The only difficulty I can see is finding the rectangle that the user has picked inside, but other than that -should be ok
Just cheat and use: BPoly, (vlax-ename->vla-object (entlast)), (vla-getboundingbox..., calculate midpoint b/w two points.
;; Find Center of Cell Without Cheating ~ 14.12.2009 ~ Lee McDonnell(defun c:test (/ vlax-list->3D-point ssInter DOC E ENT I IPTS MAP MID MIP OBJLST PT PTS SPC SS TMP1 TMP2 TOBJ) (vl-load-com) (setq doc (vla-get-ActiveDocument (vlax-get-Acad-Object)) spc (if (zerop (vla-get-activespace doc)) (if (= (vla-get-mspace doc) :vlax-true) (vla-get-modelspace doc) (vla-get-paperspace doc)) (vla-get-modelspace doc))) (defun vlax-list->3D-point (lst) (if lst (cons (list (car lst) (cadr lst) (caddr lst)) (vlax-list->3D-point (cdddr lst))))) (defun ssInter (vlst / i j obj1 obj2 iArr iLst) (setq i (length vLst)) (while (not (minusp (setq j (1- i) i (1- i)))) (setq obj1 (nth i vLst)) (while (not (minusp (setq j (1- j)))) (setq obj2 (nth j vLst)) (if (setq iLst (vlax-list->3D-point (vlax-invoke Obj1 'IntersectWith Obj2 acExtendNone))) (setq iPts (cons (car iLst) iPts))))) iPts) (if (setq i -1 ss (ssget "_X" '((0 . "LINE,*POLYLINE")))) (progn (while (setq e (ssname ss (setq i (1+ i)))) (setq ObjLst (cons (vlax-ename->vla-object e) ObjLst))) (while (progn (setq ent (car (entsel "\nSelect Text: "))) (cond ( (eq 'ENAME (type ent)) (if (eq (cdr (assoc 0 (entget ent))) "TEXT") (while (progn (setq pt (getpoint "\nPick Inside Cell: ")) (cond ( (vl-consp pt) (setq tmp1 (vla-AddLine spc (vlax-3D-point (polar pt 0 1.)) (vlax-3D-point (polar pt pi 1.))) tmp2 (vla-AddLine spc (vlax-3D-point (polar pt (/ pi 2.) 1.)) (vlax-3D-point (polar pt (/ (* 3 pi) 2.) 1.)))) (setq ObjLst (vl-remove-if (function (lambda (x) (not (cdr x)))) (mapcar (function (lambda (x) (cons x (cond ( (vlax-list->3D-point (vlax-invoke tmp1 'IntersectWith x acExtendThisEntity))) ( (vlax-list->3D-point (vlax-invoke tmp2 'IntersectWith x acExtendThisEntity))))))) ObjLst))) (if (and ObjLst (<= 4 (length ObjLst))) (progn (setq ObjLst (vl-sort ObjLst (function (lambda (a b) (< (distance (cadr a) pt) (distance (cadr b) pt)))))) (if (not (vl-position 'nil (setq ObjLst (mapcar 'car (list (car ObjLst) (cadr ObjLst) (caddr ObjLst) (cadddr ObjLst)))))) (if (setq pts (ssInter ObjLst)) (progn (setq miP (apply 'mapcar (cons 'min pts)) maP (apply 'mapcar (cons 'max pts))) (setq Mid (polar miP (angle miP maP) (/ (distance MiP maP) 2.))) (vla-put-Alignment (setq tOBj (vlax-ename->vla-object ent)) acAlignmentMiddleCenter) (vla-put-TextAlignmentPoint tObj (vlax-3D-point Mid)) (mapcar 'vla-delete (list tmp1 tmp2))) (princ "\n** Error Detecting Cell **")) (princ "\n** Error Detecting Cell **"))) (princ "\n** Boundary not Found **")))))) (princ "\n** Object Must be Text **"))) (princ "\n** Nothing Selected **"))))) (princ "\n** No Lines or Polylines Found in Drawing **")) (princ))
If the rectangle (pline) exist then picking the rectangle make things simple.Did I miss something?
Possible Solution (WITHOUT CHEATING!)
Quote from: Lee Mac on December 14, 2009, 12:24:48 PMPossible Solution (WITHOUT CHEATING!) Maybe I need a little more background:Tables already exist, made of lines, with text already populated. Some text isn't justified Middle Center of the "cells" they are within (cells being crossing lines). I was thinking of picking the text to MC (middle center) in "cell", pick inside of "cell", modify text to be MC within that "cell".
If the text is within the area, you could just select the text object, then use it's insertion point for the interior point with -boundary. From there, you could iterate through a multiple selection.Quote from: Dommy2Hotty on December 14, 2009, 12:52:06 PMQuote from: Lee Mac on December 14, 2009, 12:24:48 PMPossible Solution (WITHOUT CHEATING!) Maybe I need a little more background:Tables already exist, made of lines, with text already populated. Some text isn't justified Middle Center of the "cells" they are within (cells being crossing lines). I was thinking of picking the text to MC (middle center) in "cell", pick inside of "cell", modify text to be MC within that "cell".
(defun c:test (/ *error* vl ov i ss ent obj pt prop eLst poly) (vl-load-com) (defun *error* (msg) (and ov (mapcar 'setvar vl ov)) (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\n** Error: " msg " **"))) (princ)) (setq vl '("CMDECHO" "OSMODE") ov (mapcar 'getvar vl)) (mapcar 'setvar vl '(0 0)) (if (setq i -1 ss (ssget "_:L" '((0 . "MTEXT,TEXT")))) (while (setq ent (ssname ss (setq i (1+ i)))) (setq obj (vlax-ename->vla-object ent)) (if (eq "AcDbText" (vla-get-ObjectName obj)) (if (eq AcAlignmentLeft (vla-get-Alignment obj)) (progn (setq tmp (vla-get-InsertionPoint obj)) (vla-put-Alignment obj acAlignmentMiddleCenter) (vla-put-TextAlignmentPoint obj tmp)) (vla-put-Alignment obj acAlignmentMiddleCenter)) (vla-put-AttachmentPoint obj acAttachmentPointMiddleCenter)) (setq pt (vlax-get obj (setq prop (if (eq "TEXT" (cdr (assoc 0 (entget ent)))) 'TextAlignmentPoint 'InsertionPoint)))) (setq eLst (entlast)) (vl-cmdf "_.-boundary" pt "") (if (not (eq eLst (setq poly (entlast)))) (progn (vla-getBoundingBox (vlax-ename->vla-object poly) 'MiP 'MaP) (setq pLst (mapcar 'vlax-safearray->list (list mIP maP))) (vlax-put-property obj prop (vlax-3D-point (polar (car pLst) (apply 'angle pLst) (/ (apply 'distance pLst) 2.)))) (entdel poly)) (princ "\n ** Boundary not Found ** ")))) (mapcar 'setvar vl ov) (princ))
The Cheating way Code: [Select](defun c:test (/ *error* vl ov i ss ent obj pt prop eLst poly) (vl-load-com) (defun *error* (msg) (and ov (mapcar 'setvar vl ov)) (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\n** Error: " msg " **"))) (princ)) (setq vl '("CMDECHO" "OSMODE") ov (mapcar 'getvar vl)) (mapcar 'setvar vl '(0 0)) (if (setq i -1 ss (ssget "_:L" '((0 . "MTEXT,TEXT")))) (while (setq ent (ssname ss (setq i (1+ i)))) (setq obj (vlax-ename->vla-object ent)) (if (eq "AcDbText" (vla-get-ObjectName obj)) (if (eq AcAlignmentLeft (vla-get-Alignment obj)) (progn (setq tmp (vla-get-InsertionPoint obj)) (vla-put-Alignment obj acAlignmentMiddleCenter) (vla-put-TextAlignmentPoint obj tmp)) (vla-put-Alignment obj acAlignmentMiddleCenter)) (vla-put-AttachmentPoint obj acAttachmentPointMiddleCenter)) (setq pt (vlax-get obj (setq prop (if (eq "TEXT" (cdr (assoc 0 (entget ent)))) 'TextAlignmentPoint 'InsertionPoint)))) (setq eLst (entlast)) (vl-cmdf "_.-boundary" pt "") (if (not (eq eLst (setq poly (entlast)))) (progn (vla-getBoundingBox (vlax-ename->vla-object poly) 'MiP 'MaP) (setq pLst (mapcar 'vlax-safearray->list (list mIP maP))) (vlax-put-property obj prop (vlax-3D-point (polar (car pLst) (apply 'angle pLst) (/ (apply 'distance pLst) 2.)))) (entdel poly)) (princ "\n ** Boundary not Found ** ")))) (mapcar 'setvar vl ov) (princ))
(defun c:CenterText (/ ss i elast obj bent ipt) (defun getmid (ent) (setq lst (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= 10 (car x))) (entget ent)))) (if (= (length lst) 4) (mapcar '(lambda (a b) (/ (+ a b) 2.)) (car lst) (caddr lst)) ) ) (command "_undo" "begin") (prompt "\Selext text within the table.") (setq ss (ssget "_:L" '((0 . "TEXT")))) (setq i -1) (while (setq ename (ssname ss (setq i (1+ i)))) (setq obj (vlax-ename->vla-object ename)) (setq elast (entlast)) (setq ipt (vlax-get obj 'insertionpoint)) (if (vl-catch-all-error-p (vl-catch-all-apply '(lambda () (vl-cmdf "_-BOUNDARY" (trans ipt 0 1) "") (while (> (getvar "CMDACTIVE") 0) (command "")) ) ) ) (princ "\nText boundry not found.") ;; got a boundry (progn (if (and (not (eq elast (setq bent (entlast)))) (setq midpt (getmid bent)) ) (progn (vla-put-Alignment obj acAlignmentMiddleCenter) (vla-put-TextAlignmentPoint Obj (vlax-3D-point MidPT)) ) (and (eq bent (entlast)) (entdel bent)) ) ) ) ) (command "_undo" "end") (princ))
