Author Topic: dynamic block with attributes extraction to excel  (Read 3215 times)
astro86
« on: December 17, 2009, 10:24:43 AM »
I posted this topic on  AutoLISP (Vanilla / Visual) http://www.theswamp.org/index.php?topic=31338.msg368992
 but no answers  :cry:
maybee it's easyer with VB...
David Hall
  • Automatic Duh Generator
Re: dynamic block with attributes extraction to excel
« Reply #1 on: December 17, 2009, 03:21:31 PM »
I didn't read the LISP version, but I can tell you from experience, you will want to use different tag names for ALL the attributes, so when you extract it, it wont cause problems with the visability states.  I had many fits trying to make it work, which I eventually did, but abandoned it later b/c it was huge pain in the neck
fixo
« Reply #2 on: December 18, 2009, 05:40:10 PM »
I sent my responce here
http://www.theswamp.org/index.php?topic=31338.msg369339#msg369339
~'J'~
« Reply #3 on: December 18, 2009, 05:46:09 PM »
don't plan on using VBA if you want to carry the program forward to future AutoCAD versions.
