Author Topic: [Boo] Simple Boo acad application  (Read 1898 times)
MickD
« on: December 16, 2009, 05:52:16 PM »
A simple Boo app to whet the appetite :)
Just like Python it's quite easy and enjoyable to write and easy to implement.
I used shapdev 3.1.1
The one and only App class, don't forget to ref in the acmgd.dll and acdbmgd.dll
App.boo
namespace BOOAcad1
import System
import System.IO
import System.Reflection
import Autodesk.AutoCAD.Runtime
import Autodesk.AutoCAD.DatabaseServices
import Autodesk.AutoCAD.EditorInput
import Autodesk.AutoCAD.ApplicationServices
import Autodesk.AutoCAD.ApplicationServices.Application as acadApp
# the one and only app class, here you can do any program initialisation etc.
public class App(IExtensionApplication):
public static appPath as string
public def Initialize():
try:
appPath = Path.GetDirectoryName(System.Reflection.Assembly.GetExecutingAssembly().Location)
//load the hlr api, an example of getting the version to load version specific modules/app's
// note you can also use the C style of commenting.
ed = acadApp.DocumentManager.MdiActiveDocument.Editor
ed.WriteMessage(('\nAutoCAD Version: ' +
Autodesk.AutoCAD.ApplicationServices.Application.Version.ToString()
# seems to handle multiple lines for a single line of code pretty well :)
if Autodesk.AutoCAD.ApplicationServices.Application.Version.Major == 17:
Autodesk.AutoCAD.Runtime.SystemObjects.DynamicLinker.LoadModule('AsdkHlrApi17.dbx', true, true)
else:
ed.WriteMessage('\nSorry, hlr engine not available in this version yet!')
ed.WriteMessage('\n Loading BOOAcad application...\n')
except acEx as Autodesk.AutoCAD.Runtime.Exception:
ed.WriteMessage(('\nError: ' + acEx.Message))
return
public def Terminate():
pass
# another gotcha! this would normally be placed at the top but needs to be here for some reason(?)
[assembly: ExtensionApplication(typeof(BOOAcad1.App))]
[assembly: CommandClass(typeof(BOOAcad1.Commands))]
And a simple commands class - Commands.boo
# note where our namespace is placed, in C# it would be just before our
# class def's after the imports!
namespace BOOAcad1
import System
import System.IO
import System.Runtime.InteropServices
import Autodesk.AutoCAD.Geometry
# this is similar to the 'using' directive in C# to save some typing ;)
# Our basic class to house all of our commands
class Commands:
"""Description of Commands Class."""
public def constructor():
pass
# a simple test command
[CommandMethod('BOO1')] #our command attribute
public def BOOtest1(): #and the method to run
ed.WriteMessage("\n BOO! it works!!")
I'll post some more examples of the trickier aspects as I come to them.
Cheers.
- John Carmack
- J.R.R. Tolkien
