Author Topic: SQLite for C# ~ Gareth Isaac  (Read 16609 times)
It's Alive!
  • Retired
  • AKA Daniel
Re: SQLite for C# ~ Gareth Isaac
« Reply #15 on: December 27, 2009, 12:02:21 AM »
This essentially what I did for the lisp wrappers
public class Commands
  [LispFunction("doit")]
  static public ResultBuffer doit(ResultBuffer args)
   return getQueryBuffer("C:\\MySQLite.db", "SELECT * FROM MyTable;");
  static ResultBuffer getQueryBuffer(String database, String query)
   ResultBuffer buffer = new ResultBuffer();
   using (ManagedSQLite.Database db = new ManagedSQLite.Database(database))
    using (ManagedSQLite.Query q = db.ExecuteQuery(query))
     buffer.Add(new TypedValue((short)LispDataType.ListBegin));
     while (!q.IsEndOfFile) // is now a property
      for (int i = 0; i < q.NumberOfFields; i++)
       switch (q.FieldDataType(i))
        case ManagedSQLite.SQLiteType.Integer:
         buffer.Add(new TypedValue((short)LispDataType.Int32, q.GetIntField(i)));
         break;
        case ManagedSQLite.SQLiteType.Double:
         buffer.Add(new TypedValue((short)LispDataType.Double, q.GetFloatField(i)));
         break;
        case ManagedSQLite.SQLiteType.Null:
         break;
        default:
         buffer.Add(new TypedValue((short)LispDataType.Text, q.GetStringField(i)));
         break;
      q.NextRow();
      buffer.Add(new TypedValue((short)LispDataType.ListEnd));
   return buffer;
« Reply #16 on: December 27, 2009, 12:17:02 AM »
Thanks Daniel !!
[Kerry is on vacation; this posting is a pre-saved script.]
It's Alive!
  • Retired
  • AKA Daniel
« Reply #17 on: December 27, 2009, 01:04:51 AM »
another sample
  [CommandMethod("doit")]
  public static void doit()
   string database = "C:\\MySQLite.db";
    db.ExecuteDML("create table Test1(No int, Name char(64));");
    //db.BeginTransaction() bug
    db.ExecuteDML("BEGIN TRANSACTION;");
    for (int i = 0; i < 10000; i++)
     db.ExecuteDML(String.Format("insert into Test1 values ({0} , 'Welcome To TheSwamp');", i));
    //db.CommitTransaction() bug
    db.ExecuteDML("COMMIT TRANSACTION;");
It's Alive!
  • Retired
  • AKA Daniel
« Reply #18 on: December 27, 2009, 01:05:50 AM »
Have Fun : )
« Reply #19 on: December 27, 2009, 01:32:58 AM »
Have Fun : )
If you insist :D
It's Alive!
  • Retired
  • AKA Daniel
« Reply #20 on: December 27, 2009, 01:33:21 AM »
All the string statements now accept  'param object[]' arguments   8-)
    db.ExecuteDML("create table Test2(No int, Name char(64));");
    db.BeginTransaction();
     db.ExecuteDML("insert into Test2 values ({0} , '{1}');", i, "Welcome To TheSwamp");
    db.CommitTransaction();
It's Alive!
  • Retired
  • AKA Daniel
« Reply #21 on: December 27, 2009, 02:03:47 AM »
ExecuteScalar has a bug don't use it yet
It's Alive!
  • Retired
  • AKA Daniel
« Reply #22 on: December 27, 2009, 02:16:11 AM »
ExecuteScalar sample
   Editor ed =
    AcAp.Application.DocumentManager.MdiActiveDocument.Editor;
    int res =  db.ExecuteScalar("select count(*) from Test2;");
    ed.WriteMessage("\nselect count {0}", res);
It's Alive!
  • Retired
  • AKA Daniel
« Reply #23 on: December 27, 2009, 02:51:27 AM »
It looks like all the functions are working and there don't seem to be anymore leaks. I don't really like the method the original author uses to covert System::String to wchar_t, I might go in and optimize this a bit better. Once the code is stabilized, I will go in and add comments for Doxygen  8-)
« Reply #24 on: December 27, 2009, 03:20:21 AM »
    [LispFunction("DOIT1227")]
    static public ResultBuffer MyLispFunction_DOIT1227(ResultBuffer args)
        return getQueryBuffer("K:\\KDUBPro2010\\PipeData.db3",
            "SELECT * FROM FittingsReducer WHERE nb = 100 AND nb_reduced = 90;");
Command: netload
Command: (doit1227)
((100 114.3 90 101.6 105.0 102.0 102.0))
« Reply #25 on: December 27, 2009, 03:23:27 AM »
Dan, 'cause I'm too lazy to look it up at the moment :
Can you remind me how to get a listing of colulmn headers ?
It's Alive!
  • Retired
  • AKA Daniel
« Reply #26 on: December 27, 2009, 04:27:51 AM »
have a look
namespace CsMgdAcad2
 public class SqlRow : List<object> { }
 public class SqlTable : List<SqlRow> { }
  [CommandMethod("addit")]
  public static void addit()
    db.ExecuteDML("create table Test4(No int, Name char(64));");
    for (int i = 0; i < 10; i++)
     db.ExecuteDML(String.Format("insert into Test4 values ({0} , 'Welcome To TheSwamp');", i));
  [CommandMethod("getit")]
  public static void getit()
   Editor ed = AcAp.Application.DocumentManager.MdiActiveDocument.Editor;
   string query = "SELECT * FROM Test4;";
   SqlTable table = getQueryTable(database, query);
   foreach (SqlRow row in table)
    ed.WriteMessage("\n(");
    foreach (object item in row)
     ed.WriteMessage("{0} ", item);
    ed.WriteMessage(")");
   return getQueryBuffer("C:\\MySQLite.db", "SELECT * FROM Test4;");
  static SqlTable getQueryTable(String database, String query)
   SqlTable table = new SqlTable();
     // get the column names
     SqlRow names = new SqlRow();
      names.Add(q.FieldName(i));
     table.Add(names);
      SqlRow row = new SqlRow();
      for (int i = 0; i < q.NumberOfFields; i++) // NumberOfFields is now property
        case ManagedSQLite.SQLiteType.Integer: // added SQLiteType enum
         row.Add(q.GetIntField(i));
         break;
         row.Add(q.GetFloatField(i));
         break;
         break;
        default:
         row.Add(q.GetStringField(i));
         break;
      q.NextRow();
      table.Add(row);
   return table;
     //get columns
      buffer.Add(new TypedValue((short)LispDataType.Text, q.FieldName(i)));
         break;
         break;
         break;
        default:
         break;
      q.NextRow();
   return buffer;
It's Alive!
  • Retired
  • AKA Daniel
« Reply #27 on: December 27, 2009, 04:33:44 AM »
Query.FieldName is the function to get the column name
« Reply #28 on: December 27, 2009, 04:35:31 AM »
brilliant !
I'll send Lorraine off to Darrell Lea tomorrow :)
It's Alive!
  • Retired
  • AKA Daniel
« Reply #29 on: December 27, 2009, 04:48:17 AM »
brilliant !
Let's see, one Jelly Belly per line of code .... carry the 4...
Ha! I still owe you!  :laugh:
