 'vla-Item (list blkCol blkName)))))
        (vlax-for obj BlkObj
            (if (= (vla-get-ObjectName obj) "AcDbBlockReference")
                (if (setq tempList (assoc (setq tempName (vla-get-Name obj)) NestingList))
                    (setq NestingList (subst (cons tempName (1+ (cdr tempList))) tempList NestingList))
                    (setq NestingList (cons (cons tempName 1) NestingList))
    (cons blkName NestingList)
(defun c:Test ()
    (showblocknesting (cdr (assoc 2 (entget (car (entsel))))) (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))))
adalea03
« Reply #5 on: January 06, 2010, 08:13:09 PM »
No master here, but I would block everything (with attributes).
SSget all the parts, and drill through list(s) , counting as you go.
Sound so simmple, doesn't it?
i.e.
Block A contains 4 distint parts .
Get/count all instances of block A.
(List "Block A" integer-blockcountA  ("subpart1" (* integer-blockcountA qty-subpart1))  ("subpart2" (* integer-blockcountA qty-subpart2)))
                                                        ("subpart3" (* integer-blockcountA qty-subpart3)))  ("subpart4" (* integer-blockcountA) qty-subpart4)))
Block B contains 12 distint parts .
(List "Block B" integer-blockcountB  ("subpart1" (* integer-blockcountB qty-subpart1))   ...
There may be a lot  of "hard coding" necessary to achieve your goal,
but if your needs are specific to your discipline ,
just "Get 'er done", any 'ole way you can.
AA
adalea03
« Reply #6 on: January 06, 2010, 08:25:58 PM »
Better yet, follow T.Wiley.
xianaihua
« Reply #7 on: January 07, 2010, 06:10:08 AM »
thanks,
Sorry, my English is poor, not explained clearly.
Now, regardless of anything else, we can reduce the problem only to the list of recursive processing.
In accordance with the above requirements, how the recursive computation of the list? Please express anyone's idea and suggestions!
« Reply #8 on: January 07, 2010, 09:21:19 AM »
Why does it have to be recursive? Is this a homework assignment?
xianaihua
« Reply #9 on: January 07, 2010, 10:10:47 AM »
hi,CAB!
Of course, do not use the recursive method can also be!Doing mechanical design, we often have statistical part quantity.Bom assembly drawings of each style is shown below
« Last Edit: January 07, 2010, 10:27:54 AM by xianaihua »
« Reply #10 on: January 07, 2010, 11:33:00 AM »
« Reply #11 on: January 07, 2010, 11:33:35 AM »
I think because I said recursive, as that lends itself to these type of situations.
« Reply #12 on: January 07, 2010, 12:05:14 PM »
Thanks Tim, but at the end of the Op's first post:
From futher postings it is obviously not Homework, from school anyway.  :-)
« Reply #13 on: January 07, 2010, 12:12:52 PM »
You pay better attention that I do Alan, as I didn't even see that requirement.   :-D
« Reply #14 on: January 07, 2010, 12:32:33 PM »
