so it errors prior to even running at all ... INTERESTING ..
I have had absolutely no problem whatsoever running it .. even on 2008 .. that is after I actually got it to load
maybe instead of posting the code in the message, you could post the actual file you are loading ... I had a heck of a time finding the parenthesis that wasn't closed and then when running it I encountered even more errors ... I suspect it had to do with the copy/paste copy/paste process ...
you can diagnose it easily enough though by opening the code in the VLIDE editor, under the Debug menu, check "Trace Command" and "Animate", then load the code and run it ... it will step through each line and will stop where the error is produced.
