Author Topic: [non-member] Rich  (Read 5374 times)
[non-member] Rich
« on: December 11, 2009, 01:54:15 PM »
Rich, whom I met through a coworker, just donated a used server.
thanks Rich!!
More info on the server when I get it home.
Re: [non-member] Rich
« Reply #1 on: December 12, 2009, 10:06:39 AM »
one sweet machine
NetBSD 5.0.1 (GENERIC) #0: Thu Jul 30 01:39:11 UTC 2009
        builds@b8.netbsd.org:/home/builds/ab/netbsd-5-0-1-RELEASE/i386/200907292356Z-obj/home/builds/ab/netbsd-5-0-1-RELEASE/src/sys/arch/i386/compile/GENERIC
total memory = 3967 MB
avail memory = 3887 MB
timecounter: Timecounters tick every 10.000 msec
timecounter: Timecounter "i8254" frequency 1193182 Hz quality 100
Dell Computer Corporation PowerEdge 2650
mainbus0 (root)
cpu0 at mainbus0 apid 0: Intel 686-class, 3051MHz, id 0xf29
cpu1 at mainbus0 apid 6: Intel 686-class, 3051MHz, id 0xf29
cpu2 at mainbus0 apid 1: Intel 686-class, 3051MHz, id 0xf29
cpu3 at mainbus0 apid 7: Intel 686-class, 3051MHz, id 0xf29
ioapic0 at mainbus0 apid 8: pa 0xfec00000, version 11, 16 pins
ioapic1 at mainbus0 apid 9: pa 0xfec01000, version 11, 16 pins
ioapic2 at mainbus0 apid 10: pa 0xfec02000, version 11, 16 pins
acpi0 at mainbus0: Intel ACPICA 20080321
acpi0: X/RSDT: OemId <DELL  ,PE2650  ,00000001>, AslId <MSFT,0100000a>
LUSB: ACPI: Found matching pin for 0.15.INTA at func 2: 5
acpi0: SCI interrupting at int 9
acpi0: fixed-feature power button present
timecounter: Timecounter "ACPI-Safe" frequency 3579545 Hz quality 900
ACPI-Safe 32-bit timer
npx1 at acpi0 (FPU, PNP0C04)
npx1: io 0xf0-0xff irq 13
npx1: reported by CPUID; using exception 16
pcppi1 at acpi0 (SPK, PNP0800)
pcppi1: io 0x61
midi0 at pcppi1: PC speaker (CPU-intensive output)
sysbeep0 at pcppi1
attimer1 at acpi0 (TMR, PNP0100): AT Timer
attimer1: io 0x40-0x5f irq 0
FDC (PNP0700) at acpi0 not configured
COMA (PNP0501) at acpi0 not configured
COMB (PNP0501) at acpi0 not configured
apm0 at acpi0: Power Management spec V1.2
attimer1: attached to pcppi1
ipmi0 at mainbus0
pci0 at mainbus0 bus 0: configuration mode 1
pci0: i/o space, memory space enabled, rd/line, rd/mult, wr/inv ok
pchb0 at pci0 dev 0 function 0
pchb0: vendor 0x1166 product 0x0014 (rev. 0x33)
pchb1 at pci0 dev 0 function 1
pchb1: vendor 0x1166 product 0x0014 (rev. 0x00)
pchb2 at pci0 dev 0 function 2
pchb2: vendor 0x1166 product 0x0014 (rev. 0x00)
vendor 0x1028 product 0x000c (undefined subclass 0x00) at pci0 dev 4 function 0 not configured
vendor 0x1028 product 0x0008 (undefined subclass 0x00) at pci0 dev 4 function 1 not configured
vendor 0x1028 product 0x000d (undefined subclass 0x00) at pci0 dev 4 function 2 not configured
vga1 at pci0 dev 14 function 0: vendor 0x1002 product 0x4752 (rev. 0x27)
wsdisplay0 at vga1 kbdmux 1: console (80x25, vt100 emulation)
wsmux1: connecting to wsdisplay0
drm at vga1 not configured
piixpm0 at pci0 dev 15 function 0
piixpm0: vendor 0x1166 product 0x0201 (rev. 0x93)
piixpm0: interrupting at SMIpiixpm0: polling
iic0 at piixpm0: I2C bus
rccide0 at pci0 dev 15 function 1
rccide0: ServerWorks CSB5 IDE Controller (rev. 0x93)
rccide0: bus-master DMA support present
rccide0: primary channel configured to compatibility mode
rccide0: primary channel interrupting at ioapic0 pin 14
atabus0 at rccide0 channel 0
rccide0: secondary channel wired to compatibility mode
rccide0: secondary channel interrupting at ioapic0 pin 15
atabus1 at rccide0 channel 1
ohci0 at pci0 dev 15 function 2: vendor 0x1166 product 0x0220 (rev. 0x05)
ohci0: interrupting at ioapic0 pin 5
ohci0: OHCI version 1.0, legacy support
usb0 at ohci0: USB revision 1.0
pcib0 at pci0 dev 15 function 3
pcib0: vendor 0x1166 product 0x0225 (rev. 0x00)
pchb3 at pci0 dev 16 function 0
pchb3: vendor 0x1166 product 0x0101 (rev. 0x05)
pci1 at pchb3 bus 3
pci1: i/o space, memory space enabled
bge0 at pci1 dev 6 function 0: Broadcom BCM5703X Gigabit Ethernet
bge0: interrupting at ioapic1 pin 12
bge0: ASIC BCM5703 A2 (0x1002), Ethernet address 00:0d:56:71:df:96
brgphy0 at bge0 phy 1: BCM5703 1000BASE-T media interface, rev. 2
brgphy0: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-FDX, auto
bge1 at pci1 dev 8 function 0: Broadcom BCM5703X Gigabit Ethernet
bge1: interrupting at ioapic1 pin 13
bge1: ASIC BCM5703 A2 (0x1002), Ethernet address 00:0d:56:71:df:97
brgphy1 at bge1 phy 1: BCM5703 1000BASE-T media interface, rev. 2
brgphy1: 10baseT, 10baseT-FDX, 100baseTX, 100baseTX-FDX, 1000baseT, 1000baseT-FDX, auto
pchb4 at pci0 dev 16 function 2
pchb4: vendor 0x1166 product 0x0101 (rev. 0x05)
pci2 at pchb4 bus 4
pci2: i/o space, memory space enabled
ppb0 at pci2 dev 8 function 0: vendor 0x8086 product 0x0309 (rev. 0x01)
pci3 at ppb0 bus 5
pci3: i/o space, memory space enabled
ahc1 at pci3 dev 6 function 0: Adaptec aic7899 Ultra160 SCSI adapter
ahc1: interrupting at ioapic1 pin 14
ahc1: aic7899: Ultra160 Wide Channel A, SCSI Id=7, 32/253 SCBs
scsibus0 at ahc1: 16 targets, 8 luns per target
ahc2 at pci3 dev 6 function 1: Adaptec aic7899 Ultra160 SCSI adapter
ahc2: interrupting at ioapic1 pin 15
ahc2: aic7899: Ultra160 Wide Channel B, SCSI Id=7, 32/253 SCBs
scsibus1 at ahc2: 16 targets, 8 luns per target
pchb5 at pci0 dev 17 function 0
pchb5: vendor 0x1166 product 0x0101 (rev. 0x05)
pci4 at pchb5 bus 1
pci4: i/o space, memory space enabled
pchb6 at pci0 dev 17 function 2
pchb6: vendor 0x1166 product 0x0101 (rev. 0x05)
pci5 at pchb6 bus 2
pci5: i/o space, memory space enabled
isa0 at pcib0
com0 at isa0 port 0x3f8-0x3ff irq 4: ns16550a, working fifo
com1 at isa0 port 0x2f8-0x2ff irq 3: ns16550a, working fifo
pckbc0 at isa0 port 0x60-0x64
fdc0 at isa0 port 0x3f0-0x3f7 irq 6 drq 2
timecounter: Timecounter "clockinterrupt" frequency 100 Hz quality 0
scsibus0: waiting 2 seconds for devices to settle...
scsibus1: waiting 2 seconds for devices to settle...
fd0 at fdc0 drive 0: 1.44MB, 80 cyl, 2 head, 18 sec
atapibus0 at atabus0: 2 targets
cd0 at atapibus0 drive 0: <TEAC CD-ROM CD-224E, , K.9A> cdrom removable
cd0: 32-bit data port
cd0: drive supports PIO mode 4, DMA mode 2, Ultra-DMA mode 2 (Ultra/33)
cd0(rccide0:0:0): using PIO mode 4, DMA mode 2, Ultra-DMA mode 2 (Ultra/33) (using DMA)
uhub0 at usb0: vendor 0x1166 OHCI root hub, class 9/0, rev 1.00/1.00, addr 1
uhub0: 4 ports with 4 removable, self powered
sd0 at scsibus0 target 0 lun 0: <IBM, IC35L073UCDY10-0, S27F> disk fixed
sd0: 70007 MB, 36703 cyl, 6 head, 651 sec, 512 bytes/sect x 143374650 sectors
sd0: sync (12.50ns offset 127), 16-bit (160.000MB/s) transfers, tagged queueing
sd1 at scsibus0 target 1 lun 0: <IBM, IC35L073UCDY10-0, S27F> disk fixed
sd1: 70007 MB, 36703 cyl, 6 head, 651 sec, 512 bytes/sect x 143374650 sectors
sd1: sync (12.50ns offset 127), 16-bit (160.000MB/s) transfers, tagged queueing
sd2 at scsibus0 target 2 lun 0: <IBM, IC35L073UCDY10-0, S27F> disk fixed
sd2: 70007 MB, 36703 cyl, 6 head, 651 sec, 512 bytes/sect x 143374650 sectors
sd2: sync (12.50ns offset 127), 16-bit (160.000MB/s) transfers, tagged queueing
sd3 at scsibus0 target 3 lun 0: <IBM, IC35L073UCDY10-0, S27F> disk fixed
sd3: 70007 MB, 36703 cyl, 6 head, 651 sec, 512 bytes/sect x 143374650 sectors
sd3: sync (12.50ns offset 127), 16-bit (160.000MB/s) transfers, tagged queueing
sd4 at scsibus0 target 4 lun 0: <IBM, IC35L073UCDY10-0, S27F> disk fixed
sd4: 70007 MB, 36703 cyl, 6 head, 651 sec, 512 bytes/sect x 143374650 sectors
sd4: sync (12.50ns offset 127), 16-bit (160.000MB/s) transfers, tagged queueing
ses0 at scsibus0 target 6 lun 0: <PE/PV, 1x5 SCSI BP, 1.1> processor fixed
ses0: SAF-TE Compliant Device
ses0: async, 8-bit transfers
ipmi0: version 1.0 interface SMIC iobase 0xecf4/3 spacing 1
Kernelized RAIDframe activated
pad0: outputs: 44100Hz, 16-bit, stereo
audio0 at pad0: half duplex
boot device: sd0
