Author Topic: Lisp commands  (Read 9713 times)
AVCAD
Lisp commands
« Reply #15 on: November 12, 2004, 05:38:28 PM »
WOOHOOO!! IT WORKS...
Here is the Code if anyone is intrested.
;Creates a line on a specified layer for Audio/Video Signal Flows
;Layer's are chosen by either typing "A, Audio, V, Video" in either upper or Lowercase
;in the command line when prompted.
;Tested in AutoCAD 2004 - Added to Button for ease of use.
;Button code:
;^C^C(LOAD "G:/CHI-CUSTOMCAD/LISP/WIRING");WIRE;
;www.theswamp.org
;Written by Philip DeCanio, for Shen Milsom & Wilke - 11-12-2004
(defun C:wire ()
(setq P (getstring "(A)udio or (V)ideo: "))
(command "ORTHO" "ON" "SNAP" ".25")
(IF (= P "A")(command "-LAYER" "M" "A-WIRING" "C" "RED" "" "" "LINE"))
(IF (= P "V")(command "-LAYER" "M" "V-WIRING" "C" "GREEN" "" "" "LINE"))
(IF (= P "a")(command "-LAYER" "M" "A-WIRING" "C" "RED" "" "" "LINE"))
(IF (= P "v")(command "-LAYER" "M" "V-WIRING" "C" "GREEN" "" "" "LINE"))
(IF (= P "audio")(command "-LAYER" "M" "A-WIRING" "C" "RED" "" "" "LINE"))
(IF (= P "video")(command "-LAYER" "M" "V-WIRING" "C" "GREEN" "" "" "LINE"))
(IF (= P "AUDIO")(command "-LAYER" "M" "A-WIRING" "C" "RED" "" "" "LINE"))
(IF (= P "VIDEO")(command "-LAYER" "M" "V-WIRING" "C" "GREEN" "" "" "LINE"))
Thanks for the help everyone.
CarlB
Lisp commands
« Reply #16 on: November 12, 2004, 05:57:54 PM »
Avcad-
Look into the function "getkword" - it would reduce the code required by quite a bit.
Ronjop - I think "getkword" instead of "getstring" would solve your problem as well.
MikePerry
Lisp commands
« Reply #17 on: November 12, 2004, 06:21:55 PM »
Quote from: ronjonp
What am I doing wrong here? I saw the code examples and wanted to combine 3 lisps that I use. It doesn't use the options though.
Hi
Below snippet is from the AutoLISP Reference Help File -
<snip>
initget Function
The getstring function is the only user-input function that does not honor keywords.
</snip>
Therefore below is my humble re-working -
(defun c:bb (/ P) ;Used for inserting bubbler laterals
  (setvar 'plinegen 1)
  (initget 1 "Tree Shrub Bub") ;Gets T or S or B
  (setq P (getkword
   "\nEnter an option (T)ree or (S)hrub or (B)ub Lateral: "
  (if (= P "Tree")
      (setvar 'plinewid (* (getvar "dimscale") 0.05))
      (command "_.-Layer"   "_Make" "0280-tree-lateral"
      "_L"    "hidden2" ""      "_Color"
      "4"    "" ""
      (command "_.PLine")
      (while (> (getvar "CMDACTIVE") 0)
(command pause)
  (if (= P "Shrub")
      (setvar 'plinewid (* (getvar "dimscale") 0.0125))
      (command "_.-Layer"     "_Make"     "0280-shrub-lateral"
      "_Color"      "6"     ""
      (command "_.PLine")
(command pause)
  (if (= P "Bub")
      (setvar 'plinewid (* (getvar "dimscale") 0.0))
      (command "_.-Layer"   "_Make" "0280-bub-lateral"
      "5"    "" ""
      (command "_.PLine")
(command pause)
Have a good one, Mike
Lisp commands
« Reply #18 on: November 12, 2004, 07:02:36 PM »
Thanks guys. Works like a charm now. :)
AVCAD
Lisp commands
« Reply #19 on: November 15, 2004, 10:11:08 AM »
I tried using the getkword function, but for some reason it I was having trouble with it so I started over and used getstring.
Lisp commands
« Reply #20 on: November 15, 2004, 10:33:36 AM »
Quote from: AVCAD
Try the first code i posted, I changed it to use getkword.
ELOQUINTET
Lisp commands
« Reply #21 on: November 15, 2004, 11:14:23 AM »
i modified mike's but can't figure out why the stainless steel portion isn't working, any help would be great
(defun c:LLL (/ P)         ;USED FOR DRAWING LINES ON CERTAIN LAYERS
  (initget 1 "Glass Stainless steel Aluminum")      ;Gets G or S or A
  (setq   P (getkword
       "\nEnter an option (G)lass (S)tainless steel (A)luminum: "
  (if (= P "Glass")
      (command "_.-Layer"   "_Make"    "0-GLASS"
          "_L"       "CONTINUOUS"    ""         "_Color"
          "Cyan"       ""       ""
      (command "Line")
   (command pause)
  (if (= P "Stainless steel")
      (command "_.-Layer"   "_Make"    "0-STAINLESS STEEL"
          "_L"       "Continuous"    ""         "_Color"
          "Yellow"       ""       ""
      (command "Line")
   (command pause)
  (if (= P "Aluminum")
      (command "_.-Layer"   "_Make"    "0-ALUMINUM"
          "Green"       ""       ""
      (command "Line")
   (command pause)
Lisp commands
« Reply #22 on: November 15, 2004, 11:48:16 AM »
Keyword Specifications
The string argument is interpreted according to the following rules:
Each keyword is separated from the following keyword by one or more spaces. For example, "Width Height Depth" defines three keywords.
No Spaces allowed
Lisp commands
« Reply #23 on: November 15, 2004, 11:49:24 AM »
Mike,
That is a good one. Your code is perfectly fine and very readable.
But if you don't mind here is another way to do it.
Because you use INITGET 1 the routine will not continue unless the user enters a
keyword. So with that guarantee you can use a cond stmt to test the keyword and
unlike the multiple if statements it will stop testing as soon as it finds a match.
This is just another approach. The pline code is the same for each condition so it
can be moved to a point after the condition statement and you will not need to
duplicate the code.
If you could not guarantee the keyword you could use a True condition to catch
anything that fell through. Like this
  ((= p "Tree")
    Do Tree stuff)
  ((= p "Shrub")
    Do Shrub stuff)
  (T
    (alert "Nothing to do."))
 But you would have to use the pline code conditionally now. Like this:
(if (memeber p '("Tree" "Shrub"))
     (command "_.PLine")
      (command pause)
  Here is the code done with cond statement
(defun c:bb (/ p) ;Used for inserting bubbler laterals
  (setq p (getkword
    ((= p "Tree")
     (command "_.-Layer" "_Make" "0280-tree-lateral" "_L" "hidden2" "" "_Color" "4" "" "")
    ((= p "Shrub")
     (command "_.-Layer" "_Make" "0280-shrub-lateral" "_Color" "6" "" "")
    ((= p "Bub")
     (command "_.-Layer" "_Make" "0280-bub-lateral" "_L" "hidden2" "" "_Color" "5" "" "")
  (command "_.PLine")
    (command pause)
ELOQUINTET
Lisp commands
« Reply #24 on: November 15, 2004, 12:12:08 PM »
cab i suspected that was it so i took the spaces out so it read as "Stainlesssteel" but still couldn't get it to work. what spaces are you referring to?
Lisp commands
« Reply #25 on: November 15, 2004, 12:15:12 PM »
I also added:
(if (tblsearch "layer" "0280-tree-lateral")
(command "-layer" "thaw" "0280-tree-lateral" "on" "0280-tree-lateral" "")
To thaw and turn on the layer. If the layer existed and was frozen the lisp would break since frozen layers cannot be made current.
Dan,
When I run your lisp I get a syntax error for some reason.....can't figure it out.
(defun c:drip (/ P)         ;Used for inserting bubbler laterals
  (initget 1 "Tree Shrub Bub Header Cv")      ;Gets T or S or B or H or C
  (setq   P (getkword
       "\nEnter an option (T)ree, (S)hrub, (B)ub, (H)eader, or (C)v Lateral: "
  (if (= P "Tree")
          "4"       ""       ""
      (command "_.PLine")
   (command pause)
  (if (= P "Shrub")
(if (tblsearch "layer" "0280-shrub-lateral")
(command "-layer" "thaw" "0280-shrub-lateral" "on" "0280-shrub-lateral" "")
          "_Color"         "6"        ""
      (command "_.PLine")
   (command pause)
  (if (= P "Bub")
(if (tblsearch "layer" "0280-bub-lateral")
(command "-layer" "thaw" "0280-bub-lateral" "on" "0280-bub-lateral" "")
          "5"       ""       ""
      (command "_.PLine")
   (command pause)
  (if (= P "Header")
(if (tblsearch "layer" "0280-netafim_header")
(command "-layer" "thaw" "0280-netafim_header" "on" "0280-netafim_header" "")
      (command "_.-Layer"   "_Make"    "0280-netafim_header"
          "_L"       "continuous"    ""         "_Color"
          "white"       ""       ""
      (command "_.PLine")
   (command pause)
  (if (= P "Cv")
(if (tblsearch "layer" "0280-netafim_cv")
(command "-layer" "thaw" "0280-netafim_cv" "on" "0280-netafim_cv" "")
      (setvar 'plinewid (* (getvar "dimscale") 0.025))
      (command "_.-Layer"   "_Make"    "0280-netafim_cv"
          "yellow"       ""       ""
      (command "_.PLine")
   (command pause)
Thanks for the help.
Lisp commands
« Reply #26 on: November 15, 2004, 12:25:40 PM »
Quote from: eloquintet
The one in the initget and the test
(defun c:lll (/ p) ;USED FOR DRAWING LINES ON CERTAIN LAYERS
  (initget 1 "Glass Stainlesssteel Aluminum") ;Gets G or S or A
  (setq p (getkword
    ((= p "Glass")
       (command "_.-Layer" "_Make" "0-GLASS" "_L" "CONTINUOUS" "" "_Color" "Cyan" "" "")
    ((= p "Stainlesssteel")
       (command "_.-Layer" "_Make" "0-STAINLESS STEEL" "_L" "Continuous" "" "_Color" "Yellow" "" "")
    ((= p "Aluminum")
       (command "_.-Layer" "_Make" "0-ALUMINUM" "_L" "Continuous" "" "_Color" "Green" "" "")
  (command "Line")
    (command pause)
ELOQUINTET
Lisp commands
« Reply #27 on: November 15, 2004, 12:26:56 PM »
hmmm no message here maybe i'll modify this one and get back to ya
ELOQUINTET
Lisp commands
« Reply #28 on: November 15, 2004, 12:29:03 PM »
cool that one works cab tanks
Lisp commands
« Reply #29 on: November 15, 2004, 12:48:22 PM »
Ron
Here is another method.
(defun c:bb (/ p dimx lyr) ;Used for inserting bubbler laterals
  (setq p (getkword
    ((= p "Tree")
     (setq dimx 0.05)
     (setq lyr (list "0280-tree-lateral" "_L" "hidden2" "" "_Color" "4" "" ""))
    ((= p "Shrub")
     (setq dimx  0.0125)
     (setq lyr (list "0280-shrub-lateral" "_Color" "6" "" ""))
    ((= p "Bub")
     (setq dimx  1.0)
     (setq lyr (list "0280-bub-lateral" "_L" "hidden2" "" "_Color" "5" "" ""))
  (if (tblsearch "layer" (car lyr))
    (command "-layer" "T" (car lyr) "ON" (car lyr) "")
    (command "_.-layer" "_make" (foreach x lyr (command x)))
  (setvar 'plinewid (* (getvar "dimscale") dimx))
  (command "_.PLine")
    (command pause)
