Author Topic: to make fast lisp  (Read 4422 times)
dussla
to make fast lisp
« on: December 24, 2009, 09:36:29 AM »
(setq  sela (ssget "x" ) )
(command "change" sela "" "P"  "c" "251" "")
hi
friend ,  i need  your help again ~~~
above lisp routine  is to change color
but that routine is very slow  in big dwg file
is there the most fast routine to change color ~
i will wait freinds answer ~
mery chrismas
Re: to make fast lisp
« Reply #1 on: December 24, 2009, 09:45:57 AM »
Either of these:
(defun c:cCol1 (/ i ss ent)
  (if (setq i -1 ss (ssget "_X"))
    (while (setq ent (ssname ss (setq i (1+ i))))
      (vla-put-color (vlax-ename->vla-object ent) 251)))
  (princ))
(defun c:cCol2 (/ i ss ent elst)
      (setq elst (entget ent))
      (if (assoc 62 elst)
        (entmod (subst (cons 62 251) (assoc 62 elst) elst))
        (entmod (append elst (list (cons 62 251)))))))
  (princ))
Not sure which is quicker
« Last Edit: December 24, 2009, 10:01:14 AM by Lee Mac »
« Reply #2 on: December 24, 2009, 09:52:22 AM »
You might find this thread to be useful.
http://www.theswamp.org/index.php?topic=55.0
« Reply #3 on: December 24, 2009, 10:06:26 AM »
Interesting result, on a SelectionSet of 10,000 points:
<< ActiveX took: 1.1700 secs. >>
<< Entmod took: 0.9360 secs. >>
<< ActiveX took: 1.1390 secs. >>
<< Entmod took: 0.9670 secs. >>
<< ActiveX took: 1.1240 secs. >>
<< Entmod took: 0.9830 secs. >>
(defun c:cCol1 (/ i ss ent time)
  (setq time (getvar "millisecs"))
  (princ (strcat "\n<< ActiveX took: "
                 (rtos (/ (- (getvar "millisecs") time) 1000.) 2 4) " secs. >>"))
  (princ))
(defun c:cCol2 (/ i ss ent elst time)
      (if (assoc 62 elst)
  (princ (strcat "\n<< Entmod took: "
  (princ))
alanjt
  • Standby for witty remark...
« Reply #4 on: December 24, 2009, 10:39:32 AM »
Just out of curiousity...
Command: tocolor
<< FULL ActiveX took: .484 secs. >>
Command:
Command:
TOCOLOR
<< FULL ActiveX took: .469 secs. >>
Command:
Command: ccol1
<< ActiveX took: .61 secs. >>
Command:
Command: ccol2
<< Entmod took: .953 secs. >>
(defun c:ToColor (/ time ss)
  (if (setq ss (ssget "_X"))
       (vlax-for x (setq ss (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object))))
         (vla-put-color x 251))
      (vla-delete ss)))
    (princ (strcat "\n<< FULL ActiveX took: " (rtos (/ (- (getvar "millisecs") time) 1000.) 2 4) " secs. >>"))
  (princ))
Dropbox
« Reply #5 on: December 24, 2009, 10:44:14 AM »
Ooo.. get you   :-P
« Reply #6 on: December 24, 2009, 10:48:07 AM »
That is great to know - I may have to start using that method a bit more  ;-)
On 10,000 points
<< ActiveX took: 1.0610 secs. >>
<< Entmod took: 0.9050 secs. >>
<< FULL ActiveX took: 0.7950 secs. >>
<< ActiveX took: 1.0460 secs. >>
<< Entmod took: 0.9680 secs. >>
<< FULL ActiveX took: 0.7800 secs. >>
Nice one Alan  :-)
So I'm guessing "vlax-ename->vla-object" takes up the most time.
fixo
« Reply #7 on: December 24, 2009, 11:16:14 AM »
Here is my attempt
(defun C:axcol (/ acapp adoc color pfs time)
(setq adoc (vla-get-activedocument
     (setq acapp (vlax-get-acad-object)
(setq color (vla-getinterfaceobject acapp
(strcat "AutoCAD.AcCmColor." (itoa (atoi (getvar "acadver"))))))
(vla-put-colormethod color acColorMethodByACI)
(vla-put-colorindex color 251)
(setq pfs (vla-get-pickfirstselectionset adoc))
(vlax-invoke-method pfs 'Clear)
(vla-select pfs acselectionsetall)
(vlax-for a pfs
  (vla-put-truecolor a color)
  (vlax-release-object color)
Result:
11,000 circles first run
<< Full ActiveX took: 1.7350 secs. >>
11,000 circles second run
<< Full ActiveX took: 1.4840 secs. >>
11,000 points first run
<< Full ActiveX took: 1.0160 secs. >>
11,000 points second run
<< Full ActiveX took: 0.9220 secs. >>
~'J'~
« Last Edit: December 24, 2009, 01:16:23 PM by fixo »
alanjt
« Reply #8 on: December 24, 2009, 11:25:06 AM »
Yeah, I tested this a while back, out of curiosity. It would be even faster if vla-get-activedocument is a global variable and already defined. :wink:
If you notice, more of my stuff (lately) has that method over anything else.
From what I remember, repeat was even faster than while, but don't quote me on that.
On 10,000 points
Nice one Alan  :-)
Dropbox
gile
  • Marseille, France
« Reply #9 on: December 25, 2009, 04:00:29 AM »
Instead of using (ssget "_X"), it should be a little faster to run directly trough the entire database
(defun c:dbToColor (/ time)
  (vlax-for l (vla-get-Layouts
                (vla-get-ActiveDocument (vlax-get-acad-object))
    (vlax-for o (vla-get-Block l)
      (vla-put-color o 256)
  (princ (strcat "\n<< FULL ActiveX (w/out ssget) took: "
                 " secs. >>"
You can have a look here too
xianaihua
« Reply #10 on: December 25, 2009, 05:23:57 AM »
Hi,gile!
thanks!
Provide you with the program is the fastest!
