Author Topic: single selection in acad2010  (Read 2276 times)
Amsterdammed
« on: December 07, 2009, 04:52:14 PM »
Hello again.
i seem to have another problem in Acad2010, i  (sometimes?)  can't select by single click an object, like when you use the entsel function. that drives me crazy. Could that be a setting? The IT folks reinstalled my whole Laptop (and they usual don't really know what they are doing), so could that be a other than Acad problem?
bernd
JCTER
Re: single selection in acad2010
« Reply #1 on: December 07, 2009, 04:53:30 PM »
PICKFIRST ?
David Hall
  • Automatic Duh Generator
« Reply #2 on: December 07, 2009, 05:09:22 PM »
or in the properties box the button is set to 1 not +
« Reply #3 on: December 08, 2009, 10:27:18 AM »
It very aggravating to start a new ACAD when you old setting have been changed.
The problem is you set them & forget them until something is not working.
Then your are off on a hunt for the variable you long forgot and will not reset until
the next version of ACAD comes out. I use a lisp that loads each time & sets these for me.
Perhaps you should look into doing just that & keep a backup copy.  :-)
« Reply #4 on: December 08, 2009, 10:32:54 AM »
Copy of my setup, needs to be updated for more recent versions of ACAD.
;;; variable setting mechanism
;;; called from 'AlansAutoLoad.lsp'
;;; After setting the global variable, call the function, (vl-propagate
;;; 'globalVariable) where globalVariable is the symbol name of your global
;;; variable.  This will copy the value of globalVariable into all open document
;;; namespaces and set its value in any subsequent drawings opened during the
;;; current AutoCAD session.
(defun ACADset_vars (/ var)
;;BEGINNING OF SYSTEM VARIABLE SETTING
(if (>= (substr (getvar 'acadver) 1 4) "16.1")
    (setvar 'backgroundplot 0)
    (setvar 'draworderctl 3)
    (setvar 'fieldeval 31)
    (setvar 'hpgaptol 1)
    (setvar 'osnaphatch 0)
    (setvar 'xreftype 0)
  (princ "\n   <<Ignored AutoCAD 2005 Variable List>>")
(if (>= (substr (getvar 'acadver) 1 4) "16.0")
  (setvar 'hpassoc 1)
  (setvar 'peditaccept 0)
  (setvar 'reporterror 0)
  (setvar 'startup 1)
  (setvar 'gripobjlimit 30000)
  (setvar 'mtextfixed 1)
  (princ "\n   <<Ignored AutoCAD 2004 Variable List>>")
(if (>= (substr (getvar 'acadver) 1 5) "15.06")
   (setvar 'dimassoc 1)
   (setvar 'whipthread 3)
  (princ "\n   <<Ignored AutoCAD 2002 Variable List>>")
(if (>= (substr (getvar 'acadver) 1 5) "15.05")
    (setvar 'rememberfolders 1)
  (princ "\n   <<Ignored AutoCAD 2000i Variable List>>")
(if (>= (substr (getvar 'acadver) 1 4) "15.0")
  (if (and (= (getvar "MEASUREMENT") 1)      ;if metric, CAB
           (= 7 (acet-ui-message "Override DWG settings, force Imperial?   " "DWG is Metric" 20 )))
      ;in DWG (setvar "lunits"      2 )  ; 4=Arch  2=decimal
      (setvar "measureinit" 1)  ; Metric
      ;in DWG (setvar "insunits"  1)  ; block insert units Millimeters {Will Scale},  0=unitless {Will not Scale}
      ;;  only if the blocks to be inserted are metric would you set insunits to 0 or 4
      (alert "Run \"2Imperial\" to switch back.     \nInsUnits is still set to inches.  ")
    (progn  ; Imperial
      (setvar "lunits"      4 )  ; 4=Arch  2=decimal
      (setvar "measurement" 0)  ; English
      (setvar "measureinit" 0)  ; English
      (setvar "insunits"  1)  ; 0=unitless 1=inches 2=feet, block insert units
  ;;  Note- Use radians within LISP to set variables
  (setq var (list
              (list "angbase"     0 )  ;
              (list "angdir"      0 )  ; CCW
              (list "apbox"       0 )  ; Aperture box off 0
              (list "aperture"    10 ) ; zone of detection
              (list "ATTDIA"      1 )  ; ** new
              (list "ATTREQ"      0 )  ; ** new do not request attrib when inserting
              (list "aunits"      0 )  ; 0 = degrees 4 = survey
              (list "auprec"      4 )  ; decimal places displayed for angles
              (list "autosnap"    7 )  ;
              (list "blipmode"    0 )  ; o = blips off
              (list "chammode"    0 )  ; require 2 distances
              (list "cecolor"    "bylayer")
              (list "celtype"    "bylayer")
              (list "cmddia"      1 )
              (list "cmdecho"     1 )
              (list "coords"      1 )
              (list "cursorsize"  5 )  ; size of cross
              (list "demandload"  2 )  ; 2 needed for some commands, disabled 0
              (list "dimaso"      1 )  ;
              (list "dimsho"      1 )
              (list "dragmode"    2 )  ; display outline
              (list "dragp1"      10 )
              (list "dragp2"      25 )
              (list "edgemode"    1 )  ; trim to extension
              (list "expert"      4 )
              (list "facetres"    2 )
              (list "filedia"     1 ) ; display dialogs, not command line prompts
              (list "filletrad"   0 )
              (list "fillmode"    1 )  ;
              (list "gridmode"    0 )  ; grid off
              (list "grips"       1 )  ;
              (list "gripsize"    3 )  ; grip box size
              (list "highlight"   1 )
              (list "ISAVEPERCENT" 0) ; make autosave save entire drawing
              (list "insbase"  (list 0 0 0))  ;
              (list "isolines"    4 )
              (list "limcheck"    0 )  ; 0= allow create obj outside limits
              (list "luprec"      5 )  ; decimal places displayed for linear
              (list "maxactvp"    50 ) ; max viewport to be regenerated
              (list "maxsort"     500) ; max num of layers to sort in layer manager
              (list "mbuttonpan"  1)  ;
              (list "mirrtext"    0 )  ; 1=mirror text 0=backwards test
              (list "offsetgaptype" 0 )  ;
              ;; Controls how potential gaps between segments are treated when polylines are offset.
              ;; 0 Fills the gaps by extending the polyline segments
              ;; 1 Fills the gaps with filleted arc segments (the radius of each arc segment is equal to the offset distance)
              ;; 2 Fills the gaps with chamfered line segments (the perpendicular distance to each chamfer is equal to the offset distance)
              (list "NOMUTT"      0 )
              (list "osmode"      175 )
              ;(list "PDMODE"      0 )  ; new, causes a regen
              (list "pickadd"     1 )
              (list "pickauto"    1 )
              (list "pickbox"     3 )  ; the pick box size
              (list "pickdrag"    0 )
              (list "pickfirst"   1 )
              (list "pickstyle"   1 )  ;
              (list "plinegen"    0 )  ;
              (list "plinetype"   2 )  ;
              (list "plinewid"    0 )  ; pline width
              (list "plotrotmode" 2 )  ; needs to be 2 in order the show shadow in PS display
              (list "plquiet"     0 )  ; Controls the display of optional dialog boxes and nonfatal errors for batch plotting and scripts.
              ;;  0   Displays plot dialog boxes and nonfatal errors
              ;;  1   Logs nonfatal errors and doesn't display plot-related dialog boxes
              (list "PSLTSCALE"   0 )  ; new 0=do not use PS plot scale
              (list "polarang"  0.392699)  ; angle increments 22.5 DEG
              (list "polarmode"   0 )  ; use absolute angle current UCS
              (list "projmode"    1 )  ;
              (list "proxygraphics" 1)  ;
              (list "proxynotice"   0)  ; Do not notify
              (list "proxyshow"     1)  ;
              (list "QAFLAGS"      0 )
              (list "qtextmode"   0 )  ; 1=display box ILO text
              (list "regenmode"   1 )
              (list "savetime"   10 ) ; minutes between auto save 0=no auto save
              (list "sdi"         0 )
              (list "snapang"     0 )
              (list "snapbase"  (list 0 0)) ; hatch base point
              (list "snapisopair" 0 )
              (list "snapmode"    0 )
              (list "snapstyl"    0 )
              (list "snaptype"    0 )
              (list "snapunit"  (list 1 1))
              (list "sortents"    96)
              (list "splframe"    0 )
              (list "textfill"    1 )  ; plot with text filled
              (list "textqlty"    50 ) ; text resolution of TT font while plotting
              (list "textsize"    5 )  ; default text size
              (list "tooltips"    1 )
              (list "trimmode"    1 )
              (list "tstackalign" 1 )
              (list "tstacksize"  70 )
              (list "ucsfollow"   0 )
              (list "ucsicon"     0 )  ; 0=no display 3=display icon at origin
              (list "unitmode"    0 ) ; Displays fractional, feet-and-inches, and surveyor's angles as previously set
              (list "worldview"   1 )
              (list "visretain"   1 )  ; retain layer state
              (list "xloadctl"    1 )  ; load xrefs
              (list "zoomfactor"  10 )
        ); setq
  (mapcar '(lambda (x)
              (setvar(car x) (cadr x))
                  var)
  (prompt "\nACADSet_Variables has set system variables to your preset values.")
) ;; EOF
(ACADset_vars); this line runs the routine when it is loaded
JCTER
« Reply #5 on: December 08, 2009, 10:34:22 AM »
I'm 100% with CAB... nothing makes me feel more humbled than forgetting some simple, basic thing that I just can't remember what AUTODESK calls it to be able to call up the sysvar properly to toggle it...
I find the migration utility has worked 90% of the time but even 10% remaining is enough to make for a really bad day, sometimes.  Having an external LSP with all your doo-dads set like you want is WIN.  I did this only recently for the past release of oh-ten and I think it'll save many headaches... because relying on the migration tool assumes you use the same computer, or at least hard drive, forever, for the utility to -have- a previous install to copy from.
Amsterdammed
« Reply #6 on: December 10, 2009, 05:19:40 AM »
Problem is I'm in the middle of a already delayed project, so fornow i switched back to Acad 2007. And i changed my mouse, because i suspect that thing as well. As soon as i can breath again i will find out. Cab, thanks, very good idea, things like that are a must. But we switch not so often from Version, o the hit comes less often but even harder.....
