Author Topic: Determining the point used with SSGET  (Read 1287 times)
cmwade77
« on: December 15, 2009, 01:29:53 PM »
Ok, I have a routine that I want to use SSGET to be able to select multiple pieces of text, but in some cases one piece of text will be selected, when that happens I need to be able to determine the point that was clicked to select the object, any ideas on how I can determine what point was clicked to select the object?
Re: Determining the point used with SSGET
« Reply #1 on: December 15, 2009, 01:30:51 PM »
Look at ' ssnamex '.  I think it should have what you want, or a usable way to get what you want.
cmwade77
« Reply #2 on: December 15, 2009, 03:09:54 PM »
Thank you, that did the trick, now to just get it to work right with my routine.
