Author Topic: Lisp Catalogue  (Read 3774 times)
bman
Lisp Catalogue
« on: November 16, 2004, 08:58:54 AM »
Does someone have a program that catalogues your lisp routines to where you can give a brief description as to what each routine does?
hudster
Lisp Catalogue
« Reply #1 on: November 16, 2004, 09:02:44 AM »
CADALYST
you'll find one here, pretty good one by Jefferey P Saunders.
Look for the Lisp Manager
bman
Lisp Catalogue
« Reply #2 on: November 16, 2004, 11:47:05 AM »
thanks HUD
PDJ
Lisp Catalogue
« Reply #3 on: November 16, 2004, 12:47:53 PM »
I was gonna post this to the Lillypond but that dang thing confuddles me everytime.. This is an earlier one from Cadalyst.  2002 I believe.. So, here goes:
;Tip1775:  LIB.LSP          MANAGE ROUTINES       (c)2002, Roy Everitt
;;;   Lib.lsp
;;;   Permission to use, copy, modify, and distribute this software and its
;;;   documentation for any purpose and without fee is hereby granted.
;;;   THIS SOFTWARE IS PROVIDED "AS IS" WITHOUT EXPRESS OR IMPLIED WARRANTY.
;;;   ALL IMPLIED WARRANTIES OF FITNESS FOR ANY PARTICULAR PURPOSE AND OF
;;;   MERCHANTABILITY ARE HEREBY DISCLAIMED.
;;;   Copyright© Roy Everitt
;;;   March, 2000
;;;   Note: Older versions of Autocad will not recognize the *error* function. You will
;;;         need to replace the (defun-q *error* (msg) statement with (defun *error* (msg).
;;;   This program allows you to add all of your favorite lisp routines to an easily modified
;;;   list, then execute them from a list box selection.
;;;   Step 1. Define your preferences for functions that execute your programs.
;;;           Example: (DEFUN C:Table ()(Load "Table") (c:Table))...see below "dlg_main" function.
;;;   Step 2. Add a Quoted description to the list in "set_pgm_name" function for your program.
;;;           Example: "Add a Chart or (Table) to your drawing (c:Table)"
;;;           Note: This list will automatically be sorted by the acad_strlsort function as coded.
;;;           Use the sample programs table.lsp, altext.lsp, half.lsp & ct.lsp to test lib.lsp
;;;           for compatibility with your settings. Be sure to change the *error* function from
;;;           (defun-q *error* (msg) to (defun-q *error* (msg), in the table.lsp program, with older
;;;           versions of Autocad.
;;;   Step 3. Add each equivalant description to the (if ()) statement test for each "lsp_name" list
;;;           element, from the "set_pgm_name" function, into the "runit" function, in order for this
;;;           program to execute the selected program from the list.
;;;           Example:(if (= lsp_name "Add a Chart or (Table) to your drawing (c:Table)")(c:Table))
;;;   You might also want to automatically load this program from the appload "Startup Suite"
;;;   in Autocad 2000 or other programs such as (defun S::STARTUP function in acad.lsp with older
;;;   versions of Autocad. This will also allow command line program execution from the functions
;;;   established in Step 1. It will also help prevent unnecessarily loading programs, when they
;;;   may not be used during the current drawing editing session, thus saving computer memory.
;;;   This program can also be used as a "Front End" loader for other functions that you might
;;;   want to have available for access by other programs as well, rather than re-defining those
;;;   functions in each individual program using them. Some examples of typical functions that
;;;   might be used are listed at the end of this file (dtor),(rtod) & (chk_acadver).
;;;   The program also generates a custom DCL file (temp.dcl) that is re-written each
;;;   time it is executed. The code may be changed so that temp.dcl is written to, and
;;;   found in any user preferred folder, as long as that folder is in the Support Files
;;;   Search Path.
;;;   Note: By default, it will be written in your Autocad Working Directory, (wherever
;;;         your shortcut or "Start In" Icon is set up to work).
;;;   Example: Look for the code: (setq fd (open "temp.dcl" "w"))
;;;            Change it to: (setq fd (open "c:\\myfolder\\temp.dcl" "w"))
;;;            Look for the code: (close (open "temp.dcl" "w") )
;;;            Change it to: (close (open "c:\\myfolder\\temp.dcl" "w") )
;;;            Look for the code: (if (< (setq *libid* (load_dialog "temp.dcl")) 0)
;;;            Change it to: (if (< (setq *libid* (load_dialog "c:\\myfolder\\temp.dcl")) 0)
;;;                          (Where "myfolder" is your designated folder name)
(princ "\Lib Program Loading...")
(defun
   C:LIB (/ OL OS OC CR DLG_CLOSE FD DLG_HEADER DLG_MAIN DLG_DIALOG
          DLG_CHK DLG_ITEM DLG_ATT SYMTOS DLG_PROTO DCL_TEMP
          SET_PGM_NAME PGM_LIST PGM_NUM NUM GET_PGM_LIST LSP_NAME
          *LIBID* CATEGORY PICK_CATEGORY NO_OF_LSPS ACADREL
;;;;;MAIN DIALOG CONTROL FUNCTIONS;;;;
  (defun CR () (princ "\n" FD))
  (defun DLG_CLOSE () (princ "}" FD) (CR))
  (defun
     DLG_HEADER (AUDIT)
    (princ "dcl_settings : default_dcl_settings {" FD)
    (CR)
    (princ (strcat " audit_level = " (itoa AUDIT) "; }") FD)
    (CR)
  ) ;_ end of defun
  (defun DLG_DIALOG (NAME) (princ (strcat NAME " : dialog {") FD) (CR))
  (defun DLG_ITEM (ITEM) (princ (strcat ": " ITEM "{") FD) (CR))
  (defun DLG_PROTO (type) (princ (strcat type ";") FD) (CR))
  (defun
     DLG_ATT (ATT VAL)
      ((= (type VAL) 'INT)
       (princ (strcat ATT "=" (itoa VAL) ";") FD)
       (CR)
      ((= (type VAL) 'REAL)
       (princ (strcat ATT "=" (rtos VAL) ";") FD)
       (CR)
      ((= (type VAL) 'STR)
       (princ (strcat ATT "=\"" VAL "\";") FD)
       (CR)
      ((= (type VAL) 'SYM)
       (princ (strcat ATT "=" (SYMTOS VAL) ";") FD)
       (CR)
    ) ;_ end of cond
  ) ;_ end of defun
  (defun
     SYMTOS (SYM / FD)
    (setq FD (open "symtos.txt" "w"))
    (princ SYM FD)
    (close FD)
    (setq
      FD  (open "symtos.txt" "r")
      SYM (strcase (read-line FD) t)
    ) ;_ end of setq
    (close FD)
    SYM
  ) ;_ end of defun
  (defun
     DCL_TEMP (/ FD)
    (setq FD (open "temp.dcl" "w"))
    (DLG_HEADER 0)
;;;Define Main Dialog;;;
    (DLG_DIALOG "dlg_main")
    (DLG_ATT "label" "Lisp Library Program Execution :")
    (DLG_ITEM "popup_list")
    (DLG_ATT "label" "Lisp Category Group:")
    (DLG_ATT "multiple_select" 'FALSE)
    (DLG_ATT "key" "cat_lst")
    (DLG_ATT "width" 15)
    (DLG_CLOSE)
    (DLG_ITEM "text")
    (DLG_ATT "width" "20")
    (DLG_ATT "key" "no_of_lsps")
    (DLG_CLOSE)
    (DLG_ITEM "list_box")
    (DLG_ATT
      "label"
      "Available Program Descriptions along with their Commands (c:XXXX)"
    ) ;_ end of dlg_att
    (DLG_ATT "height" 10)
    (DLG_ATT "width" 60)
    (DLG_ATT "key" "pgm_list")
    (DLG_ATT "fixed_width" 'TRUE)
    (DLG_CLOSE)
    (DLG_ITEM "button")
    (DLG_ATT "key" "run_pgm")
    (DLG_ATT "label" "Execute Selected Program")
    (DLG_ATT "height" 2)
    (DLG_ATT "alignment" 'CENTERED)
    (DLG_CLOSE)
    (DLG_PROTO "cancel_button")
    (DLG_CLOSE)
    (close FD)
    "temp.dcl"
 ;********************Set Category List Function***********************
  ;;define your Program Category lists here.
  (defun
     SET_CATEGORY_LIST ()
    (setq
      CATEGORY_LIST
       (list
         "ALL" "BATCH PROCESS DRAWINGS" "CALCULATIONS" "CONVERSONS"
         "DIMENSIONING" "FUNCTIONS" "ISOMETRIC TOOLS"
         "LAYERING UTILITIES" "LEADERS-ARROWS" "MISC" "LINES-POLYLINES"
         "AUTOCAD SETTINGS" "TEXT" "DRAWING SHAPES"
        ) ;_ end of list
    ) ;_ end of setq
    (if (<= (getvar "maxsort") (length CATEGORY_LIST))
        (setq MSORT (getvar "maxsort"))
        (setvar "maxsort" (length CATEGORY_LIST))
        (setq CATEGORY_LIST (acad_strlsort CATEGORY_LIST))
        (setvar "maxsort" MSORT)
      ) ;_ end of progn
    ) ;_ end of if
    (start_list "cat_lst")
    (mapcar 'add_list CATEGORY_LIST)
    (end_list)
 ;********************Set Program List Function***********************
  ;;define your program lists here, along with their commands for execution.
  (defun
     SET_PGM_NAME (/ CAT_PICK)
    ;;*****************Examples List from Samples Programs*******************
    ;;Add your "All" Lists here and also in their Sub-Category...
    (if (= CATEGORY "ALL")
        (setq
          PGM_LIST
           (list
             "Align Text along (2) Points (c:At)"
             "Center a Text string between (2) Points (c:Ct)"
             "Locate the Midpoint of any (2) selected Points (c:H)"
             "Program Description Example 1  (c:XXX1)"
             "Program Description Example 2  (c:XXX2)"
             "Program Description Example 3  (c:XXX3)"
             "Program Description Example 4  (c:XXX4)"
             "Program Description Example 5  (c:XXX5)"
             "Program Description Example 6  (c:XXX6)"
             "Program Description Example 7  (c:XXX7)"
             "Program Description Example 8  (c:XXX8)"
             "Program Description Example 9  (c:XXX9)"
            ) ;_ end of list
        ) ;_ end of setq
      ) ;_ end of progn
    ) ;_ end of if
;;;Add your "Batch" Lists here...
    (if (= CATEGORY "BATCH PROCESS DRAWINGS")
        (setq
          PGM_LIST
           (list
             "Batch Program Example 1  (c:XXX1)"
             "Batch Program Example 2  (c:XXX2)"
             "Batch Program Example 3  (c:XXX3)"
           ) ;_ end of list
        ) ;_ end of setq
      ) ;_ end of progn
    ) ;_ end of if
;;;Add your "Calculation" Lists here...
    (if (= CATEGORY "CALCULATIONS")
        (setq
          PGM_LIST
           (list
             "Calculation Program Example 1  (c:XXX1)"
             "Calculation Program Example 2  (c:XXX2)"
             "Calculation Program Example 3  (c:XXX3)"
           ) ;_ end of list
        ) ;_ end of setq
      ) ;_ end of progn
    ) ;_ end of if
;;;Add your "Conversion" Lists here...
    (if (= CATEGORY "CONVERSONS")
        (setq
          PGM_LIST
           (list
             "Conversion Program Example 1  (c:XXX1)"
             "Conversion Program Example 2  (c:XXX2)"
             "Conversion Program Example 3  (c:XXX3)"
           ) ;_ end of list
        ) ;_ end of setq
      ) ;_ end of progn
    ) ;_ end of if
;;;Add your "Dimensioning" Lists here...
    (if (= CATEGORY "DIMENSIONING")
        (setq
          PGM_LIST
           (list
             "Dimensioning Program Example 1  (c:XXX1)"
             "Dimensioning Program Example 2  (c:XXX2)"
             "Dimensioning Program Example 3  (c:XXX3)"
           ) ;_ end of list
        ) ;_ end of setq
      ) ;_ end of progn
    ) ;_ end of if
;;;Add your "Functions" Lists here...
    (if (= CATEGORY "FUNCTIONS")
        (setq
          PGM_LIST
           (list
             "Functions Program Example 1  (c:XXX1)"
             "Functions Program Example 2  (c:XXX2)"
             "Functions Program Example 3  (c:XXX3)"
           ) ;_ end of list
        ) ;_ end of setq
      ) ;_ end of progn
    ) ;_ end of if
;;;Add your "Isometric" Lists here...
    (if (= CATEGORY "ISOMETRIC TOOLS")
        (setq
          PGM_LIST
           (list
             "Isometric Program Example 1  (c:XXX1)"
             "Isometric Program Example 2  (c:XXX2)"
             "Isometric Program Example 3  (c:XXX3)"
           ) ;_ end of list
        ) ;_ end of setq
      ) ;_ end of progn
    ) ;_ end of if
;;;Add your "Layering" Lists here...
    (if (= CATEGORY "LAYERING UTILITIES")
        (setq
          PGM_LIST
           (list
             "Layering Program Example 1  (c:XXX1)"
             "Layering Program Example 2  (c:XXX2)"
             "Layering Program Example 3  (c:XXX3)"
           ) ;_ end of list
        ) ;_ end of setq
      ) ;_ end of progn
    ) ;_ end of if
;;;Add your "Leaders-Arrows" Lists here...
    (if (= CATEGORY "LEADERS-ARROWS")
        (setq
          PGM_LIST
           (list
             "Leaders-Arrows Program Example 1  (c:XXX1)"
             "Leaders-Arrows Program Example 2  (c:XXX2)"
             "Leaders-Arrows Program Example 3  (c:XXX3)"
           ) ;_ end of list
        ) ;_ end of setq
      ) ;_ end of progn
    ) ;_ end of if
;;;Add your "Miscellaneous" Lists here...
    (if (= CATEGORY "MISC")
        (setq
          PGM_LIST
           (list
             "Miscellaneous Program Example 1  (c:XXX1)"
             "Miscellaneous Program Example 2  (c:XXX2)"
             "Miscellaneous Program Example 3  (c:XXX3)"
           ) ;_ end of list
        ) ;_ end of setq
      ) ;_ end of progn
    ) ;_ end of if
;;;Add your "Lines-Polylines" Lists here...
    (if (= CATEGORY "LINES-POLYLINES")
        (setq
          PGM_LIST
           (list
             "Lines-Polylines Program Example 1  (c:XXX1)"
             "Lines-Polylines Program Example 2  (c:XXX2)"
             "Lines-Polylines Program Example 3  (c:XXX3)"
           ) ;_ end of list
        ) ;_ end of setq
      ) ;_ end of progn
    ) ;_ end of if
;;;Add your "Autocad Settings" Lists here...
    (if (= CATEGORY "AUTOCAD SETTINGS")
        (setq
          PGM_LIST
           (list
             "Autocad Settings Program Example 1  (c:XXX1)"
             "Autocad Settings Program Example 2  (c:XXX2)"
             "Autocad Settings Program Example 3  (c:XXX3)"
           ) ;_ end of list
        ) ;_ end of setq
      ) ;_ end of progn
    ) ;_ end of if
;;;Add your "Text" Lists here...
    (if (= CATEGORY "TEXT")
        (setq
          PGM_LIST
           (list
             "Text Program Example 3  (c:XXX3)"
             "Text Program Example 4  (c:XXX4)"
             "Text Program Example 5  (c:XXX5)"
            ) ;_ end of list
        ) ;_ end of setq
      ) ;_ end of progn
    ) ;_ end of if
;;;Add your "Drawing Shapes" Lists here...
    (if (= CATEGORY "DRAWING SHAPES")
        (setq
          PGM_LIST
           (list
             "Drawing Shapes Program Example 1  (c:XXX1)"
             "Drawing Shapes Program Example 2  (c:XXX2)"
             "Drawing Shapes Program Example 3  (c:XXX3)"
           ) ;_ end of list
        ) ;_ end of setq
      ) ;_ end of progn
    ) ;_ end of if
    (if (<= (getvar "maxsort") (length PGM_LIST))
        (setvar "maxsort" (length PGM_LIST))
        (setq PGM_LIST (acad_strlsort PGM_LIST))
      ) ;_ end of progn
    ) ;_ end of if
    (start_list "pgm_list")
    (mapcar 'add_list PGM_LIST)
    (end_list)
    (setq NO_OF_LSPS (rtos (length PGM_LIST) 2 0))
    (set_tile "no_of_lsps" (strcat "Number of Programs : " NO_OF_LSPS))
  ) ;_ end of defun
  (defun
     PICK_CATEGORY ()
    (setq CATEGORY (nth (atoi CAT_PICK) CATEGORY_LIST))
 ;********************GET Program from List FUNCTION***********************
  (defun
     GET_PGM_LIST ()
    (setq PGM_NUM (atoi (get_tile "pgm_list")))
    (setq PGM (nth PGM_NUM PGM_LIST))
    (setq LSP_NAME PGM)
 ;********************RUN Program from List FUNCTION***********************
  ;;Define your Program Equivalants from the "set_pgm_name" List Function above, in order to Execute.
  (defun
     RUNIT ()
    (if (= LSP_NAME "Add a Chart or (Table) to your drawing (c:Table)")
      (C:TABLE)
    ) ;_ end of if
    (if (= LSP_NAME "Align Text along (2) Points (c:At)")
      (C:AT)
    ) ;_ end of if
    (if (= LSP_NAME "Center a Text string between (2) Points (c:Ct)")
      (C:CT)
    ) ;_ end of if
    (if (= LSP_NAME
        ) ;_ end of =
      (C:H)
    ) ;_ end of if
    (if (= LSP_NAME "Program Description Example 5 (c:XXX5)")
      (C:XXX5)
    ) ;_ end of if
    (if (= LSP_NAME "Program Description Example 6 (c:XXX6)")
      (C:XXX6)
    ) ;_ end of if
    (if (= LSP_NAME "Program Description Example 7 (c:XXX7)")
      (C:XXX7)
    ) ;_ end of if
    (if (= LSP_NAME "Program Description Example 8 (c:XXX8)")
      (C:XXX8)
    ) ;_ end of if
    (if (= LSP_NAME "Program Description Example 9 (c:XXX9)")
      (C:XXX9)
    ) ;_ end of if
  ) ;_ end of defun
  (defun
     DLG_CHK ()
    (if (/= LSP_NAME NIL)
      (progn (setq FLAG 1) (done_dialog))
        (setq FLAG t)
        (alert
          "\nThere is nothing to Execute....\nPlease make a selection from the List!\n\n"
        ) ;_ end of alert
      ) ;_ end of progn
    ) ;_ end of if
  ) ;_ end of defun
  (defun
     DLG_MAIN (/ FLAG)
    (setvar "cmdecho" 0)
    (if (= CATEGORY NIL)
      (setq CATEGORY "ALL")
    ) ;_ end of if
    (close (open "temp.dcl" "w"))
    (if (not (new_dialog "dlg_main" *LIBID*))
      (exit)
    ) ;_ end of if
    (SET_CATEGORY_LIST)
    (SET_PGM_NAME)
    (action_tile
      "cat_lst"
      "(setq cat_pick $value)(pick_category)(set_pgm_name)"
    ) ;_ end of action_tile
    (action_tile "pgm_list" "(get_pgm_list)")
    (action_tile "run_pgm" "(dlg_chk)")
    (action_tile "cancel" "(setq flag 0)(done_dialog)")
    (start_dialog)
    (if (= FLAG 1)
      (RUNIT)
    ) ;_ end of if
    (princ "" FD)
    (close FD)
  ) ;_ end of defun
;;; Define Error Routine ;;;
  (setq LIB_ERR *ERROR*)
  (defun-q
    *ERROR*
    (MSG)
    (princ MSG)
    (princ "" FD)
    (close FD)
    (setq *ERROR* LIB_ERR)
  ) ;_ end of defun-q
;;; Perform creation of dialog, Load dialog & set global Handle (*libid*) ;;;
  (if (not *LIBID*)
;;; first time thru
      (DCL_TEMP)
      (if (< (setq *LIBID* (load_dialog "temp.dcl")) 0)
        (*ERROR* "Dialog Load Error")
      ) ;_ end of if
    ) ;_ end of progn
  ) ;_ end of if
  (DLG_MAIN)
;;;   RESTORE ERROR HANDLER AND EXIT   ;;;
  (terpri)
  (*ERROR* "Lib program finished...")
) ;_ end of defun
(princ "Loaded")
(princ "\n->Defined command...Lib")
(terpri)
;;; Degrees to Radius
(defun DTOR (DEGREE) (* DEGREE (/ pi 180.0)))
;;; Radius to Degrees
(defun RTOD (RADIAN) (* RADIAN (/ 180.0 pi)))
;;; Check for current version of Autocad
(defun
   CHK_ACADVER ()
  (if (wcmatch (getvar "ACADVER") "*12*")
    (setq ACADREL "12")
  ) ;_ end of If
  (if (wcmatch (getvar "ACADVER") "*13*")
    (setq ACADREL "13")
  ) ;_ end of If
  (if (wcmatch (getvar "ACADVER") "*14*")
    (setq ACADREL "14")
  ) ;_ end of If
  (if (wcmatch (getvar "ACADVER") "*15*")
    (setq ACADREL "15")
  ) ;_ end of If
) ;_ end of defun
;;; FUNCTIONS TO SETUP LISP ROUTINES FOR AUTO-LOADING THE FIRST TIME THEY ARE
;;; CALLED, EITHER FROM THE COMMAND LINE OR FROM THIS PROGRAM'S LIST BOX EXECUTION.
;;;Add your custom programs and define their loading functions here...
(defun
   C:AT ()
  (load "Altext") ;Align text along (2) endpoints
  (C:AT)
) ;Has option for vertical & oblique text.
(defun
   C:CT ()
  (load "Ct") ;Center text between (2) pick points.
  (C:CT)
) ;_ end of DEFUN
(defun
   C:H ()
  (load "Half") ;Divide any (2) pick points in half and place
  (C:H)
) ;a node point between them for reference.
(defun
   C:TABLE ()
  (load "Table") ;Add a Chart or (Table) to your drawing
  (C:TABLE)
) ;Uses "dimtxt" and "dimscale" settings
 ;(DEFUN C:XXX5  ()(Load "XXX5")          ;Program Description Example 5
 ;(c:XXX5))
 ;(DEFUN C:XXX6  ()(Load "XXX6")          ;Program Description Example 6
 ;(c:XXX6))
 ;(DEFUN C:XXX7  ()(Load "XXX7")          ;Program Description Example 7
 ;(c:XXX7))
 ;(DEFUN C:XXX8  ()(Load "XXX8")          ;Program Description Example 8
 ;(c:XXX8))
 ;(DEFUN C:XXX9  ()(Load "XXX9")          ;Program Description Example 9
 ;(c:XXX9))
Anonymous
Anonymous
